scanning and decryption of data
I had two nRF52832 where one broadcasts with encrypted data of advertising beacon info and another nRF52832 should only scan without connecting and should decrypt the data of beacon which is broadcasting.
for that what should i do?
please give me any sample code if available
  • Hi Simon,
    I had done the encryption part as given in this link
    Encryption code:
    #include <stdint.h>
    #include <string.h>
    #include "ble_advertising.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "nrf_soc.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_sdm.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_tps.h"
    #include "ble_ias.h"
    #include "ble_lls.h"
    #include "ble_bas.h"
    #include "ble_conn_params.h"
    #include "ble_conn_state.h"
    #include "sensorsim.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_delay.h"
    #include "app_timer.h"
    #include "ble_ias_c.h"
    #include "app_util.h"
    #include "bsp_btn_ble.h"
    #include "ble_db_discovery.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "fds.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_lesc.h"
    #include "nrf_ble_qwr.h"
    //#include "nrf_ble_scan.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_fstorage.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                     "NORDIC"
    #define APP_BLE_OBSERVER_PRIO           3
    #define APP_BLE_CONN_CFG_TAG            1
    #define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(120000)
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(500, UNIT_1_25_MS)
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(1000, UNIT_1_25_MS)
    #define SLAVE_LATENCY                   0
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)
    #define APP_ADV_INTERVAL                40
    #define APP_ADV_TIMEOUT_IN_SECONDS      80
    #define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)
    #define APP_ADV_DURATION                18000
    #define BLE_ADV_DIRECTED_ENABLED        true
    #define BLE_ADV_DIRECTED_DISABLED       false
    #define BLE_ADV_DIRECTED_SLOW_ENABLED   true
    #define BLE_ADV_DIRECTED_SLOW_DISABLED  false
    #define BLE_ADV_FAST_ENABLED            true
    #define BLE_ADV_FAST_DISABLED           false
    #define BLE_ADV_SLOW_ENABLED            true
    #define BLE_ADV_SLOW_DISABLED           false
    #define BLE_ADV_WHITELIST_ENABLED       true
    #define BLE_ADV_WHITELIST_DISABLED      false
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3
    #define SEC_PARAM_BOND                  1
    #define SEC_PARAM_MITM                  0
    #define SEC_PARAM_LESC                  0
    #define SEC_PARAM_KEYPRESS              0
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE
    #define SEC_PARAM_OOB                   0
    #define SEC_PARAM_MIN_KEY_SIZE          7
    #define SEC_PARAM_MAX_KEY_SIZE          16
    #define BLE_GAP_ADV_TYPE_ADV_IND          0x00
    #define BLE_GAP_ADV_TYPE_ADV_DIRECT_IND   0x01
    #define BLE_GAP_ADV_TYPE_ADV_SCAN_IND     0x02
    #define BLE_GAP_ADV_TYPE_ADV_NONCONN_IND  0x03
    #define BLE_GAP_ADDR_TYPE_PUBLIC                        0x00
    #define BLE_GAP_ADDR_TYPE_RANDOM_STATIC                 0x01
    #define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE     0x02
    #define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE 0x03
    #define INITIAL_LLS_ALERT_LEVEL         BLE_CHAR_ALERT_LEVEL_NO_ALERT
    #define TX_POWER_LEVEL                  (-8)
    #define ADC_REF_VOLTAGE_IN_MILLIVOLTS   600
    #define ADC_PRE_SCALING_COMPENSATION    6
    #define DIODE_FWD_VOLT_DROP_MILLIVOLTS  270
    #define ADC_RES_10BIT                   1024
    #define DEAD_BEEF                       0xDEADBEEF
    #define ECB_KEY_LEN            (16UL)
    #define COUNTER_BYTE_LEN       (4UL)
    #define NONCE_RAND_BYTE_LEN    (12UL)
    static uint8_t m_ecb_key[16] = {0x6E,0x88,0x90,0x8D,0x75,0xBB,0x95,0xEA,0x2C,0x65,0x93,0x01,0x43,0xF8,0x1B,0x5F};
    static uint8_t m_counter_byte[4] = {0x6F,0x88,0x99,0x84};
    // The RNG wait values are typical and not guaranteed. See Product Specifications for more info.
    #ifdef NRF51
    #define RNG_BYTE_WAIT_US       (677UL)
    #elif defined NRF52
    #define RNG_BYTE_WAIT_US       (124UL)
    #else
    #error "Either NRF51 or NRF52 must be defined."
