Hii nordic;
I need to encrypt and decrypt my advertising data i.e;UUID,Major,Minor,etc.; of my nrf52832
So it cannot be seen by third parties
my sdk version is 15.2 and softdevice is 132
Hii nordic;
hi @bjorn-spockeli,
please repond
Please see the attached main.c file and use it as a reference.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO 3 /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA 1 /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
#define ECB_KEY_LEN (16UL)
#define COUNTER_BYTE_LEN (4UL)
#define NONCE_RAND_BYTE_LEN (12UL)
// The RNG wait values are typical and not guaranteed. See Product Specifications for more info.
#ifdef NRF51
#define RNG_BYTE_WAIT_US (677UL)
#elif defined NRF52
#define RNG_BYTE_WAIT_US (124UL)
#else
#error "Either NRF51 or NRF52 must be defined."
BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE Nordic UART Service (NUS) client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static bool m_initialized = false;
static nrf_ecb_hal_data_t m_ecb_data;
static uint8_t m_ecb_key[16] = {0x6E,0x88,0x90,0x8D,0x75,0xBB,0x95,0xEA,0x2C,0x65,0x93,0x01,0x43,0xF8,0x1B,0x5F};
static uint8_t nounce[16];
static uint8_t m_beacon_info[0x17];
/**@brief NUS UUID. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_IMMEDIATE_ALERT_SERVICE,
.type = BLE_UUID_TYPE_BLE
app_error_handler(0xDEADBEEF, line_num, p_file_name);
void ctr_init(const uint8_t * p_nonce, const uint8_t * p_ecb_key)
m_initialized = true;
// Save the key.
memcpy(&m_ecb_data.key[0], p_ecb_key, ECB_KEY_LEN);
// Copy the nonce.
memcpy(&m_ecb_data.ciphertext[COUNTER_BYTE_LEN],
&p_nonce[COUNTER_BYTE_LEN],
NONCE_RAND_BYTE_LEN);
// Zero the counter value.
memset(&m_ecb_data.cleartext[0], 0x00, COUNTER_BYTE_LEN);
static uint32_t crypt(uint8_t * buf)
uint8_t i;
uint32_t err_code;
if (!m_initialized)
err_code = sd_ecb_block_encrypt(&m_ecb_data);
if (NRF_SUCCESS != err_code)
return err_code;
for (i=0; i < ECB_KEY_LEN; i++)
buf[i] ^= m_ecb_data.ciphertext[i];
// Increment the counter.
(*((uint32_t*) m_ecb_data.cleartext))++;
return NRF_SUCCESS;
uint32_t ctr_encrypt(uint8_t * p_clear_text)
return crypt(p_clear_text);
uint32_t ctr_decrypt(uint8_t * p_cipher_text)
return crypt(p_cipher_text);
/**@brief Function for starting scanning. */
static void scan_start(void)
ret_code_t ret;
ret = nrf_ble_scan_start(&m_scan);
APP_ERROR_CHECK(ret);
ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
ret_code_t err_code;
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
case NRF_BLE_SCAN_EVT_CONNECTED:
ble_gap_evt_connected_t const * p_connected =
p_scan_evt->params.connected.p_connected;
// Scan is automatically stopped by the connection.
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_connected->peer_addr.addr[0],
p_connected->peer_addr.addr[1],
p_connected->peer_addr.addr[2],
p_connected->peer_addr.addr[3],
p_connected->peer_addr.addr[4],
p_connected->peer_addr.addr[5]
} break;
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("Scan timed out.");
scan_start();
} break;
case NRF_BLE_SCAN_EVT_SCAN_REQ_REPORT:
NRF_LOG_INFO("Scan Request Report received!");
case NRF_BLE_SCAN_EVT_FILTER_MATCH:
NRF_LOG_INFO("Received Advertisment Report that matches the scan filter(s)!");
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
ble_gap_scan_params_t scan_params;
memset(&scan_params,0,sizeof(scan_params));
scan_params.active = 1;
scan_params.interval = NRF_BLE_SCAN_SCAN_INTERVAL;
scan_params.window = NRF_BLE_SCAN_SCAN_WINDOW;
scan_params.timeout = 0;
scan_params.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL;
scan_params.scan_phys = BLE_GAP_PHY_1MBPS;
//scan_params.report_incomplete_evts = true;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = false;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
init_scan.p_scan_param = &scan_params;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
ret_code_t ret_val;
NRF_LOG_DEBUG("Receiving data.");
NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
for (uint32_t i = 0; i < data_len; i++)
do
ret_val = app_uart_put(p_data[i]);
if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_BUSY);
if (p_data[data_len-1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
if (ECHOBACK_BLE_UART_DATA)
// Send data back to the peripheral.
