NRF9160 custom board programming issue
Hi, I have my custom board for the nrf9160 ,
I was able to program it through the built in programmer of the nrf9160 dk but I have an issue, when I connect the VDD to the VDD_GPIO by soldering a bridge the programmer does not recognize the board, where the issue can ? Thanks in advance
  • damianogiacomi said:
    I am using the segger embedded studio and when I compile the solutin and try to connect the jlink it returns this, sorry for asking but where should I use this command?
     You run this using command prompt or similar.
    The reset pin was not connected right, not it connects but it gives this hardfault exeption in the debugger
    Difficult for me to say with little information. A hard fault usually means that you are writing to an area you are not allowed in your code. What are you trying to run? Is this a sample project or your own code?
    I have a question about what should be the reset pin impedance ?
     I don't have these numbers at the moment, will ask our internal team.
    BR,
    Øyvind
     It's a standard input with an internal pull-up of about 10kOhm.