    #define APP_BEACON_INFO_LENGTH          0x17
    #define APP_ADV_DATA_LENGTH             0x15
    #define APP_DEVICE_TYPE                 0x02
    #define APP_MEASURED_RSSI               0xC5
    #define APP_COMPANY_IDENTIFIER          0x0059
    #define APP_MAJOR_VALUE                 0x00, 0x02
    #define APP_MINOR_VALUE                 0x00, 0x02
    #define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                            0x45, 0x56, 0x67, 0x78, \
                                            0x89, 0x9a, 0xab, 0xbc, \
                                            0xcd, 0xde, 0xef, 0xf0
    #if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    #define MAJ_VAL_OFFSET_IN_BEACON_INFO   18
    #define UICR_ADDRESS                    0x10001080
    #define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
            ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
    APP_TIMER_DEF(m_battery_timer_id);
    BLE_TPS_DEF(m_tps);
    BLE_IAS_DEF(m_ias, NRF_SDH_BLE_TOTAL_LINK_COUNT);
    BLE_LLS_DEF(m_lls);
    BLE_BAS_DEF(m_bas);
    BLE_IAS_C_DEF(m_ias_c);
    NRF_BLE_GATT_DEF(m_gatt);
    NRF_BLE_QWR_DEF(m_qwr);
    BLE_ADVERTISING_DEF(m_advertising);
    BLE_DB_DISCOVERY_DEF(m_ble_db_discovery);
    static volatile bool m_is_high_alert_signalled;
    static volatile bool m_is_ias_present = false;
    static nrf_saadc_value_t adc_buf[2];
    static ble_uuid_t m_adv_uuids[] =
        {BLE_UUID_IMMEDIATE_ALERT_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_TX_POWER_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_LINK_LOSS_SERVICE, BLE_UUID_TYPE_BLE}
    static ble_gap_adv_params_t m_adv_params;
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
    static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
    static uint8_t              m_enc_scandata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_scandata,
    static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =
        APP_DEVICE_TYPE,
        APP_ADV_DATA_LENGTH,
        APP_BEACON_UUID,
        APP_MAJOR_VALUE,
        APP_MINOR_VALUE,
        APP_MEASURED_RSSI
    static void on_ias_evt(ble_ias_t * p_ias, ble_ias_evt_t * p_evt);
    static void on_lls_evt(ble_lls_t * p_lls, ble_lls_evt_t * p_evt);
    static void on_ias_c_evt(ble_ias_c_t * p_lls, ble_ias_c_evt_t * p_evt);
    static void on_bas_evt(ble_bas_t * p_bas, ble_bas_evt_t * p_evt);
    static void advertising_init(void);
    static void advertising_start(bool erase_bonds);
    static void service_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(false);
    void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
            nrf_saadc_value_t adc_result;
            uint16_t          batt_lvl_in_milli_volts;
            uint8_t           percentage_batt_lvl;
            uint32_t          err_code;
            adc_result = p_event->data.done.p_buffer[0];
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
            batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                      DIODE_FWD_VOLT_DROP_MILLIVOLTS;
            percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
            err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(err_code);
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_ias_c_on_db_disc_evt(&m_ias_c, p_evt);
    static void adc_configure(void)
        ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
        nrf_saadc_channel_config_t config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
        err_code = nrf_drv_saadc_channel_init(0, &config);
        err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
        err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
    static void battery_level_meas_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        ret_code_t err_code;
        err_code = nrf_drv_saadc_sample();
    static void timers_init(void)
        err_code = app_timer_init();
        err_code = app_timer_create(&m_battery_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    battery_level_meas_timeout_handler);
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_KEYRING);
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
                break; // BLE_ADV_EVT_FAST
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
                break; // BLE_ADV_EVT_IDLE
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
        uint32_t      err_code;
        ble_advdata_t advdata;
        ble_advdata_t scandata;
        uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
        ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
        uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
        uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
        uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
        m_beacon_info[index++] = MSB_16(major_value);
        m_beacon_info[index++] = LSB_16(major_value);
        m_beacon_info[index++] = MSB_16(minor_value);
        m_beacon_info[index++] = LSB_16(minor_value);
        manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
        manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_NO_NAME;
        advdata.flags                 = flags;
        advdata.p_manuf_specific_data = &manuf_specific_data;
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        m_adv_params.p_peer_addr     = NULL;
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.duration        = 0;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        memset(&scandata, 0, sizeof(scandata));
        scandata.name_type             = BLE_ADVDATA_FULL_NAME;
        scandata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        scandata.uuids_complete.p_uuids  = m_adv_uuids;
        ble_gap_addr_t gap_address;
        gap_address.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC;
        memcpy(&gap_address.addr, "\xee\xdd\xcc\xbb\xaa\xAC", sizeof(gap_address.addr));
        err_code = sd_ble_gap_addr_set(&gap_address);
        err_code = ble_advdata_encode(&scandata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
        if (erase_bonds == true){
            delete_bonds();
            err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    void nonce_generate(uint8_t * p_buf)
        uint8_t i         = COUNTER_BYTE_LEN;
        uint8_t remaining = NONCE_RAND_BYTE_LEN;
        while(0 != remaining)
            uint32_t err_code;
            uint8_t  available = 0;
            err_code = sd_rand_application_bytes_available_get(&available);
            available = ((available > remaining) ? remaining : available);
            if (0 != available)
    	        err_code = sd_rand_application_vector_get((p_buf + i), available);
    	        i         += available;
    	        remaining -= available;
    	    if (0 != remaining)
    	        nrf_delay_us(RNG_BYTE_WAIT_US * remaining);
    static bool m_initialized = false;
    static nrf_ecb_hal_data_t m_ecb_data;
    void ctr_init(const uint8_t * p_nonce, const uint8_t * p_ecb_key)
        m_initialized = true;
        // Save the key.
        memcpy(&m_ecb_data.key[0], p_ecb_key, ECB_KEY_LEN);
        // Copy the nonce.
        memcpy(&m_ecb_data.cleartext[COUNTER_BYTE_LEN],
    	          &p_nonce[COUNTER_BYTE_LEN],
    	          NONCE_RAND_BYTE_LEN);
        // Zero the counter value.
        memset(&m_ecb_data.cleartext[0], 0x00, COUNTER_BYTE_LEN);
    static uint32_t crypt(uint8_t * buf)
        uint8_t  i;
        uint32_t err_code;
        if (!m_initialized)
        err_code = sd_ecb_block_encrypt(&m_ecb_data);
        if (NRF_SUCCESS != err_code)
    	    return err_code;
        for (i=0; i < ECB_KEY_LEN; i++)
    	    buf[i] ^= m_ecb_data.ciphertext[i];
        // Increment the counter.
        (*((uint32_t*) m_ecb_data.cleartext))++;
        return NRF_SUCCESS;
    uint32_t ctr_encrypt(uint8_t * p_clear_text)
        return crypt(p_clear_text);
    uint32_t ctr_decrypt(uint8_t * p_cipher_text)
        return crypt(p_cipher_text);
    ///**@brief Function for initializing the Advertising functionality.
    // * @details Encodes the required advertising data and passes it to the stack.
    // *          Also builds a structure to be passed to the stack when starting advertising.
    //static void advertising_init(void)
    //    ret_code_t             err_code;
    //    ble_advertising_init_t init;
    //    memset(&init, 0, sizeof(init));
    //    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    //    init.advdata.include_appearance      = true;
    //    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    //    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    //    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    //    init.config.ble_adv_fast_enabled  = true;
    //    init.config.ble_adv_fast_interval = APP_ADV_INTERVAL;
    //    init.config.ble_adv_fast_timeout  = APP_ADV_DURATION;
    //    init.evt_handler = on_adv_evt;
    //    err_code = ble_advertising_init(&m_advertising, &init);