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
static uint16_t index = 0;
uint32_t ret_val;
switch (p_event->evt_type)
/**@snippet [Handling data from UART] */
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
} while (ret_val == NRF_ERROR_RESOURCES);
index = 0;
NRF_LOG_ERROR("Communication error occurred while handling UART.");
case APP_UART_FIFO_ERROR:
NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
case BLE_NUS_C_EVT_NUS_TX_EVT:
ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start();
* @brief Function for handling shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
// Prepare wakeup buttons.
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
uint8_t uuid[26];
case BLE_GAP_EVT_CONNECTED:
err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
p_gap_evt->conn_handle,
p_gap_evt->params.disconnected.reason);
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
// Pairing not supported.
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_GAP_EVT_ADV_REPORT:
//NRF_LOG_INFO("Advertise received");
scan_start();
/*//nrf_gpio_pin_toggle(LED1_PIN);
NRF_LOG_INFO("Scannable: %d",p_gap_evt->params.adv_report.type.scannable);
NRF_LOG_INFO("Scan-response: %d",p_gap_evt->params.adv_report.type.scan_response);
ble_gap_addr_t addr;
memcpy(addr.addr, p_gap_evt->params.adv_report.peer_addr.addr, 6);
/* NRF_LOG_INFO("Beacon address: %02x:%02x:%02x:%02x:%02x:%02x",
p_gap_evt->params.adv_report.peer_addr.addr[5],
p_gap_evt->params.adv_report.peer_addr.addr[4],
p_gap_evt->params.adv_report.peer_addr.addr[3],
p_gap_evt->params.adv_report.peer_addr.addr[2],
p_gap_evt->params.adv_report.peer_addr.addr[1],
p_gap_evt->params.adv_report.peer_addr.addr[0]);
// Filter on peripheral address. Should iterate over a list of known peripherals.
uint8_t beacon_addr[6] ={0xec,0x97,0x40,0x5b,0xaf,0xfa};
if(!memcmp(addr.addr,beacon_addr, sizeof(beacon_addr))){
//NRF_LOG_INFO("Scannable: %d",p_gap_evt->params.adv_report.type.scan_response);
uint16_t data_offset = 0;
uint16_t maunf_data_len;
//Check if it is a scan response packet
if(p_gap_evt->params.adv_report.type.scan_response)
NRF_LOG_INFO("Scan response report received");
// Search for manuf data in the scan response packet
maunf_data_len = ble_advdata_search(p_gap_evt->params.adv_report.data.p_data, p_gap_evt->params.adv_report.data.len,&data_offset,BLE_GAP_AD_TYPE_MANUFACTURER_SPECIFIC_DATA);
NRF_LOG_HEXDUMP_INFO((p_gap_evt->params.adv_report.data.p_data+data_offset),maunf_data_len);
// Extract nounce
memcpy(nounce,p_gap_evt->params.adv_report.data.p_data+data_offset,maunf_data_len);
// Intialize the crypto module
ctr_init(nounce,m_ecb_key);
// Find the manuf data in the advertisment packet
// Copy manuf data to beacon info array
memcpy(m_beacon_info,p_gap_evt->params.adv_report.data.p_data+data_offset,maunf_data_len);
// Decrypt the advertisment manuf data
ctr_decrypt(m_beacon_info);
ctr_decrypt(&m_beacon_info[16]);
NRF_LOG_INFO("Decrypted info:");
NRF_LOG_HEXDUMP_INFO(m_beacon_info, sizeof(m_beacon_info));
// Reset counter values for next decrypt
m_ecb_data.cleartext[0] = 0x00;
m_ecb_data.cleartext[1] = 0x00;
m_ecb_data.cleartext[2] = 0x00;
m_ecb_data.cleartext[3] = 0x00;
memmove(uuid, p_gap_evt->params.adv_report.data.p_data, p_gap_evt->params.adv_report.data.len);
NRF_LOG_INFO("UUID: %02x%02x%02x%02x%02x%02x", uuid[9], uuid[10], uuid[11], uuid[12], uuid[13], uuid[14]);
NRF_LOG_INFO("TX_POWER: %02x", p_gap_evt->params.adv_report.tx_power);
NRF_LOG_INFO("RSSI: %02x", p_gap_evt->params.adv_report.rssi);
// uint8_t batt_lvl;
// NRF_LOG_INFO("battery level: %02x", p_gap_evt->params.adv_report.batt_lvl);
} break;
case BLE_GAP_EVT_SCAN_REQ_REPORT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("ATT MTU exchange completed.");
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void)
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
* @details Handles any pending log operations, then sleeps until the next event occurs.
