nr52832 nfc read and write not working properly with i2c
Hi, I am using nRF52832 with sensor, nfc and  Softdevice S132 v3.0.0 to advertising packets .The sensor is interfaced with nrf52832 using twi interface. I have referred examples\nfc\writable_ndef_msg to read and write data from nfc.  I am writing url to nfc tag and read  it from tag. When I Comment sensor  code , nfc read and write operation work properly. But When I used sensor code then after writing data to tag it reads new data once then it reads old data.
Thanks in Advance
  • Hi.
    Could you share the project with me?
    TWI should not affect nfc operations.
    Andreas
  • static const uint8_t m_url[] =
        {'n', 'o', 'r', 'd', 'i', 'c', 's', 'e', 'm', 'i', '.', 'c', 'o', 'm'}; // URL "nordicsemi.com"
    uint8_t       m_ndef_msg_buf[NDEF_FILE_SIZE];                               // Buffer for NDEF file
    volatile bool m_update_state;                                               // Flag indicating that Type 4 Tag performs NDEF message update procedure.
    #define MAX_REC_COUNT      10   //< Maximum records count.
    #define TWI_INSTANCE_ID     1								/* TWI instance ID. */
    static volatile bool twi_xfer_done = false; /* Indicates if operation on TWI has ended. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID); /* TWI instance. */
    void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    	  switch (p_event->type)
            case NRF_DRV_TWI_EVT_DONE:
                twi_xfer_done = true;
    void twi_init (void)
    		ret_code_t err_code;
        const nrf_drv_twi_config_t twi_lm75b_config = {
           .scl                = 13,
           .sda                = 12,
           .frequency          = NRF_TWI_FREQ_400K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGHEST,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config,twi_handler , NULL); //
        nrf_drv_twi_enable(&m_twi);
    static void advertising_update(void)
        uint32_t      err_code;
        ble_advdata_t advdata;
        uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    	ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    	twi_init();
    	set_sensorconfigeration();
    	updateSensorData();
    	nrf_drv_twi_disable(&m_twi);
    	//nrf_drv_twi_uninit(&m_twi);
        manuf_specific_data.data.p_data = (uint8_t *) mf_Data;
        manuf_specific_data.data.size   = mf_Data_LEN;
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_FULL_NAME;
    	advdata.include_appearance   = false;
        advdata.flags                 = flags;
        advdata.p_manuf_specific_data = &manuf_specific_data;
        err_code = ble_advdata_set(&advdata, NULL);
     * @brief Callback function for handling NFC events.
    static void nfc_callback(void          * context,
                             nfc_t4t_event_t event,
                             const uint8_t * data,
                             size_t          dataLength,
                             uint32_t        flags)
        (void)context;
        switch (event)
            case NFC_T4T_EVENT_FIELD_ON:
            case NFC_T4T_EVENT_FIELD_OFF:
                m_update_state = false;
            case NFC_T4T_EVENT_NDEF_READ:
            case NFC_T4T_EVENT_NDEF_UPDATED:
                if (dataLength == 0)
                    m_update_state = true;
                else if (m_update_state == true)
     * @brief Function for creating a record in English.
    static void en_record_add(nfc_ndef_msg_desc_t * p_ndef_msg_desc)
        /** @snippet [NFC text usage_1] */
        uint32_t             err_code;
        static const uint8_t en_payload[] =
                      {'H', 'e', 'l', 'l', 'o', ' ', 'W', 'o', 'r', 'l', 'd', '!'};
        static const uint8_t en_code[] = {'e', 'n'};
        NFC_NDEF_TEXT_RECORD_DESC_DEF(en_text_rec,
                                      UTF_8,
                                      en_code,
                                      sizeof(en_code),
                                      en_payload,
                                      sizeof(en_payload));
        err_code = nfc_ndef_msg_record_add(p_ndef_msg_desc,
                                           &NFC_NDEF_TEXT_RECORD_DESC(en_text_rec));
    		bsp_board_led_on(BSP_BOARD_LED_2);
     * @brief Function for encoding the welcome message.
    static void welcome_msg_encode(uint8_t * p_buffer, uint32_t * p_len)
        NFC_NDEF_MSG_DEF(welcome_msg, MAX_REC_COUNT);
        en_record_add(&NFC_NDEF_MSG(welcome_msg));
        /** @snippet [NFC text usage_2] */
        uint32_t err_code = nfc_ndef_msg_encode(&NFC_NDEF_MSG(welcome_msg),
                                                p_buffer,
                                                p_len);
    void nfc_init()
    		uint32_t err_code;
    	  /* Set up NFC */
        err_code = nfc_t4t_setup(nfc_callback, NULL);
        /* Provide information about available buffer size to encoding function */
        uint32_t len = sizeof(m_ndef_msg_buf);
    	 /* Encode welcome message */
        welcome_msg_encode(m_ndef_msg_buf, &len);
        /* Run Read-Write mode for Type 4 Tag platform */
        err_code = nfc_t4t_ndef_rwpayload_set(m_ndef_msg_buf, sizeof(m_ndef_msg_buf));
        /* Start sensing NFC field */
        err_code = nfc_t4t_emulation_start();
    	uint32_t err_code;
    	ble_stack_init();
    	gap_params_init();
    	timers_init();
    	advertising_update();
    	timers_start();
        advertising_start();
    	nfc_init();
        for (;; )
            power_manage();
    snippet of code
  • Hi.
    Could you share the project with me? I'm not able to compile and debug your code snippet.
    Andreas
  • err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config,twi_handler , NULL); //
    I have Tested my code whenever  I comment above nfc works properly but when I used above then its behavior not properly.
  • Hi.
    Could you please share your project with me? And describe in details how I can reproduce the issue?
    So that I can debug it?
    Andreas
