I m using NRF52840 as a Beacon. i m using SDK15.2 ble_app_beacon.Advertising is works fine. Now i want to change advertising parameter while button pressed.
#include "app_timer.h"
#include "ble_advdata.h"
#include "bsp.h"
#include "nordic_common.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_soc.h"
#include <stdbool.h>
#include <stdint.h>
#include "ble_srv_common.h"
#include "boards.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG 1 // Tag identifying the BLE configuration.
#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(500, UNIT_0_625_MS) // iBeacon specifies an advertising interval of 100ms
#define APP_BEACON_INFO_LENGTH 0x17 // Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH 0x15 // Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE 0x02 // 0x02 refers to Beacon.
#define APP_COMPANY_IDENTIFIER 0x004C // Company identifier for Nordic Semiconductor
#define DEAD_BEEF 0xDEADBEEF // Value used as error code on stack dump
uint32_t mac_addr[];
uint8_t service_uid[17];
uint8_t *service_uid_pointer;
uint8_t m_beacon_info1[APP_BEACON_INFO_LENGTH]={0};
uint8_t serial_number[4];
uint32_t test_sno;
static ble_gap_adv_params_t m_adv_params; // Parameters to be passed to the stack when starting advertising.
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; // Advertising handle used to identify an advertising set.
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; // Buffer for storing an encoded advertising set.
/*Encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX},
.scan_rsp_data =
.p_data = NULL,
.len = 0
void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) {
/** Initializing the Advertising.**/
static void advertising_init(void) {
uint32_t err_code;
ble_advdata_t advdata;
uint32_t pin_value;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
/* Beacon Configuration*/
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
m_beacon_info1[0]=APP_DEVICE_TYPE;
m_beacon_info1[1]=APP_ADV_DATA_LENGTH;
/* service id*/
for(int i=5;i>1;i--)
m_beacon_info1[i]=*service_uid_pointer++;
pin_value = nrf_gpio_pin_read(11);
if(pin_value==0)
m_beacon_info1[6]=0x00;
nrf_gpio_pin_toggle(14);
// Aided
m_beacon_info1[6]=0xff;
// nrf_gpio_pin_clear(14);
// m_beacon_info1[6]=0x00; // Aided
m_beacon_info1[7]=0xff; //Reserved id
m_beacon_info1[8]=0xff; // reserved id
//m_beacon_info1[18]=0x20; //Major 1st byte
m_beacon_info1[18]=0x54;
m_beacon_info1[19]=0x57; //Major 2nd byte
m_beacon_info1[20]=0x4F; //Minor 1st byte
m_beacon_info1[21]=0x54;
//m_beacon_info1[21]=0x55;//Minor 2nd byte
m_beacon_info1[22]=0xC3; //Rssi @1m
manuf_specific_data.data.p_data = (uint8_t *)m_beacon_info1;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
// Initialize advertising parameters.
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY; //Filter policy
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
// m_adv_params.channel_mask[4];
// m_adv_params.channel_mask[4] = 0xA0;
m_adv_params.duration = 0; // Never time out.
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
/**Starting advertising.*/
static void advertising_start(void) {
ret_code_t err_code;
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
/* Getting MAc address*/
void device_name_get(void) {
memcpy(serial_number,(uint32_t*)0x10001084,4);
//NRF_LOG_INFO("Serial Number : %x, %x, %x, %x",serial_number[0],serial_number[1],serial_number[2],serial_number[3]);
//NRF_LOG_FLUSH();
mac_addr[0]=NRF_FICR->DEVICEADDR0;
test_sno = test_sno | (serial_number[0] <<24)|(serial_number[1] <<16)|(serial_number[2] <<8)|(serial_number[3]);
if (test_sno != 0xFFFF7FFFF)
for(int i=0;i<4;i++){
service_uid[i]=serial_number[i];
NRF_LOG_INFO("S.NO:%2X",service_uid[i]);
service_uid[i]=(uint8_t)((mac_addr[0])>>(8*i));
NRF_LOG_INFO("MAC:%2X",service_uid[i]);
service_uid_pointer=&service_uid;
/*Initializing the BLE stack.*/
static void ble_stack_init(void) {
// Configure the BLE stack.
uint32_t ram_start = 0;
// Enable BLE stack.
/** Initializing logging. */
static void log_init(void) {
/**Initializing LEDs. */
static void leds_init(void) {
ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
/**Initializing timers. */
static void timers_init(void) {
/** Initializing power management.
static void power_management_init(void) {
/*Function for handling the idle state (main loop).
*No pending log operation, then sleep until next the next event occurs.
static void idle_state_handle(void) {
if (NRF_LOG_PROCESS() == false) {
nrf_pwr_mgmt_run();
/*Main Loop */
int main(void) {
// Initialize.
nrf_gpio_cfg_input(11,GPIO_PIN_CNF_PULL_Pullup);
nrf_gpio_cfg_output(14);
log_init();
timers_init();
// leds_init();
device_name_get();
power_management_init();
ble_stack_init();
advertising_init();
nrf_drv_clock_init();
sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, BLE_GAP_TX_POWER_ROLE_ADV, 0); //Set transmission Power
// Start execution.
NRF_LOG_INFO("Beacon example started.");
advertising_start();
// Enter main loop.
for (;;) {
idle_state_handle();
*/Here is my code.I m not getting the result.Please guide me to solve this issue
