Mesh functionality in Bootloader
I am currently attempting to include mesh functionality in a bootloader so as to have it do DFU over mesh without the serial port. I keep getting errors when trying to initialize the mesh (an ASSERTION ERROR in the entry_validation() function). Could you please explain to me what the bare minimum requirements are to initialize the mesh stack.
I have already added all mesh files and adjusted the linker to fit the bootloader in the flash space. I just want to know exactly what it would take to successfully initialize the mesh.
Context:
3 Nordic Thingy52s
nRF SDK for mesh v2.2.0
nRF SDK 15.0.0 softdevice (v6.0.0)
Base bootloader code from nRF15s secure_bootloader in the dfu example.
  • Maybe you can trace back to the modification you made to the firmware.
    How do you plan to send data to the bootloader from the application. Please be aware that you still need the mesh bootloader flashed. What the DFU application does is to forward the data packet it receive to the bootloader (by calling nrf_mesh_dfu_cmd_send() ).
    You would need to follow what we do in serial_handler_openmesh_rx() and serial_handler_dfu_rx()
  • I had not made changes to the firmware when I get this error. This appears when I use the base code on my Thingy52. after adding a board_init from the ThingySDK but by this point I had made many changes and still, on occasion get this error.
    I just wanted to know what could be wrong with the base code?
    I think we need to have some clarification here.
    Please let us know what exact firmware you are using, on which hardware board.
    Is the "base code" you mentioned the default Thingy code  ? We don't have mesh supported in that code. Please give us the exact link to the code you use.
    What are you planning to create in your application ?
  • CONTEXT:
    Mesh SDK v2.2.0
    SDK15.0.0
    NordicThingy52 DK.
    PROCESS:
    I follow the steps for making the ble_uart_coexist project. No modification to code is done. I simply move the files to their required locations.
    RESULT:
    Upon runtime, I immediately get a NO_MEM error in the places previously stated.
    QUESTION:
    I am wondering why I receive this error if I simply run the program without any modifications.
    AFTERWORD:
    As for what I am trying to do, I am attempting to go through the steps you laid out for me upon suggesting I use this example as the base code for the DFU module I am trying to make. This is my final goal.
  • First please make sure the ble_uart_coexist works fine on your thingy, meaning you can receive UART and send it to a phone, at the same time can do mesh light switch activity.
    Do you know how exactly the mesh bootloader works ? How you plan to integrate DFU support in your application ?
    There are 2 big steps needed:
    1. Integrate DFU feature and bootloader in to your application (so that it can accept DFU update) and execute it. This is normal bootloader that you can receive image via UART, not BLE.
    2. Change what in 1 so that the image can be received in BLE instead of UART.
    Both steps requires you to have deep understanding on how the Mesh bootloader works.
    I strongly suggest to start your development on a NRF52 DK, not the Thingy. The Thingy is not made to be a development board, it's a prototyping platform.
