52832 PWM delay
I use timer+ppi+pwm model.my init code like this
void PWM_init()
/* ƵµÀµÄ PWM, 200Hz£¨5000us=5ms), ͨ¹ý ¿ª·¢°åLED ¹Ü½ÅÊä³ö. */
	app_pwm_config_t pwm0_cfg = APP_PWM_DEFAULT_CONFIG_1CH(250L, PWM_PIN);
	/* Çл»ÆµµÀµÄ¼«ÐÔ */
	pwm0_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
	/* ³õʼ»¯ºÍʹÄÜPWM. */
	err_code = app_pwm_init(&PWM0,&pwm0_cfg,pwm_ready_callback);
	app_pwm_enable(&PWM0);//ʹÄÜPWM
	while (app_pwm_channel_duty_set(&PWM0, 0, 50) == NRF_ERROR_BUSY);
I use some code to close and open PWM ,like this
void PWM_stop()
    app_pwm_disable(&PWM0);
void PWM_start()
question:I use oscilloscopes to check PWM, I find that when I start PWM,I must to wait about 260us before 52832 product PWM.
                 why I need to wait 260us?
  • #include <stdbool.h>
    #include <stdint.h>
    #include "nrf.h"
    #include "app_error.h"
    #include "bsp.h"
    #include "nrf_delay.h"
    #include "app_pwm.h"
    APP_PWM_INSTANCE(PWM0,1);                   // ´´½¨Ò»¸öʹÓö¨Ê±Æ÷1²úÉúPWM²¨µÄʵÀý
    static volatile bool ready_flag;            // ʹÓÃÒ»¸ö±ê־λ±íʾPWM״̬
    void pwm_ready_callback(uint32_t pwm_id)    // PWM»Øµ÷¹¦ÄÜ
        ready_flag = true;
    void ADC_PWM_START(void)
    	nrf_gpio_pin_set(16);
    void ADC_PWM_STOP(void)
    	nrf_gpio_pin_clear(16);
        ret_code_t err_code;
        /* 2-¸öƵµÀµÄ PWM, 200Hz£¨5000us=5ms), ͨ¹ý ¿ª·¢°åLED ¹Ü½ÅÊä³ö. */
        app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(250, 26);
        /* Çл»Á½¸öƵµÀµÄ¼«ÐÔ */
        pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
        err_code = app_pwm_init(&PWM0,&pwm1_cfg,NULL);
    		/* ÉèÖÃÕ¼¿Õ±È - ²»Í£ÉèÖÃÖ±µ½PWM×¼±¸ºÃ. */
    		while (app_pwm_channel_duty_set(&PWM0, 0, 0) == NRF_ERROR_BUSY);
    		/* µÈ´ý»Øµ÷ */
    		nrf_delay_ms(25);
    		nrf_gpio_cfg_output(16);
        while(true)
    				nrf_delay_ms(1);
    				ADC_PWM_STOP();
    				nrf_delay_ms(1);
            ADC_PWM_START();
    my code like this.it's diferent with your.please test my code on your circuit.thaks
    The added delay is a result of the prolonged period. You can see this yourself by reducing the period to 10 for example.It should then take shorter time for the signal to be produced on the GPIO. It's not a delay per se, but a consequence of a bigger period.
    Jared
  • sorry,I dont kown what you mean to reduce the period to 10.
    Sorry, I meant if you decrease the period to 10 µs from 50 µs, you will see that the "delay" between the function call and the produced signal is decreased.
    You should also modify your code before testing to easier highlight the difference. Initializing of the pin and the delay should either be removed to an earlier point in the code or removed.
    Best regards
    Jared
  • "decrease the period to 10 µs from 50 µs" is meant to modify this code "while (app_pwm_channel_duty_set(&PWM0, 0, 50) == NRF_ERROR_BUSY);" is right?
    but I cant found the "delay" is decreased.