nrf_pwr_mgmt_run();
void nonce_generate(uint8_t * p_buf)
uint8_t i = COUNTER_BYTE_LEN;
uint8_t remaining = NONCE_RAND_BYTE_LEN;
while(0 != remaining)
uint32_t err_code;
uint8_t available = 0;
err_code = sd_rand_application_bytes_available_get(&available);
available = ((available > remaining) ? remaining : available);
if (0 != available)
err_code = sd_rand_application_vector_get((p_buf + i), available);
i += available;
remaining -= available;
if (0 != remaining)
nrf_delay_us(RNG_BYTE_WAIT_US * remaining);
uint32_t err_code;
// Initialize.
log_init();
timer_init();
uart_init();
buttons_leds_init();
db_discovery_init();
power_management_init();
ble_stack_init();
gatt_init();
nus_c_init();
scan_init();
printf("BLE UART central example started.\r\n");
NRF_LOG_INFO("BLE UART central example started.");
scan_start();
ble_gap_addr_t gap_address;
err_code = sd_ble_gap_addr_get(&gap_address);
NRF_LOG_HEXDUMP_INFO(&gap_address.addr,sizeof(gap_address.addr));
uint8_t nonce[16] = {0};
uint8_t m_beacon_info[16];
ctr_init(nonce,m_ecb_key);
NRF_LOG_INFO("Encrypted info:");
// Decrypt the ciphertext with the same counter value, i.e. 0x00,0x00,0x00,0x00, that was used for encrypting.
// Start execution.
// Enter main loop.
for (;;)
idle_state_handle();
hi @bjorn-spockeli,
thanks for the reply and for reference code
i used the given code as reference and added code then also my beacon data is not being encrypted
it is same as shown in picture
#include <stdint.h>
#include <string.h>
#include "ble_advertising.h"
#include "nrf.h"
#include "nrf_soc.h"
#include "nrf_drv_saadc.h"
#include "nrf_sdm.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_tps.h"
#include "ble_ias.h"
#include "ble_lls.h"
#include "ble_bas.h"
#include "ble_conn_params.h"
#include "ble_conn_state.h"
#include "sensorsim.h"
#include "ble_ias_c.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
//#include "nrf_ble_scan.h"
#include "nrf_fstorage.h"
#define DEVICE_NAME "NORDIC"
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(120000)
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(1000, UNIT_1_25_MS)
#define SLAVE_LATENCY 0
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)
#define APP_ADV_INTERVAL 40
#define APP_ADV_TIMEOUT_IN_SECONDS 80
#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS)
#define APP_ADV_DURATION 18000
#define BLE_ADV_DIRECTED_ENABLED true
#define BLE_ADV_DIRECTED_DISABLED false
#define BLE_ADV_DIRECTED_SLOW_ENABLED true
#define BLE_ADV_DIRECTED_SLOW_DISABLED false
#define BLE_ADV_FAST_ENABLED true
#define BLE_ADV_FAST_DISABLED false
#define BLE_ADV_SLOW_ENABLED true
#define BLE_ADV_SLOW_DISABLED false
#define BLE_ADV_WHITELIST_ENABLED true
#define BLE_ADV_WHITELIST_DISABLED false
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000)
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000)
#define MAX_CONN_PARAMS_UPDATE_COUNT 3
#define SEC_PARAM_BOND 1
#define SEC_PARAM_MITM 0
#define SEC_PARAM_LESC 0
#define SEC_PARAM_KEYPRESS 0
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE
#define SEC_PARAM_OOB 0
#define SEC_PARAM_MIN_KEY_SIZE 7
#define SEC_PARAM_MAX_KEY_SIZE 16
#define BLE_GAP_ADV_TYPE_ADV_IND 0x00
#define BLE_GAP_ADV_TYPE_ADV_DIRECT_IND 0x01
#define BLE_GAP_ADV_TYPE_ADV_SCAN_IND 0x02
#define BLE_GAP_ADV_TYPE_ADV_NONCONN_IND 0x03
#define BLE_GAP_ADDR_TYPE_PUBLIC 0x00
#define BLE_GAP_ADDR_TYPE_RANDOM_STATIC 0x01
