which changes are require in code when use of wakeup button ?
Respected sir,
There is added external reset button at SRU532 module, and changes are given according to it using wakeup button at code.When wakeup button is used then some part is uncommented and want to reset only one pin using one button of nRF51422.It is done for reset time of BLE advertising after 3 min or within 1 hr,but it is not worked.How it will solve?
  • yes sir I checked it.But what exact changes are required in main() file
  • There is need to reopen channel of ANT to receive data then how this function reinitialize at main() ?
  • **@brief Application's Stack ANT event handler.
     * @param[in]   p_ant_evt   Event received from the stack.
    static void on_ant_evt(ant_evt_t * p_ant_evt)
    	uint32_t err_code;
        /*if (p_ant_evt->channel == ANT_HRMRX_ANT_CHANNEL)// oeration of the HRT channel
            switch (p_ant_evt->event)
                case EVENT_RX:
                    on_ant_evt_rx(p_ant_evt);
                case EVENT_CHANNEL_CLOSED:
                    on_ant_evt_channel_closed();
                    // No implementation needed.
    		if (p_ant_evt->channel == ANT_FALCOTX_ANT_CHANNEL) // operation of the falco-motor channel
    						case EVENT_TX: // if transmisson
                     //channel_event_handle(event); // boradcast the Hx_M motor  data
    									on_ant_evt_tx(p_ant_evt);
                case EVENT_RX:
    						err_code = sd_ant_channel_open(ANT_FALCOTX_ANT_CHANNEL); // open the Motor CH0
       else if (p_ant_evt->channel == ANT_FALCOTTX_ANT_CHANNEL) // operation of the falco-motor channel
                     //channel_event_handle(event); // boradcast the Hx_M TS sensor data
                case EVENT_RX:
    								err_code = sd_ant_channel_open(ANT_FALCOTTX_ANT_CHANNEL);// open the TS CH1