    //    APP_ERROR_CHECK(err_code);
    //    ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG);
    static void qwr_init(void)
        nrf_ble_qwr_init_t qwr_init_obj = {0};
        qwr_init_obj.error_handler = nrf_qwr_error_handler;
        err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
    static void tps_init(void)
        ble_tps_init_t tps_init_obj;
        memset(&tps_init_obj, 0, sizeof(tps_init_obj));
        tps_init_obj.initial_tx_power_level = TX_POWER_LEVEL;
        tps_init_obj.tpl_rd_sec = SEC_JUST_WORKS;
        err_code = ble_tps_init(&m_tps, &tps_init_obj);
    static void ias_init(void)
        ble_ias_init_t ias_init_obj;
        memset(&ias_init_obj, 0, sizeof(ias_init_obj));
        ias_init_obj.evt_handler  = on_ias_evt;
        ias_init_obj.alert_wr_sec = SEC_JUST_WORKS;
        err_code = ble_ias_init(&m_ias, &ias_init_obj);
    static void lls_init(void)
        ble_lls_init_t lls_init_obj;
        // Initialize Link Loss Service
        memset(&lls_init_obj, 0, sizeof(lls_init_obj));
        lls_init_obj.evt_handler         = on_lls_evt;
        lls_init_obj.error_handler       = service_error_handler;
        lls_init_obj.initial_alert_level = INITIAL_LLS_ALERT_LEVEL;
        lls_init_obj.alert_level_rd_sec = SEC_JUST_WORKS;
        lls_init_obj.alert_level_wr_sec = SEC_JUST_WORKS;
        err_code = ble_lls_init(&m_lls, &lls_init_obj);
    static void bas_init(void)
        ble_bas_init_t bas_init_obj;
        memset(&bas_init_obj, 0, sizeof(bas_init_obj));
        bas_init_obj.evt_handler          = on_bas_evt;
        bas_init_obj.support_notification = true;
        bas_init_obj.p_report_ref         = NULL;
        bas_init_obj.initial_batt_level   = 100;
        bas_init_obj.bl_rd_sec        = SEC_OPEN;
        bas_init_obj.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init_obj.bl_report_rd_sec = SEC_OPEN;
        err_code = ble_bas_init(&m_bas, &bas_init_obj);
    static void ias_client_init(void)
        ble_ias_c_init_t ias_c_init_obj;
        memset(&ias_c_init_obj, 0, sizeof(ias_c_init_obj));
        m_is_high_alert_signalled = false;
        ias_c_init_obj.evt_handler   = on_ias_c_evt;
        ias_c_init_obj.error_handler = service_error_handler;
        err_code = ble_ias_c_init(&m_ias_c, &ias_c_init_obj);
        qwr_init();
        tps_init();
        ias_init();
        lls_init();
        bas_init();
        ias_client_init();
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
        cp_init.disconnect_on_fail             = true;
        cp_init.evt_handler                    = NULL;
    static void alert_signal(uint8_t alert_level)
        switch (alert_level)
            case BLE_CHAR_ALERT_LEVEL_NO_ALERT:
                NRF_LOG_INFO("No Alert.");
                err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
                break; // BLE_CHAR_ALERT_LEVEL_NO_ALERT
            case BLE_CHAR_ALERT_LEVEL_MILD_ALERT:
                NRF_LOG_INFO("Mild Alert.");
                err_code = bsp_indication_set(BSP_INDICATE_ALERT_0);
                break; // BLE_CHAR_ALERT_LEVEL_MILD_ALERT
            case BLE_CHAR_ALERT_LEVEL_HIGH_ALERT:
                NRF_LOG_INFO("HIGH Alert.");
                err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
                break; // BLE_CHAR_ALERT_LEVEL_HIGH_ALERT
        switch (p_evt->evt_type)
            case BLE_IAS_EVT_ALERT_LEVEL_UPDATED:
                if (p_evt->p_link_ctx != NULL)
                    alert_signal(p_evt->p_link_ctx->alert_level);
                break; // BLE_IAS_EVT_ALERT_LEVEL_UPDATED
                // No implementation needed.
            case BLE_LLS_EVT_LINK_LOSS_ALERT:
                alert_signal(p_evt->params.alert_level);
                break; // BLE_LLS_EVT_LINK_LOSS_ALERT
    static void on_ias_c_evt(ble_ias_c_t * p_ias_c, ble_ias_c_evt_t * p_evt)
            case BLE_IAS_C_EVT_DISCOVERY_COMPLETE:
                // IAS is found on peer. The Find Me Locator functionality of this app will work.
                err_code = ble_ias_c_handles_assign(&m_ias_c,
                                                    p_evt->conn_handle,
                                                    p_evt->alert_level.handle_value);
                m_is_ias_present = true;
                break; // BLE_IAS_C_EVT_DISCOVERY_COMPLETE
            case BLE_IAS_C_EVT_DISCOVERY_FAILED:
                // IAS is not found on peer. The Find Me Locator functionality of this app will NOT work.