#define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE 0x02
#define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE 0x03
#define INITIAL_LLS_ALERT_LEVEL BLE_CHAR_ALERT_LEVEL_NO_ALERT
#define TX_POWER_LEVEL (-8)
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS 600
#define ADC_PRE_SCALING_COMPENSATION 6
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS 270
#define ADC_RES_10BIT 1024
#define DEAD_BEEF 0xDEADBEEF
static uint8_t m_ecb_key[16] = {0xC4,0xB1,0xC4,0x95,0x81,0x1D,0x6D,0xD9,0x6A,0xAD,0x3E,0x09,0xFB,0x2D,0xAD,0xA3};
#ifdef NRF51
#elif defined NRF52
#else
#define APP_BEACON_INFO_LENGTH 0x17
#define APP_ADV_DATA_LENGTH 0x15
#define APP_DEVICE_TYPE 0x02
#define APP_MEASURED_RSSI 0xC5
#define APP_COMPANY_IDENTIFIER 0x004C
#define APP_MAJOR_VALUE 0x00, 0x02
#define APP_MINOR_VALUE 0x00, 0x02
#define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \
0x45, 0x56, 0x67, 0x78, \
0x89, 0x9a, 0xab, 0xbc, \
0xcd, 0xde, 0xef, 0xf0
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO 18
#define UICR_ADDRESS 0x10001080
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
APP_TIMER_DEF(m_battery_timer_id);
BLE_TPS_DEF(m_tps);
BLE_IAS_DEF(m_ias, NRF_SDH_BLE_TOTAL_LINK_COUNT);
BLE_LLS_DEF(m_lls);
BLE_BAS_DEF(m_bas);
BLE_IAS_C_DEF(m_ias_c);
NRF_BLE_QWR_DEF(m_qwr);
BLE_ADVERTISING_DEF(m_advertising);
BLE_DB_DISCOVERY_DEF(m_ble_db_discovery);
static volatile bool m_is_high_alert_signalled;
static volatile bool m_is_ias_present = false;
static nrf_saadc_value_t adc_buf[2];
static ble_uuid_t m_adv_uuids[] =
{BLE_UUID_IMMEDIATE_ALERT_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_TX_POWER_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_LINK_LOSS_SERVICE, BLE_UUID_TYPE_BLE}
static ble_gap_adv_params_t m_adv_params;
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static uint8_t m_enc_scandata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = m_enc_scandata,
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =
APP_DEVICE_TYPE,
APP_ADV_DATA_LENGTH,
APP_BEACON_UUID,
APP_MAJOR_VALUE,
APP_MINOR_VALUE,
APP_MEASURED_RSSI
static void on_ias_evt(ble_ias_t * p_ias, ble_ias_evt_t * p_evt);
static void on_lls_evt(ble_lls_t * p_lls, ble_lls_evt_t * p_evt);
static void on_ias_c_evt(ble_ias_c_t * p_lls, ble_ias_c_evt_t * p_evt);
static void on_bas_evt(ble_bas_t * p_bas, ble_bas_evt_t * p_evt);
static void advertising_init(void);
static void advertising_start(bool erase_bonds);
static void service_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
advertising_start(false);
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
nrf_saadc_value_t adc_result;
uint16_t batt_lvl_in_milli_volts;
uint8_t percentage_batt_lvl;
uint32_t err_code;
adc_result = p_event->data.done.p_buffer[0];
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
DIODE_FWD_VOLT_DROP_MILLIVOLTS;
percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
ble_ias_c_on_db_disc_evt(&m_ias_c, p_evt);
static void adc_configure(void)
ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
nrf_saadc_channel_config_t config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
err_code = nrf_drv_saadc_channel_init(0, &config);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
static void battery_level_meas_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
err_code = nrf_drv_saadc_sample();
static void timers_init(void)
