Problem 'stopped by vector catch' in allocating RAM when I added a new ble service" (nrf52840 sdk15.3.0)
Hello,everyone
I want to add dfu service in UART example ,but when I tried to allocate the RAM,Debug terminal shows nothing,Then I set the breakpoint in nrf_sdh_ble.c and debugging,I can't enter the C file,
After I set breakpoint in main.c,I found that when debug goes to "ble_stack_init();",It will be block and I can't do anything,like the images:
1.before  debug "ble_stack_init();"
2.after  debug "ble_stack_init();"
it shows"restricted memory" in Watch,and The window "output" shows"stopped by vector catch",If I start"built and run" directly,It can succeed,but I think it doesn;t make anythings,Finally,I see maybe I can use app_error_handler_bare(), unfortunately I don't know how to use it.could you please give me some help? thanks!
best regards,
zhong
  • hello,AndreasF
    I do the thing in the infocenter guide,I add the code and set
    NRF_PWR_MGMT_CONFIG_AUTO_SHUTDOWN_RETRY 1
    and there are some errors in the image
    which files should I add?
  • Hi zhong.
    Have you added the source files and header files?
    zhong said:
    1.Add source file
    Add a folder nRF_DFU to the project and add the following files:
    <sdk>\components\ble\ble_services\ble_dfu\ble_dfu.c
    <sdk>\components\ble\ble_services\ble_dfu\ble_dfu_bonded.c
    <sdk>\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c
    <sdk>\components\libraries\bootloader\dfu\nrf_dfu_svci.c
    ../../../../../../components/libraries/bootloader
    ../../../../../../components/libraries/bootloader/ble_dfu
    ../../../../../../components/libraries/bootloader/dfu
    ../../../../../../components/libraries/svc
     Have you defined m_ready_for_reset?
    Andreas
  • hello,AndreasF,
    I try it,and then I receive the message like this:
     nrf_sdh_ble: Insufficient RAM allocated for the SoftDevice.
     nrf_sdh_ble: Change the RAM start location from 0x20002A98 to 0x20002AA8.
     nrf_sdh_ble: Maximum RAM size for application is 0x3D558.
     nrf_sdh_ble: sd_ble_enable() returned NRF_ERROR_NO_MEM.
     app: ERROR 4 [NRF_ERROR_NO_MEM] at /Users/zz/Desktop/stage5a/heatzy_pilote/BLE_Projects/nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_uart/main.c:508
    PC at: 0x0002EC1B
    so,how to change the section placement marcos?I use the soft6.1.1 and sdk 15.3.0,This is my setting(I set by the tutorial:https://devzone.nordicsemi.com/tutorials/b/getting-started/posts/adjustment-of-ram-and-flash-memory),I don't know the exact mean about FLASH_PH_START and FLASH_PH_SIZE.etc
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x100000
    RAM_PH_START=0x20000000
    RAM_PH_SIZE=0x40000
    FLASH_START=0x26000
    FLASH_SIZE=0xda000
    RAM_START=0x20002a98
    RAM_SIZE=0x3d568
    so I just change the RAM_START and RAM_SIZE?or I should also change other things like FLASH_PH_START or FLASH_START. Look forward to your reply.
    best regards,
    zhong
  • hello,AndreasF,
    I changed my section placement marcos by the warning:
    FLASH_PH_START=0x0
    RAM_PH_SIZE=0x40000
    FLASH_START=0x26000
    FLASH_SIZE=0xda000
    RAM_START=0x20002aa8
    RAM_SIZE=0x3d558
    and then I "build and run" in order to get the output.hex.After this,I make the setting file and mix the settings.hex,app.hex,softdevice.hex and bootloader.hex by using the code below:
    nrfutil settings generate --family NRF52840 --application app.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 settings.hex
    mergehex --merge bootloader.hex s140_nrf52_6.1.1_softdevice.hex --output production_final1.hex
    mergehex --merge production_final1.hex app.hex --output production_final2.hex
    mergehex --merge production_final2.hex settings.hex --output production_final.hex
    nrfjprog --eraseall -f NRF52
    nrfjprog -f NRF52 --program "production_final.hex" --verify
    nrfjprog --reset -f NRF52
    finally I can connect the nrf52840 which is named "UART service" by my phone,but I can only find that there is only a service named UART service,I can't find the dfu service, what should I do?
    best regards,
    zhong
  • hello,AndreasF,
    I try it again, and it also only shows the UART service,could you please help me find the solution?Thanks a lot.
    best regrads,
    zhong