                break; // BLE_IAS_C_EVT_DISCOVERY_FAILED
            case BLE_IAS_C_EVT_DISCONN_COMPLETE:
                // Disable alert buttons
                break; // BLE_IAS_C_EVT_DISCONN_COMPLETE
            case BLE_BAS_EVT_NOTIFICATION_ENABLED:
                // Start battery timer
                err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
                break; // BLE_BAS_EVT_NOTIFICATION_ENABLED
            case BLE_BAS_EVT_NOTIFICATION_DISABLED:
                err_code = app_timer_stop(m_battery_timer_id);
                break; // BLE_BAS_EVT_NOTIFICATION_DISABLED
        ret_code_t err_code = NRF_SUCCESS;
                NRF_LOG_INFO("Disconnected.");
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                // Assign connection handle to the Queued Write module.
                err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, p_ble_evt->evt.gap_evt.conn_handle);
                // Discover peer's services.
                err_code = ble_db_discovery_start(&m_ble_db_discovery,
            } break;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_ias_c.conn_handle,
            case BSP_EVENT_KEY_0:
                if (m_is_ias_present)
                    if (!m_is_high_alert_signalled)
                        err_code =
                            ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_HIGH_ALERT);
                        err_code = ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_NO_ALERT);
                    if (err_code == NRF_SUCCESS)
                        m_is_high_alert_signalled = !m_is_high_alert_signalled;
                    else if (
                        (err_code != NRF_ERROR_RESOURCES)
                        (err_code != NRF_ERROR_NOT_FOUND)
            } break;
            case BSP_EVENT_KEY_1:
                NRF_LOG_INFO("Alert Off.");
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    ///**@brief Function for starting advertising.
    //static void advertising_start(bool erase_bonds)
    //    if (erase_bonds == true){
    //        delete_bonds();
    //        // Advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED event.
    //    else
    //        uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    static void tx_power_set(void)
        ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
        bool erase_bonds;
        uint8_t nonce[16] = {0};
        // Initialize.
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        adc_configure();
        gap_params_init();
        gatt_init();
        NRF_LOG_INFO("Unencrypted info:");
       NRF_LOG_HEXDUMP_INFO(m_beacon_info, sizeof(m_beacon_info));
        nonce_generate(nonce);
        ctr_init(nonce,m_ecb_key);
        ctr_encrypt(m_beacon_info);
        ctr_encrypt(&m_beacon_info[16]);
         NRF_LOG_INFO("Encrypted info:");
        m_ecb_data.cleartext[0] = 0x00;
        m_ecb_data.cleartext[1] = 0x00;
        m_ecb_data.cleartext[2] = 0x00;
        m_ecb_data.cleartext[3] = 0x00;
            // Decrypt the ciphertext with the same counter value, i.e. 0x00,0x00,0x00,0x00, that was used for encrypting.
        ctr_decrypt(m_beacon_info);
        ctr_decrypt(&m_beacon_info[16]);
        NRF_LOG_INFO("Decrypted info:");
        advertising_init();
        db_discovery_init();
        services_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("Proximity example started.");
        advertising_start(erase_bonds);
        tx_power_set();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    and same i wrote for the decryption part for central i am not receiving the values that are encrypted in the peripheral
    Decryption code:
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "app_uart.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_nus_c.h"
    #define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
    #define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
    #define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
    #ifdef NRF51
    #elif defined NRF52
    #else
    BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE Nordic UART Service (NUS) client instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
    NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    /**@brief NUS UUID. */
    static ble_uuid_t const m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for starting scanning. */
    static void scan_start(void)
        ret_code_t ret;
        ret = nrf_ble_scan_start(&m_scan);
        APP_ERROR_CHECK(ret);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch(p_scan_evt->scan_evt_id)
             case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                  err_code = p_scan_evt->params.connecting_err.err_code;
             } break;
             case NRF_BLE_SCAN_EVT_CONNECTED:
                  ble_gap_evt_connected_t const * p_connected =
                                   p_scan_evt->params.connected.p_connected;
                 // Scan is automatically stopped by the connection.
                 NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                          p_connected->peer_addr.addr[0],
                          p_connected->peer_addr.addr[1],
                          p_connected->peer_addr.addr[2],
                          p_connected->peer_addr.addr[3],
                          p_connected->peer_addr.addr[4],
                          p_connected->peer_addr.addr[5]
             } break;
             case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                 NRF_LOG_INFO("Scan timed out.");
                 scan_start();
             } break;
    /**@brief Function for initializing the scanning and setting the filters.
