Is it possible get the network UTC time from the LTE-modem? Possibly using AT commands.
I would also like to know if this is in the recent firmware update tesc. If not, is there a simple ntp example to look at for us to get the time?
tesc The user guide doesn't say anything about the clock being syncrhonized with the network. I was also told by support that you need to set the clock before you can start querying it. In other words, it is not auomatically set from the network. What is the best way to set the clock in an automated way the first time (assuming that support is correct)?
edit; here is the link to the user guide infocenter.nordicsemi.com/.../nrf91_at_commands_v0.9.1.pdf
I see that there are some unanswered questions in this thread.
The up-to-date answer to the original question is that AT+CCLK was added (modem firmware v1.0.x), and the time provided by the read command is based on network time if available. Not all network provide the time information, and the accuracy of the time also depend on the network. When time is not provided from the network, you must get the time by other means.
There is also the proprietary AT%CCLK command, which is similar, introduced in v1.1.x.
For details, please consult the nRF91 AT Commands documentation.
Regarding other methods to source time, please search other DevZone threads and create a new question for that specifically if you do not find an existing thread on the subject.
Terje
we are using the "AT%CCLK?" at it works very nice.
but now for the challange... since the modem is synchronized with the LTE network and sends on the designated time slot, the modem knows the time in accuracy better than 1msec.
will it be possible to get a synchronization pulse once a complete second ellapses? similar to how the GPS works with PPS
that is:
1. send AT%CCLK2?
2. wait for a pulse on a hardware pin GPIO (or an internal signal)
3. get the string with [sec] resolution as we get from the "AT%CCLK?" command
Does NORDIC support something like this?
This will eliminate the need for GPS if the GPS is used only for accurate time reception
Many thanks
Ohad.
