Get connected device name in Generic Access Service from ble central
Hi all,
I would like to get the complete name from the connected peripheral by reading the device name characteristic (0x2A00) in the Generic Access Service (0x1800). I am using SDK 15.2.0 with soft device s132 v6.1.1.
I have tried to call sd_ble_gattc_char_value_by_uuid_read in BLE_GAP_EVT_CONNECTED event, and then get the device name through p_ble_evt->evt.gattc_evt.params.char_val_by_uuid_read_rsp.handle_value in BLE_GATTC_EVT_CHAR_VAL_BY_UUID_READ_RSP event. But it never runs inside the event BLE_GATTC_EVT_CHAR_VAL_BY_UUID_READ_RSP.  I have tested another way by using p_ble_evt->evt.gatts_evt.params.write.data but it didn't get the device name.
So I would like to know how I can do that.
Many thanks in advance.
  • Hi Andy,
    I have put the code in "db_disc_handler" and BLE_GATTC_EVT_READ_RSP event; sd_ble_gattc_read() is also called inside "db_disc_handler". But I see only the log line "Found GAP profile service". "Found device name characteristic" and "Read length: Read offset: " do not appear.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
        if ((p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE) &&
                (p_evt->params.discovered_db.srv_uuid.uuid == BLE_UUID_NUS_SERVICE) &&
                (p_evt->params.discovered_db.srv_uuid.type == NUS_SERVICE_UUID_TYPE))
                    NRF_LOG_INFO("Found GAP profile service");
                    // Find the CCCD Handles of the device name characteristic
                    for (uint8_t i = 0; i < p_evt->params.discovered_db.char_count; i++)
                        if ((p_evt->params.discovered_db.charateristics[i].characteristic.uuid.uuid == BLE_UUID_GAP_CHARACTERISTIC_DEVICE_NAME) &&
    			(p_evt->params.discovered_db.charateristics[i].characteristic.uuid.type == BLE_UUID_TYPE_BLE))
    			NRF_LOG_INFO("Found device name characteristic");
    			device_name_handle = p_evt->params.discovered_db.charateristics[i].characteristic.handle_value;
    			// Break out of for loop
         ret_code_t err_code;
         err_code = sd_ble_gattc_read(p_evt->conn_handle, device_name_handle, 0);
         if (err_code != NRF_ERROR_BUSY)
    case BLE_GATTC_EVT_READ_RSP:
                uint8_t device_name[50];
                uint8_t device_name_length;
                ble_gattc_evt_read_rsp_t const * p_read_rsp = &p_ble_evt->evt.gattc_evt.params.read_rsp;
                NRF_LOG_INFO("Read length: %d, Read offset: %d", p_read_rsp->len, p_read_rsp->offset);
                // We are reading the device name
                if (p_read_rsp->handle == device_name_handle)
    		for (uint8_t i = 0; i < p_read_rsp->len; i++)
    			device_name[i + p_read_rsp->offset] = p_read_rsp->data[i];
    		device_name_length = p_read_rsp->len + p_read_rsp->offset;
    	} break;
  • The reason this won't work is because you are looking for the device name characteristic inside the NUS service. The device name characteristics lies inside the generic access service. I tried to check for p_evt->params.discovered_db.srv_uuid.uuid == 0x1800 but never got any hit, and I am not sure why.
    I tried to get sd_ble_gattc_char_value_by_uuid_read() to work, and have partly succeeded. I called it inside case BLE_GATTC_EVT_WRITE_RSP (Then the call to ble_nus_c_tx_notif_enable--> cccd_configure()-->sd_ble_gattc_write() has completed and I won't receive NRF_ERROR_BUSY) and I successfully received the event BLE_GATTC_EVT_CHAR_VAL_BY_UUID_READ_RSP. However, I haven't been able to get the data yet. But I think you have to use the function sd_ble_gattc_evt_char_val_by_uuid_read_rsp_iter().
    If you don't figure it out, please ask, and I will look into it.
    Simon
  • Hi Simon,
    Thank you for your reply. I will try later and give feedback.
    I think I must discover all services, then discover service characteristics inside 1800 uuid, and finally read the characteristic value of 2A00 uuid.