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        ret_code_t ret_val;
        NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
        if (p_data[data_len-1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
        if (ECHOBACK_BLE_UART_DATA)
            // Send data back to the peripheral.
            do
                ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
        static uint16_t index = 0;
        uint32_t ret_val;
        switch (p_event->evt_type)
            /**@snippet [Handling data from UART] */
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                    do
                        ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                        if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                    } while (ret_val == NRF_ERROR_RESOURCES);
                    index = 0;
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
            case APP_UART_FIFO_ERROR:
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                scan_start();
     * @brief Function for handling shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
                // Prepare wakeup buttons.
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        uint8_t uuid[26];
                err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
                NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                             p_gap_evt->conn_handle,
                             p_gap_evt->params.disconnected.reason);
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
                // Pairing not supported.
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
           case BLE_GAP_EVT_ADV_REPORT:
    				NRF_LOG_INFO("Advertise received");
    				scan_start();
    	//			nrf_gpio_pin_toggle(LED1_PIN);
    				memmove(uuid, p_gap_evt->params.adv_report.data.p_data, p_gap_evt->params.adv_report.data.len);
    				NRF_LOG_INFO("UUID: %02x%02x%02x%02x%02x%02x", uuid[9], uuid[10], uuid[11], uuid[12], uuid[13], uuid[14]);
    				NRF_LOG_INFO("TX_POWER: %02x", p_gap_evt->params.adv_report.tx_power);
    				NRF_LOG_INFO("RSSI: %02x", p_gap_evt->params.adv_report.rssi);
                                     ble_gap_addr_t  addr;
                                     memcpy(addr.addr, p_gap_evt->params.adv_report.peer_addr.addr, 6);
                                     NRF_LOG_INFO("Beacon address: %02x:%02x:%02x:%02x:%02x:%02x",
                                     p_gap_evt->params.adv_report.peer_addr.addr[5],
                                     p_gap_evt->params.adv_report.peer_addr.addr[4],
                                     p_gap_evt->params.adv_report.peer_addr.addr[3],
                                     p_gap_evt->params.adv_report.peer_addr.addr[2],
                                     p_gap_evt->params.adv_report.peer_addr.addr[1],
                                     p_gap_evt->params.adv_report.peer_addr.addr[0]);
      //                               uint8_t           batt_lvl;
     //                               NRF_LOG_INFO("battery level: %02x", p_gap_evt->params.adv_report.batt_lvl);
    		        } break;
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("ATT MTU exchange completed.");
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    /**@brief Function for initializing the GATT library. */
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in] event  Event generated by button press.
        switch (event)
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
                err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Function for initializing the Nordic UART Service (NUS) client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler = ble_nus_c_evt_handler;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    /**@brief Function for initializing buttons and leds. */
    static void buttons_leds_init(void)
        err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the nrf log module. */
    /** @brief Function for initializing the database discovery module. */
     * @details Handles any pending log operations, then sleeps until the next event occurs.
            nrf_pwr_mgmt_run();
            uint32_t err_code;
            if (0 != available)
    	        i         += available;
    	    if (0 != remaining)
        // Save the key.
        // Copy the nonce.
        memcpy(&m_ecb_data.ciphertext[COUNTER_BYTE_LEN],
        uint8_t  i;
        uint32_t err_code;
        if (!m_initialized)
    	    return err_code;
        return NRF_SUCCESS;
        // Initialize.
        log_init();
        timer_init();
        uart_init();
        buttons_leds_init();
        ble_stack_init();
        gatt_init();
        nus_c_init();
        scan_init();
        printf("BLE UART central example started.\r\n");
        NRF_LOG_INFO("BLE UART central example started.");
        scan_start();
      //  uint8_t m_beacon_info[32];
        NRF_LOG_HEXDUMP_INFO(m_ecb_data.ciphertext, sizeof(m_ecb_data.ciphertext));
        ctr_decrypt(m_ecb_data.ciphertext);
        ctr_decrypt(&m_ecb_data.ciphertext[16]);
        // Start execution.
        // Enter main loop.
        for (;;)
    please say if any changes that i need to change in this decryption code or please give me if any code if available for decryption of the info that i had encrypted in peripheral
  • Does it work? If not, could you specify which part of the encryption code that fails.
    Simon
  • Hi Simon,
    encryption works but at scanning part decryption is not working as shown in the above decryption code
    Decryption code:
    so please check the decryption code and say if any changes are needed or give me any code if available for decryption at central side
  • It is difficult to say just by looking at it. Have you tested the code yourself? Does it work? If not, what part of the decryption code does not work?
