How to use nRF52840-DK with an external power supply?
Now,in my application I use to power the nRF52840 with a 3.3V external supply at the VDD pin.
I want to know how to set it, I want to power the nRF52840 with a 3.3V external supply at P21.
It does not energize in this setting.
Is there a missing or unnecessary settings?
・SB36 -> shorted
・SB39 -> shorted
・SW6 -> DEFUULT
・SW8 -> ON
・SW10 -> OFF
Best Regard.
eye
    The ble image transfer demo shouldn't be dependent on the power supply.
    • Could you be more specific of what happens you execute the Github demo program?
    • Do you measure any voltage on the VDD pin?
    • What IDE are you using to program the chip?
    Best regards
    Jared
    I have two boards, so I will organize them once.
    [Settings with differences]
    • Board_A
      ・circuit :SB40 ->cut , P22 -> shorted
      (I was trying to use for comparison of voltage.I used it when I asked a question)
    •  Board_B
      ・circuit :default. it's not modified at all
      (New! I prepared to compare the action)
    [Common settings]
    • IDE: SEGGER Embedded Studio for ARM 4.16
    • SDK:nRF5 SDK ver15.3
    • program: nrf52-ble-image-transfer-demo
      => The code has been modified by the SDK version upgrade.
      (nrfx_power_clock.c -> nrfx_power.c)
    • Camera: Arducam Mini 2MP camera module (OV2640)
    • Camera's Wiring: I reference GitHub's readme.
    Q1) Could you be more specific of what happens you execute the Github demo program?
    A1) Board_A and Board_B do the same action
     [OK] VIN3-5V(3.3V)  / J2.USB connector(5V)
    1. Energize at 220mA.
    2. LED_1 Keep on flashing.
    3. Android_App can scan Board with BLE5.
    4. Android_App can connect Board with BLE5.
    5. Android_App can take camera's pictures and stream.
    [NG] P21.eternal supply(3.3V) / Coin cell battery(3.0V)
    =>  Do not energize
    Q2) Do you measure any voltage on the VDD pin?
    => No. Board_B's circuit has not been modified at all.
    However, when measuring the voltage on the Board_A, it is the same as the A1.
    Q3) What IDE are you using to program the chip?
    A3) SEGGER Embedded Studio for ARM 4.16
    Best Regards.
    eye
  • I checked additionally
     P27.Li-in connector(3.3V)
    =>  OK
    I think so, It is effective only when using 5 V power sources.
    eye
    What power source are you using when it's not working?
    =>  OK
    Does this mean that it worked with the Li-Po battery connected to P27?
    Best regards
    Jared
  • He, Sorry for the late reply.
    I usually use VIN3-5V .
    But , When measuring current,  It is not recommended.
    Yes.
    Instead of the Li-Po battery, P27 was powered by supplying 3.3 V from the regulated power supply.
    Best regards.
    eye
