Mesh DFU problem
We have a Mesh app that should be updated via DFU.
The problem is that if a device (for whatever reason) restarts in the middle of DFU or it is powered up later (i.e. not working during DFU), it newer receives update.
Here is a app log (device started after DFU):
<t:         23>, ble_softdevice_support.c,  162, sd_ble_enable: app_ram_base should be adjusted to 0x20002DA0
<t:        489>, main.c,   68, Initializing and adding models
<t:        496>, main.c,  111, rom_base   26201
<t:        498>, main.c,  112, rom_end    424D4
<t:        500>, main.c,  113, rom_length 1C2D3
<t:        502>, main.c,  114, bank_addr   43000
<t:        509>, bizlogic.c,  213, Bizlogic init
<t:        511>, gap_listener.c,   85, GAP scanner started.
<t:        514>, gap_advertiser.c,   74, GAP advertiser init
<t:       5389>, nrf_mesh_dfu.c,  529, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
<t:       5398>, main.c,  141, Started.
<t:       5510>, nrf_mesh_dfu.c,  391, 	New firmware!
<t:       5512>, dfu.c,   48, NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED_NO_AUTH
<t:       5515>, nrf_mesh_dfu.c,  529, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
<t:       5519>, nrf_mesh_dfu.c,  535, Killing a TX slot prematurely (repeats done: 0).
<t:       8167>, nrf_mesh_dfu.c,  529, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
<t:       8171>, nrf_mesh_dfu.c,  535, Killing a TX slot prematurely (repeats done: 0).
Device obviously knows that is should be updated (NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED_NO_AUTH) but it fails to transfer firmware (Killing a TX slot prematurely).
How to fix this?
And also when the update is transmission over the Mesh is stopped?
If we have Client with ID = 1 and Server with ID = 2, and if Server devices are now updated, they still broadcast this new firmware to all devices and if you want to update Client device, before you can start it is already receiving update from Server devices and this update is transmitted all the time.
How to stop firmware re-transmission over the Mesh, so that you can update Client without Server firmware being relayed, because if you send init packet via serial to Client you get *84 78 87*. ?
And how to update Server devices then to newer version after like a day or so if some device is still broadcasting older firmware?
[Mesh SDK 3.1, nRF SDK 15.2, SD 6.1, nRF52840]
  • 1: Have you tested? I haven't studied the state machine flow for the Mesh bootloader, but it should be quite easy to test.
    2: Yes. If the overall timeout is 1h, then the DFU will time out after 1 hour, regardless, as long as the DFU update is not done. However, this is for the TIMER_START_TIMEOUT_US. The TIMER_DATA_TIMEOUT_US will not time out as long as it receives DFU packets, regardless whether it is for itself or for someone else.
    Edvin
  • 1. I have tested this and this works but I have to make TID value, when sending DFU same as before, because this value is random generated when you start DFU, and on next DFU only new devices / devices already updated will run, not devices waiting on like 50%
    2. Ok thank you!
    3. With our tests done this DFU is not really usable in working environments and it looks like it works only if everything is perfect and we don't know what would be the best thing to do...
    -If devices are far apart with like 3+ jumps between mesh devices, it usually just aborts DFU on device farthest from device running DFU, even when sending really slow(each packet on 2+second - tested with all devices provisioned, sending something each 10sec)
    -You never know when some device stops on 1% and this nrfutil update is pretty useless because you only know that device on Serial got update and for others is a mystery until you update it 100% and request their version.
    So only thing I see that can be done is
    -run DFU on other device (not for example Client which has provisioned devices)
    -Send to client all DFU_STARTS / DFU_ENDS from all nodes
    -If you get DFU_END from some Server, redo whole DFU procedure
    -Pray it works, or you can update DFU all day
    Is there something else that we can do here to make this DFU more reliable and not so time consuming?
    Thank you in advance!
  • DFU on Mesh is time consuming. This is because Mesh is a low power network, with low throughput. When you say it isn't working with 3+ jumps. Are they far apart? Do you experience a lot of loss on a regular basis between these nodes? Have you tried turning up the relay count on the nodes?
    Look in nrf_mesh_config_core.h. What is your MESH_FEATURE_RELAY_ENABLED, and what is your CORE_TX_REPEAT_RELAY_DEFAULT? If they are both 1, can you try to increase CORE_TX_REPEAT_RELAY_DEFAULT to  2 or 3?
    How many nodes are in the network that you are trying to perform the DFU on?
    BR,
    Edvin
  • Hi!
    MESH_FEATURE_RELAY_ENABLED is set to 1
    I tried setting CORE_TX_REPEAT_RELAY_DEFAULT to 2 or 3 but there is no difference.
    1. A week ago I tried
    -compiling Release and creating .zip file
    -Updating with 500ms
    -I forgot to change server app version from 1 -> 4 so it updated thinking it was version 4(I set 4 when making zip file), but then it flashed back to 1 and client devices, are still sending update for server all the time and set other servers into New firmware so it doesn't look this abort timeout is working here because I left devices untouched for atleast 4 days and when you reboot 1 device you always get "New firmware".
    Shouldn't client devices timeout after 10minutes? Why do I get update is in progress after 4 days?