err_code = app_timer_init();
err_code = app_timer_create(&m_battery_timer_id,
APP_TIMER_MODE_REPEATED,
battery_level_meas_timeout_handler);
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_KEYRING);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
break; // BLE_ADV_EVT_FAST
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
break; // BLE_ADV_EVT_IDLE
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
uint32_t err_code;
ble_advdata_t advdata;
ble_advdata_t scandata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL;
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0;
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
memset(&scandata, 0, sizeof(scandata));
scandata.name_type = BLE_ADVDATA_FULL_NAME;
scandata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
scandata.uuids_complete.p_uuids = m_adv_uuids;
gap_address.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC;
memcpy(&gap_address.addr, "\xbb\xaa\xcc\xbb\xaa\xAC", sizeof(gap_address.addr));
err_code = sd_ble_gap_addr_set(&gap_address);
err_code = ble_advdata_encode(&scandata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
if (erase_bonds == true){
delete_bonds();
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
* @brief Uses the RNG to write a 12-byte nonce to a buffer
* @details The 12 bytes will be written to the buffer starting at index 4 to leave
* space for the 4-byte counter value.
* @param[in] p_buf An array of length 16
// The random number pool may not contain enough bytes at the moment so
// a busy wait may be necessary.
uint32_t err_code;
if (0 != available)
i += available;
if (0 != remaining)
// NOTE: The ECB data must be located in RAM or a HardFault will be triggered.
* @brief Initializes the module with the given nonce and key
* @details The nonce will be copied to an internal buffer so it does not need to
* be retained after the function returns. Additionally, a 32-bit counter
* will be initialized to zero and placed into the least-significant 4 bytes
* of the internal buffer. The nonce value should be generated in a
* reasonable manner (e.g. using this module's nonce_generate function).
* @param[in] p_nonce An array of length 16 containing 12 random bytes
* starting at index 4
* @param[in] p_ecb_key An array of length 16 containing the ECB key
// Save the key.
// Copy the nonce.
memcpy(&m_ecb_data.cleartext[COUNTER_BYTE_LEN],
uint8_t i;
uint32_t err_code;
if (!m_initialized)
return err_code;
return NRF_SUCCESS;
* @brief Encrypts the given buffer in-situ
* @details The encryption step is done separately (using the nonce, counter, and
* key) and then the result from the encryption is XOR'd with the given
* buffer in-situ. The counter will be incremented only if no error occurs.
* @param[in] p_clear_text An array of length 16 containing the clear text
* @retval NRF_SUCCESS Success
* @retval NRF_ERROR_INVALID_STATE Module has not been initialized
* @retval NRF_ERROR_SOFTDEVICE_NOT_ENABLED SoftDevice is present, but not enabled
* @brief Decrypts the given buffer in-situ
* @param[in] p_cipher_text An array of length 16 containing the cipher text
* @retval NRF_SUCCESS Succeess
///**@brief Function for initializing the Advertising functionality.
// * @details Encodes the required advertising data and passes it to the stack.
// * Also builds a structure to be passed to the stack when starting advertising.
