I am having an issue migrating some code over from Keil to an example in SES studio.
The code in Keil is simply listening for a radio packet, when it receives it, it transmits a message over the serial port. I did this "bare metal" by just programming registers, no issues. There is simply a radio_setup() function as well as the standard void RADIO_IRQHandler(void) function.
I am moving over to SES starting with the usbd_cdc_adm_pca10056 example as I would like to spit these messages out over USB, not serial. The usb code works fine.
Now, when I put in the radio_setup() function and void RADIO_IRQHandler(void) into the SES code, the interrupt will not trigger. I cant seem to figure out why.
So far I have stepped through the code to make sure the radio registers are being configured, it is working. I have also verified that there are packets for the radio to capture (have another pca10056 next to it running the Keil version). So there is something with the SES code that is causing the problem. Any suggestions?
Thanks