    2. 1 week ago it worked, but when I tried it again today it doesn't work and I get timeout reason after some time like packets where lost in transition
    2. We have our own dfu.c file
    bool dfu_mode = true;
    static nrf_mesh_evt_handler_t dfu_event_handler;
    bool fw_updated_event_is_for_me(const nrf_mesh_evt_dfu_t *p_evt) {
        switch (p_evt->fw_outdated.transfer.dfu_type) {
        case NRF_MESH_DFU_TYPE_APPLICATION:
            return (p_evt->fw_outdated.current.application.app_id == p_evt->fw_outdated.transfer.id.application.app_id &&
                    p_evt->fw_outdated.current.application.company_id == p_evt->fw_outdated.transfer.id.application.company_id &&
                    p_evt->fw_outdated.current.application.app_version < p_evt->fw_outdated.transfer.id.application.app_version);
        case NRF_MESH_DFU_TYPE_BOOTLOADER:
            return (p_evt->fw_outdated.current.bootloader.bl_id == p_evt->fw_outdated.transfer.id.bootloader.bl_id &&
                    p_evt->fw_outdated.current.bootloader.bl_version < p_evt->fw_outdated.transfer.id.bootloader.bl_version);
        case NRF_MESH_DFU_TYPE_SOFTDEVICE:
            return false;
            return false;
    void dfu_event_cb(const nrf_mesh_evt_t *p_evt) {
        switch (p_evt->type) {
        case NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED:
        case NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED_NO_AUTH:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED_NO_AUTH\n");
            if (fw_updated_event_is_for_me(&p_evt->params.dfu))
                ERROR_CHECK(nrf_mesh_dfu_request(p_evt->params.dfu.fw_outdated.transfer.dfu_type, &p_evt->params.dfu.fw_outdated.transfer.id, (uint32_t *)bank_addr));
                ERROR_CHECK(nrf_mesh_dfu_relay(p_evt->params.dfu.fw_outdated.transfer.dfu_type, &p_evt->params.dfu.fw_outdated.transfer.id));
        case NRF_MESH_EVT_DFU_START:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NRF_MESH_EVT_DFU_START\n");
            dfu_mode = true;
        case NRF_MESH_EVT_DFU_END:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NRF_MESH_EVT_DFU_END\n");
            dfu_mode = false;
            send_dfu(p_evt->type);
        case NRF_MESH_EVT_DFU_BANK_AVAILABLE:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NRF_MESH_EVT_DFU_BANK_AVAILABLE\n");
            ERROR_CHECK(nrf_mesh_dfu_bank_flash(p_evt->params.dfu.bank.transfer.dfu_type));
            //__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Unhandled Mesh Event: %d \n", p_evt->type);
    void dfu_init() {
        dfu_mode = false;
        rom_length = (uint32_t)rom_end - rom_base;
        bank_addr = (uint32_t)(rom_end & FLASH_PAGE_MASK) + FLASH_PAGE_SIZE;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "rom_base   %X\n", rom_base);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "rom_end    %X\n", rom_end);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "rom_length %X\n", rom_length);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "bank_addr  %X\n", bank_addr);
        dfu_event_handler.evt_cb = dfu_event_cb;
        nrf_mesh_evt_handler_add(&dfu_event_handler);
    Should there be some other event handler here added or is that it?
    3. When trying DFU there is so many options it goes wrong
    -It can just stop when starting *RADIO TX! SLOT 1* and it says "count 99" so like it was trying to send something but couldn't and then it doesn't go on
    -It can Abort randomly with timeout
    -It can say NRF_MESH_DFU_END_ERROR_PACKET_LOSS
    -or NRF_MESH_DFU_END_ERROR_BANK_IN_BOOTLOADER_AREA
    And if I want to stop ALL sending via mesh when making DFU I cannot know any of this until DFU is complete (after 1h) and I can find out that 3/4 of devices got some error and don't work.
    4. What if
    Client 1 and Server 1 currently have firmware 1 and they are broadcasting it
    Then I run DFU on Client 2 with firmware 2 for Servers.
    4.1 Will Server 1 and others be updated properly?
    4.2 Can this somehow screw DFU if some old DFU is still in the air?
    4.3 After Server update, should I delete DFU on Client devices, so they don't broadcast it anymore?
    5. Is there anything else I can try?
    In python script I changed random TID to static, so I can send same firmware with same ID if something went wrong, but I don't see this changed have any influence on this problems.
    It is difficult to say what's going on without knowing the extent of your changes.
     You still have the dfu_evt_handler() in nrf_mesh_dfu.c, right?
    In this function, do you still use the TIMER_START_TIMEOUT_US and the TIMER_DATA_TIMEOUT_US? But you never see "Timeout fired @..." anywhere in the log? Or if you set a breakpoint there? (in nrf_mesh_dfu.c in timer_timeout?
    I know it isn't straight forward, but by default, it should work like this:
    One device initiates the DFU (the one being connected to the computer via serial), and starts transmitting the DFU packets. When the first DFU packet is received, each device will get the BLE_EVT_TYPE_DFU_START, and start a timer with timeout TIMER_START_TIMEOUT_US. Then, after that, each incoming DFU packet will trigger the BL_EVT_TYPE_DFU_DATA_SEGMENT, and start/restart the timer with TIMER_DATA_TIMEOUT_US. If any of these timeouts hit, the timer will abort the DFU session.
    In addition to starting these timers, each node will check whether the packet is intended for itself or not in the mesh_evt_handler() in main.c. It uses fw_updated_event_is_for_me() to check this. As you can see, it will, based on this, either store the data from the packet, then relay it, or just relay it.
    Can you check whether any of the timeouts fire? You can test this easier by reducing TIMER_DATA_TIMEOUT_US and TIMER_START_TIMEOUT_US to one minute or so, instead of 10 minutes.
