ASSERTION FAILED at ral_fsm.c:318 - Can not even find this file
As the title descripes i get an error with a file name in it but i can not locate this file.
I am working with the 802.15.4 wireless uart example on a nRF52840 DK. I only get this error if i start inserting breakpoints, i can debug some lines and than suddenly this error.
The Call Stack looks like this:
app_error_fault_handler()
assert_nrf_callback()
RADIO_IRQHandler()
Maybe someone can help with this error. Are there more example or even a template for 802.15.4 or is this the only project i can build on?
Thank you soo much!
  • rico said:
    Thanks for the link, it llok really helpful if someone is using Eclipse and GDB, but i can not transfer all off the given information to the SES which i am using. All examples are provided with a working project for SES and your engineers recommended using the SES. Is the a similar guide for the SES?
    Sorry, I should have been more clear. you should ignore the Eclipse/GDB specific info at the beginning of the tutorial. So what I'm suggesting is that you read the blog post I linked to initially plus the last 3 paragraphs in the Eclipse/GDB tutorial because it gives some tips on how to select the interrupt priority. There's also the official documentation from Segger (link).
    rico said:
    My intention is not to debug the radio driver. But something is causing assertation faults and i need to get rid of those(weather i am causing those are something else).
     Do you get the assert even if you don't do single-step debugging?
    rico said:
    I am running some non hardware related code on the APPLICATION TASK and i am getting assertations in sys_queue.c:152 and ral_fsm.c:318. I can not find those on the github repository you linked in the first  replay.
     And sorry about this. I was under the impression that we had the complete stack in the openthread repo, but it's just the driver (also hosted here). We do not provide source code for ral_fsm.
  •  Do you get the assert even if you don't do single-step debugging?
    I have tried debugging the wireless_uart example. It is running fine without single stepping.
    As simple as it sounds, it is not working. Maybe you can try yourself with the example provided in the SDK. I am trying to debug the beginning of the "a_radio_tx_start" function in the fsm. This is called from the user task and should be as far as i understand debuggable.
    I added MMD support to wireless_uart->raw->first in SDK 15.3.0, see attached. However, I wasn't able to replicate the assert by single stepping through the code without MMD enabled. Can you try with the same configuration on your side?
    wireless_uart.zip
  • At the moment i am using the driver from github, which works like a charm. If i find some time i will test the SDK driver and give you some feedback.
  • Glad to hear that it works now. Just let me know if you still want MMD and can't get it to work.
