Hi i am using SDK15.2 nrf52832.
What is peer id?
Which function is adding device mac address to whitelist?
how does the whitelisting process implemented in HID example code?
What is peer id?
Thank you, But i how to enable BLE_GAP_EVT_SCAN_REQ_REPORT event in event handler? because i followed many blogs but i could not achieve it.
also, how to add MAC ID to whitelist directly in the case BLE_ADV_EVT_WHITELIST_REQUEST: Please post the code snippet if possible.
can i use sd_ble_gap_whitelist_set() to set the whitelist with MAC ID as input?
If you are using the advertisement module you simple stop and start advertisement, and then on BLE_ADV_EVT_WHITELIST_REQUEST event you call ble_advertising_whitelist_reply() with the desired peer.
If you are not using the advertisement module it should be possible to call sd_ble_gap_whitelist_set() directly yes.
