Writing data to UICR region and flashing device
I'm trying to accomplish two things:
1. Write 2 values to the UICR (2 arrays actually - a serial number and encryption keys).
2. Flash the device in such a way that the information in UICR is preserved.
My questions:
1. Whats the UICR address range? (Based on the  NRF SDK, the UICR base address is 0x10001000UL). The reason I ask is because I can see in the fstorage example that you can specify the start and end addresses of the flash region to reserve for your purposes. In my case I would like to reserve memory starting from  the UICR address base. What's the recommended address range to use?
2. Using nrfjprog, I can specify which areas of flash to erase and keep UICR, by specifying the start and end address of the regions I want to erase. Would it make sense to simply specify the address range as 00000000 - 000ffffff (this is the entire flash) memory range. If I specify this range, would the programmer wipe everything except UICR data (if i specify the --sectorerase option)? I can see from my current application that it lies in the address range 00000000 - 00012b07.
Any reccommendations on what address range to specify to erase?
For now I'm trying to accomplish this without SoftDevice enabled.
Thanks (I'm a bit new to memory management) :)
    1. The module is intended for managing NV memory storage in the FLASH region (0x0 - 0x80000). You can probably use fstorage to write data to the UICR if you don't use the softdevice backend (ie. can only be used while the softdevice is disabled). Since the UICR is intended for one-time configurations like serial numbers,etc., I don't think fstorage is worth the overhead.
    2. UICR can be read it like any other register. E.g.,
    uint32_t serial_number;
    serial_number = NRF_UICR->CUSTOMER[x];
  • Thanks Vidar! Both approaches work just fine.
    I definitely see your point where the fstorage can be overhead, but it's overhead I can afford because I also plan to write other kinds of data, and fstorage provides a fairly more "controlled" way of writing/reading.
    Thanks again. I have enough to keep me going Slight smile
