Hii nordic;
I need to encrypt and decrypt my advertising data i.e;UUID,Major,Minor,etc.; of my nrf52832
So it cannot be seen by third parties
my sdk version is 15.2 and softdevice is 132
Hii nordic;
I think i had done the same that you told in the above code then also i am not getting the values
Please help me to write that code
You can start by modifying the BLE peripheral code so that the nounce that you generate is placed in the Scan response packet. This is done by populating the ble_advdata_t srdata struct in the ble_advertising_init_t init struct in advertising_init() in main.c
ret_code_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
// Populate Scan Response Data struct
ble_advdata_manuf_data_t sr_advdata;
memset(&sr_advdata,0, sizeof(sr_advdata));
sr_advdata.data.p_data = nounce;
sr_advdata.data.size = sizeof(nounce);
sr_advdata.company_identifier = 0x0059; // Nordic Semiconductor Company ID, should be replaced with own company ID.
init.srdata.p_manuf_specific_data = &sr_advdata;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
}yes its done i had added nounce to the scan response.
now what is the code that i should add in the central side i.e., Scanning side
this code is for peripheral side usinf ble_app_proximity_beacon:
this is code i wrote using ble_app_uart_c example for decryption.Please check i am getting garbage values not getting the encrypted values
Please respond
I did not see any reference any code that added the nounce to the scan response data in the ble_app_proximity_beacon example that was attached. I added this the following way.
uint32_t err_code;
ble_advdata_t advdata;
ble_advdata_t scandata;
uint8_t flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
m_beacon_info[18] = 0x00;
m_beacon_info[19] = 100; // init battery
m_beacon_info[20] = 0x00;
m_beacon_info[21] = 0x00;
memset(&advdata, 0, sizeof(advdata));
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL;
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0;
err_code = ble_advdata_encode(&advdata, m_adv_data_buffer_1.adv_data.p_data, &m_adv_data_buffer_1.adv_data.len);
ble_advdata_manuf_data_t sr_manuf_data;
memset(&sr_manuf_data,0, sizeof(sr_manuf_data));
sr_manuf_data.data.p_data = nounce;
sr_manuf_data.data.size = sizeof(nounce);
sr_manuf_data.company_identifier = APP_COMPANY_IDENTIFIER;
memset(&scandata, 0, sizeof(scandata));
//scandata.name_type = BLE_ADVDATA_FULL_NAME;
scandata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
scandata.uuids_complete.p_uuids = m_adv_uuids;
scandata.p_manuf_specific_data = &sr_manuf_data;
ble_gap_addr_t gap_address;
gap_address.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC;
memcpy(&gap_address.addr, "\xbb\xaa\xcc\xbb\xaa\xAC", sizeof(gap_address.addr));
err_code = sd_ble_gap_addr_set(&gap_address);
err_code = ble_advdata_encode(&scandata, m_adv_data_buffer_1.scan_rsp_data.p_data, &m_adv_data_buffer_1.scan_rsp_data.len);
err_code = ble_advdata_encode(&scandata, m_adv_data_buffer_2.scan_rsp_data.p_data, &m_adv_data_buffer_2.scan_rsp_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data_buffer_1, &m_adv_params);
On the central side you have come a bit on the way. However, I would recommend filtering the ADV reports on a specific ID in the scan response manufacturing data as you now are processing all advertisement reports. In the ble_app_proximity_beacon example you are adding a lot of service UUIDs which doesnt are not used. I would remove these as these take up space in the scan response packet.
You can use the ble_advdata_search() function from ble_advdata.c to find the manufacturing data by setting the ad_type input parameter set to BLE_GAP_AD_TYPE_MANUFACTURER_SPECIFIC_DATA. This will give you the offset indicating where the manufacturing data starts.
Best regards
Bjørn