//static void advertising_init(void)
// ret_code_t err_code;
// ble_advertising_init_t init;
// memset(&init, 0, sizeof(init));
// init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
// init.advdata.include_appearance = true;
// init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
// init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
// init.advdata.uuids_complete.p_uuids = m_adv_uuids;
// init.config.ble_adv_fast_enabled = true;
// init.config.ble_adv_fast_interval = APP_ADV_INTERVAL;
// init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
// init.evt_handler = on_adv_evt;
// err_code = ble_advertising_init(&m_advertising, &init);
// APP_ERROR_CHECK(err_code);
// ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG);
static void qwr_init(void)
nrf_ble_qwr_init_t qwr_init_obj = {0};
qwr_init_obj.error_handler = nrf_qwr_error_handler;
err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
static void tps_init(void)
ble_tps_init_t tps_init_obj;
memset(&tps_init_obj, 0, sizeof(tps_init_obj));
tps_init_obj.initial_tx_power_level = TX_POWER_LEVEL;
tps_init_obj.tpl_rd_sec = SEC_JUST_WORKS;
err_code = ble_tps_init(&m_tps, &tps_init_obj);
static void ias_init(void)
ble_ias_init_t ias_init_obj;
memset(&ias_init_obj, 0, sizeof(ias_init_obj));
ias_init_obj.evt_handler = on_ias_evt;
ias_init_obj.alert_wr_sec = SEC_JUST_WORKS;
err_code = ble_ias_init(&m_ias, &ias_init_obj);
static void lls_init(void)
ble_lls_init_t lls_init_obj;
// Initialize Link Loss Service
memset(&lls_init_obj, 0, sizeof(lls_init_obj));
lls_init_obj.evt_handler = on_lls_evt;
lls_init_obj.error_handler = service_error_handler;
lls_init_obj.initial_alert_level = INITIAL_LLS_ALERT_LEVEL;
lls_init_obj.alert_level_rd_sec = SEC_JUST_WORKS;
lls_init_obj.alert_level_wr_sec = SEC_JUST_WORKS;
err_code = ble_lls_init(&m_lls, &lls_init_obj);
static void bas_init(void)
ble_bas_init_t bas_init_obj;
memset(&bas_init_obj, 0, sizeof(bas_init_obj));
bas_init_obj.evt_handler = on_bas_evt;
bas_init_obj.support_notification = true;
bas_init_obj.p_report_ref = NULL;
bas_init_obj.initial_batt_level = 100;
bas_init_obj.bl_rd_sec = SEC_OPEN;
bas_init_obj.bl_cccd_wr_sec = SEC_OPEN;
bas_init_obj.bl_report_rd_sec = SEC_OPEN;
err_code = ble_bas_init(&m_bas, &bas_init_obj);
static void ias_client_init(void)
ble_ias_c_init_t ias_c_init_obj;
memset(&ias_c_init_obj, 0, sizeof(ias_c_init_obj));
m_is_high_alert_signalled = false;
ias_c_init_obj.evt_handler = on_ias_c_evt;
ias_c_init_obj.error_handler = service_error_handler;
err_code = ble_ias_c_init(&m_ias_c, &ias_c_init_obj);
qwr_init();
tps_init();
ias_init();
lls_init();
bas_init();
ias_client_init();
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = true;
cp_init.evt_handler = NULL;
cp_init.error_handler = conn_params_error_handler;
static void alert_signal(uint8_t alert_level)
switch (alert_level)
case BLE_CHAR_ALERT_LEVEL_NO_ALERT:
NRF_LOG_INFO("No Alert.");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
break; // BLE_CHAR_ALERT_LEVEL_NO_ALERT
case BLE_CHAR_ALERT_LEVEL_MILD_ALERT:
NRF_LOG_INFO("Mild Alert.");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_0);
break; // BLE_CHAR_ALERT_LEVEL_MILD_ALERT
case BLE_CHAR_ALERT_LEVEL_HIGH_ALERT:
NRF_LOG_INFO("HIGH Alert.");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
break; // BLE_CHAR_ALERT_LEVEL_HIGH_ALERT
switch (p_evt->evt_type)
case BLE_IAS_EVT_ALERT_LEVEL_UPDATED:
if (p_evt->p_link_ctx != NULL)
alert_signal(p_evt->p_link_ctx->alert_level);
break; // BLE_IAS_EVT_ALERT_LEVEL_UPDATED
// No implementation needed.
case BLE_LLS_EVT_LINK_LOSS_ALERT:
alert_signal(p_evt->params.alert_level);
break; // BLE_LLS_EVT_LINK_LOSS_ALERT
static void on_ias_c_evt(ble_ias_c_t * p_ias_c, ble_ias_c_evt_t * p_evt)
case BLE_IAS_C_EVT_DISCOVERY_COMPLETE:
// IAS is found on peer. The Find Me Locator functionality of this app will work.
err_code = ble_ias_c_handles_assign(&m_ias_c,
p_evt->conn_handle,
p_evt->alert_level.handle_value);
m_is_ias_present = true;
break; // BLE_IAS_C_EVT_DISCOVERY_COMPLETE
case BLE_IAS_C_EVT_DISCOVERY_FAILED:
// IAS is not found on peer. The Find Me Locator functionality of this app will NOT work.
