How to use serial port to show the RAM and modify the RAM start value in macOS?
I want to add a new ble service in hrs example(sdk15.3),I build and run the hrs example.and then I open the terminal emulator, but I can't find anything.I try to click the option"connect /dev/tty/usbserial",but makes nothing.How can I get something like this?(
<warning> nrf_sdh_ble: Insufficient RAM allocated for the SoftDevice.
<warning> nrf_sdh_ble: Change the RAM start location from 0x20002B90 to 0x20002B98.
<warning> nrf_sdh_ble: Maximum RAM size for application is 0xD468.
<error> nrf_sdh_ble: sd_ble_enable() returned NRF_ERROR_NO_MEM.
because if I don't change the RAM, I won't find any service by bluetooth.
  • Could you upload your project? That way I can debug it and try to help you figure out what is wrong. If you do not want to upload in public, I can convert the case into a private one.
  • hi,Holmefjord
    first,I'm sorry I was missing your message. and then I changed my tutorial(I'm using Infocenter Guide), now I'm adding dfu_buttonless service in UART service. and I receive the warning like this:
     nrf_sdh_ble: Change the RAM start location from 0x20002A98 to 0x20002AA8.
     nrf_sdh_ble: Maximum RAM size for application is 0x3D558.
     app: ERROR 4 [NRF_ERROR_NO_MEM] at /Users/zz/Desktop/stage5a/heatzy_pilote/BLE_Projects/nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_uart/main.c:508
    PC at: 0x0002EC1B
    and then
    I changed my section placement marcos by the warning:
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x100000
    RAM_PH_START=0x20000000
    RAM_PH_SIZE=0x40000
    FLASH_START=0x26000
    FLASH_SIZE=0xda000
    RAM_START=0x20002aa8
    RAM_SIZE=0x3d558
    and then I "build and run" in order to get the output.hex.After this,I make the setting file and mix the settings.hex,app.hex,softdevice.hex and bootloader.hex by using the code below:
    nrfutil settings generate --family NRF52840 --application app.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 settings.hex
    mergehex --merge bootloader.hex s140_nrf52_6.1.1_softdevice.hex --output production_final1.hex
    mergehex --merge production_final1.hex app.hex --output production_final2.hex
    mergehex --merge production_final2.hex settings.hex --output production_final.hex
    nrfjprog --eraseall -f NRF52
    nrfjprog -f NRF52 --program "production_final.hex" --verify
    nrfjprog --reset -f NRF52
    finally I can connect the nrf52840 which is named "UART service" by my phone,but I can only find that there is only a service named UART service,I can't find the dfu service,what should I do?(my code main.c and sdk_config.h are in attachment).and about other change is just add the dfu files,define them and add the path.
    best regards,
    zhong
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_dfu_ble_svci_bond_sharing.h"
    #include "nrf_svci_async_function.h"
    #include "nrf_svci_async_handler.h"
    #include "ble_dfu.h"
    #include "nrf_power.h"
    #include "nrf_bootloader_info.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define m_ready_for_reset               1
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
    //zz add
    static void ble_dfu_buttonless_evt_handler(ble_dfu_buttonless_evt_type_t event)
        switch (event)
            case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
                NRF_LOG_INFO("Device is preparing to enter bootloader mode\r\n");
            case BLE_DFU_EVT_BOOTLOADER_ENTER:
                NRF_LOG_INFO("Device will enter bootloader mode\r\n");
            case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
                NRF_LOG_ERROR("Device will enter bootloader mode\r\n");
                NRF_LOG_INFO("Unknown event from ble_dfu.\r\n");
    static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_DFU:
                NRF_LOG_INFO("Power management wants to reset to DFU mode\r\n");
                // Change this code to tailor to your reset strategy.
                // Returning false here means that the device is not ready to jump to DFU mode yet.
                // Here is an example using a variable to delay resetting the device:
                if (!m_ready_for_reset)
                     return false;
                // Implement any of the other events available from the power management module:
                //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
                //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
                //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
                return true;
        NRF_LOG_INFO("Power management allowed to reset to DFU mode\r\n");
        return true;
    //zz
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
        ble_dfu_buttonless_init_t dfus_init =
            .evt_handler = ble_dfu_buttonless_evt_handler
        err_code = ble_dfu_buttonless_init(&dfus_init);
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    6116.sdk_config.h
  • Did you check with another phone, to make sure that your phone did not cache services from previous connections?
  • hi,Holmefjord
    yes,I checked it, in fact,when I erase the nrf52840 and finish "bulid and run" the project,The led1 on nrf52840 starts to blinky, and I can find the bluetooth named"nordic_uart" directly. and there is only the uart service.and then I mixed it with bootloader,setttings and softdevice.There is also the UART service only
    here is the change I add(by Infocenter Guide):
    1.Add source file
    Add a folder nRF_DFU to the project and add the following files:
    <sdk>\components\ble\ble_services\ble_dfu\ble_dfu.c
    <sdk>\components\ble\ble_services\ble_dfu\ble_dfu_bonded.c
    <sdk>\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c
    <sdk>\components\libraries\bootloader\dfu\nrf_dfu_svci.c
    ../../../../../../components/libraries/bootloader
    ../../../../../../components/libraries/bootloader/ble_dfu
    ../../../../../../components/libraries/bootloader/dfu
    ../../../../../../components/libraries/svc
    2.Add macro switch
    Find Preprocessor Definitions in the Project Configuration window and add the following items:
    NRF_DFU_SVCI_ENABLED
    NRF_DFU_TRANSPORT_BLE=1
    BL_SETTINGS_ACCESS_ONLY
    3.Configuring sdk_config
    In sdk_config.h, make the following changes:
    BLE_DFU_ENABLED = 1
    NRF_SDH_BLE_VS_UUID_COUNT += 1
    4.Add header file
    Add the following header file to main.c:
    5. add codes in main.c
    5.1 define m_ready_for_reset
    5.2 Implement the DFU event handler
        switch (event)
    5.3 Enabling power management auto shutdown retry
    #ifndef NRF_PWR_MGMT_CONFIG_AUTO_SHUTDOWN_RETRY
    #define NRF_PWR_MGMT_CONFIG_AUTO_SHUTDOWN_RETRY 1
    5.4 Implement the power management
        switch (event)
                     return false;
                return true;
        return true;
    5.5 Initializing the Buttonless Secure DFU Service(add the code in fonction service_init)
    and then I allocate the RAM and mix the files,as the problem I had shown,I can connect the nrf52840 if I simplely click"build and run"(just find 1 service:UART),and if I run the mixed file,The result is the same,There is only a UART service.Which step is wrong?Looking forward to your reply.
    best regards,
    zhong
  • I can't see any obvious issues. Did you receive any error codes when running the code? Have you tried debugging it, to see if the dfu_service init functions are being called?
