sd_flash_write HardFault when softdevice is enbled
I'm currently in trouble with the sd_flash_write function. I've already a library using this function running on the nRF52832 with the S132 softdevice. But when a tries to run the same code compiled for the S140 softdevice on the nRF52840, the function call get stuck in the hardfault handler.
I use the SDK version 15.2.0
If the softdevice is enabled, the hardfault always occurs at the address 0x24ADC and with the PC = 0x14a3a. But if the softdevice was never enbled, the function is perfectly working.
Do you have an idea why the function break the softdevice ?
I know the there are some other smart functons to manage the memory but I aready have an optimized library for the memory managment using the sd_flash_write function and sd_flash_page_erase.I don't want to redo all my library.
Regards
  • how much is the maximum size allowed ?
    In my archive, I have included the sdk for an easier compilation. I removed it but you'll need to add it manually in the nRF5_SDK/nrf5_SDK_15.2.0 folder
    TestFlash.zip
     I don't have a clear number, but I believe about 30-50MB is the limit.
    Edit: According to the admin of DevZone, it should be able to handle up to 1GB. Unfortunately, we are having some stability issues which causes errors sporadically in regards to file transfer.
    This would explain the reason for the error.  A full SDK is about 500MB.
     I was able to add all the missing files and got your code running. I was also able to reproduce the error but was not able to find the source of the error. The Hard Fault Assertion is due to flash writing, and it is taking too much time while something in the SoftDevice needs resources. I am discussing the issue with my colleagues and will get back to you.
    I tried to run my test flash code without calling the ble_advertising_init function but the problem still occur with the same PC
    We see the same issue. And the ble_advertising_init() function does not start advertising, we cannot clearly see what is causing the assertion. But it does assert in the BLE_SoftDeviceFlashWrite() function. While waiting, please debug the BLE_SoftDeviceFlashWrite() function.
    Thanks!
  • Ok, I'll continue to investigate on my side.
    Anyway, do you have a reference code for the sd_flash_write usage with the softdevice enbled ? If Yes can you sent it to me, It will be usefull for the debugging
    Thanks
     Great, thank you!
    The only example I could find was in the ANT Bootloader example (\examples\dfu\experimental\ant_bootloader\).
    volatile uint8_t mb_flash_busy = false;
     * sd_flash_page_erase() and sd_flash_write() generates an event at SD_EVT_IRQHandler
     * Please include run this function inside SD_EVT_IRQHandler
    void ant_boot_settings_sys_event_handler(uint32_t sys_evt, void * p_context)
        if ((sys_evt == NRF_EVT_FLASH_OPERATION_SUCCESS) || (sys_evt == NRF_EVT_FLASH_OPERATION_ERROR))
    uint32_t ant_boot_settings_save(ant_boot_settings_t * boot_settings)
        ret_code_t err_code = NRF_SUCCESS;
        mb_flash_busy = true;
        err_code      = sd_flash_write((uint32_t *) ANT_BOOT_SETTINGS_LOCATION,
                                       (uint32_t*)boot_settings,
                                        ANT_BOOT_SETTINGS_SIZE / 4);
        if (err_code == NRF_SUCCESS)
            while (mb_flash_busy); // wait until it is done
            return err_code;
        return err_code;
    uint32_t ant_boot_settings_clear(ant_boot_settings_t * boot_settings)
        // Clears \ presets the bootloader_settings memory
        memset(boot_settings, 0xFF, sizeof(ant_boot_settings_t));
        // Erases entire bootloader_settings in flash
        err_code      = sd_flash_page_erase(FLASH_LAST_PAGE); // last flash page
            return err_code;
        return err_code;
    I hope this is of any help to you.
    Øyvind