break; // BLE_IAS_C_EVT_DISCOVERY_FAILED
case BLE_IAS_C_EVT_DISCONN_COMPLETE:
// Disable alert buttons
break; // BLE_IAS_C_EVT_DISCONN_COMPLETE
case BLE_BAS_EVT_NOTIFICATION_ENABLED:
// Start battery timer
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
break; // BLE_BAS_EVT_NOTIFICATION_ENABLED
case BLE_BAS_EVT_NOTIFICATION_DISABLED:
err_code = app_timer_stop(m_battery_timer_id);
break; // BLE_BAS_EVT_NOTIFICATION_DISABLED
ret_code_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("Connected.");
// Assign connection handle to the Queued Write module.
err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, p_ble_evt->evt.gap_evt.conn_handle);
// Discover peer's services.
err_code = ble_db_discovery_start(&m_ble_db_discovery,
} break;
} break;
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
static void bsp_event_handler(bsp_event_t event)
switch (event)
sleep_mode_enter();
err_code = sd_ble_gap_disconnect(m_ias_c.conn_handle,
case BSP_EVENT_KEY_0:
if (m_is_ias_present)
if (!m_is_high_alert_signalled)
err_code =
ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_HIGH_ALERT);
err_code = ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_NO_ALERT);
if (err_code == NRF_SUCCESS)
m_is_high_alert_signalled = !m_is_high_alert_signalled;
else if (
(err_code != NRF_ERROR_RESOURCES)
(err_code != NRF_ERROR_NOT_FOUND)
} break;
case BSP_EVENT_KEY_1:
NRF_LOG_INFO("Alert Off.");
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
nrf_pwr_mgmt_run();
///**@brief Function for starting advertising.
//static void advertising_start(bool erase_bonds)
// if (erase_bonds == true){
// delete_bonds();
// // Advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED event.
// else
// uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void tx_power_set(void)
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
bool erase_bonds;
// Initialize.
log_init();
timers_init();
ble_stack_init();
adc_configure();
gap_params_init();
gatt_init();
advertising_init();
services_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Proximity example started.");
NRF_LOG_INFO("Unencrypted plaintext:");
uint8_t plaintext[] = "DATATOENCRYPT";
uint8_t nounce[16] = {0};
NRF_LOG_HEXDUMP_INFO(plaintext, sizeof(plaintext));
nonce_generate(nounce);
ctr_encrypt(plaintext);
NRF_LOG_INFO("Encrypted plaintext:");
/* Reset the counter so that the message can be decrypted on this device.
/ When ciphertext is sent to another device, then the counter will be incremented from zero and upwards after decrypting.
ctr_decrypt(plaintext);
NRF_LOG_INFO("Decrypted plaintext:");
advertising_start(erase_bonds);
tx_power_set();
// Enter main loop.
for (;;)
i am getting like this as output
please say how to encrypt that advertising data
You need to replace the plaintext array with the data that you want to encrypt....
If you want to encrypt the data that is placed in the advertisement packet then you need to call the following code in the ble_app_beacon example main.c
ctr_encrypt(m_beacon_info);
ctr_encrypt(&m_beacon_info[16]);
before you call advertising_init();
See the attached main.c file.
#include <stdio.h>
#include <stdint.h>
#include "ble.h"
#ifdef NRF51
#elif defined NRF52
#else
// Save the key.
// Copy the nonce.
uint8_t i;
uint32_t err_code;
if (!m_initialized)
return err_code;
return NRF_SUCCESS;
ret_code_t ret;
} break;
} break;
scan_start();
} break;
ret_code_t ret_val;
do
do
uint32_t ret_val;
index++;
do
index = 0;
scan_start();
switch (event)
return true;
uint8_t uuid[26];
} break;
scan_start();
// Extract nounce
} break;
switch (event)
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
err_code);
nrf_pwr_mgmt_run();
uint32_t err_code;
if (0 != available)
i += available;
if (0 != remaining)
uint32_t err_code;
// Initialize.
log_init();
timer_init();
uart_init();
ble_stack_init();
gatt_init();
nus_c_init();
scan_init();
scan_start();
// Start execution.
// Enter main loop.
for (;;)
Thank you so much for your brief explanation bjorn
