Error during build of nRF9160 samples
Hi!
I'm having issues compiling the nRF9160 samples in the SDK. I've followed the Getting Started Assistant. I'm currently on the master branch. When I check out the v3 tag it doesn't have the west.yml file, so I can't do `west update`.
Anyways, my build stops at `GEN_ABSOLUTE_SYM` in `gen_offset.h`. I get the same build error for the spm sample as well as the at_client sample.
Complete output log from SES:
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_macros.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
1> Compiling ‘offsets.c’
1> In file included from C:/Dev/nrfconnectsdk/zephyr/include/toolchain.h:21:0,
1>                  from C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:74,
1>                  from C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:25:
1> C:/Dev/nrfconnectsdk/zephyr/include/toolchain/gcc.h:322:1: warning: multi-line comment [-Wcomment]
1> In file included from C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:25:0:
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:2: warning: implicit declaration of function 'GEN_ABSOLUTE_SYM'; did you mean 'GEN_OFFSET_SYM'? [-Wimplicit-function-declaration]
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:21:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___kernel_t_current_OFFSET' undeclared (first use in this function)
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: note: each undeclared identifier is reported only once for each function it appears in
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___kernel_t_nested_OFFSET' undeclared (first use in this function); did you mean '___kernel_t_current_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:22:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___kernel_t_irq_stack_OFFSET' undeclared (first use in this function); did you mean '___kernel_t_nested_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:23:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___cpu_t_current_OFFSET' undeclared (first use in this function); did you mean '___kernel_t_current_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:26:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___cpu_t_nested_OFFSET' undeclared (first use in this function); did you mean '___cpu_t_current_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:27:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___cpu_t_irq_stack_OFFSET' undeclared (first use in this function); did you mean '___kernel_t_irq_stack_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:28:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___kernel_t_idle_OFFSET' undeclared (first use in this function); did you mean '___kernel_t_nested_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:35:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___kernel_t_ready_q_OFFSET' undeclared (first use in this function); did you mean '___kernel_t_idle_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:38:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___kernel_t_arch_OFFSET' undeclared (first use in this function); did you mean '___kernel_t_idle_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:39:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___ready_q_t_cache_OFFSET' undeclared (first use in this function); did you mean '___kernel_t_arch_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:42:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> In file included from C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:27:0:
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:49:18: error: '_STRUCT_KERNEL_SIZE' undeclared (first use in this function)
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_base_t_user_options_OFFSET' undeclared (first use in this function)
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:51:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_base_t_thread_state_OFFSET' undeclared (first use in this function); did you mean '___thread_base_t_user_options_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:52:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_base_t_prio_OFFSET' undeclared (first use in this function); did you mean '___thread_base_t_user_options_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:53:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_base_t_sched_locked_OFFSET' undeclared (first use in this function); did you mean '___thread_base_t_thread_state_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:54:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_base_t_preempt_OFFSET' undeclared (first use in this function); did you mean '___thread_base_t_prio_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:55:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_base_t_swap_data_OFFSET' undeclared (first use in this function); did you mean '___thread_base_t_preempt_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:56:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_t_base_OFFSET' undeclared (first use in this function); did you mean '___ready_q_t_cache_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:58:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_t_caller_saved_OFFSET' undeclared (first use in this function); did you mean '___thread_t_base_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:59:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_t_callee_saved_OFFSET' undeclared (first use in this function); did you mean '___thread_t_caller_saved_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:60:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_t_arch_OFFSET' undeclared (first use in this function); did you mean '___thread_t_base_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:61:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_stack_info_t_start_OFFSET' undeclared (first use in this function); did you mean '___thread_t_callee_saved_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:64:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_stack_info_t_size_OFFSET' undeclared (first use in this function); did you mean '___thread_stack_info_t_start_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:65:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_t_stack_info_OFFSET' undeclared (first use in this function); did you mean '___thread_stack_info_t_size_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:67:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:78:18: error: 'K_THREAD_SIZEOF' undeclared (first use in this function); did you mean 'K_THREAD_DEFINE'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/kernel_offsets.h:81:18: error: '_DEVICE_STRUCT_SIZEOF' undeclared (first use in this function); did you mean 'K_THREAD_STACK_SIZEOF'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_arch_t_basepri_OFFSET' undeclared (first use in this function); did you mean '___thread_t_base_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:29:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___thread_arch_t_swap_return_value_OFFSET' undeclared (first use in this function); did you mean '___thread_arch_t_basepri_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:30:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___esf_t_a1_OFFSET' undeclared (first use in this function); did you mean '___thread_t_arch_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:41:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___esf_t_a2_OFFSET' undeclared (first use in this function); did you mean '___esf_t_a1_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:42:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___esf_t_a3_OFFSET' undeclared (first use in this function); did you mean '___esf_t_a2_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:43:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___esf_t_a4_OFFSET' undeclared (first use in this function); did you mean '___esf_t_a3_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:44:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___esf_t_ip_OFFSET' undeclared (first use in this function); did you mean '___esf_t_a4_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:45:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___esf_t_lr_OFFSET' undeclared (first use in this function); did you mean '___esf_t_ip_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:46:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___esf_t_pc_OFFSET' undeclared (first use in this function); did you mean '___esf_t_lr_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:47:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___esf_t_xpsr_OFFSET' undeclared (first use in this function); did you mean '___esf_t_pc_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:48:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:55:18: error: '___esf_t_SIZEOF' undeclared (first use in this function); did you mean 'K_THREAD_SIZEOF'?
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___callee_saved_t_v1_OFFSET' undeclared (first use in this function); did you mean '___esf_t_a1_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:57:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___callee_saved_t_v2_OFFSET' undeclared (first use in this function); did you mean '___callee_saved_t_v1_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:58:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___callee_saved_t_v3_OFFSET' undeclared (first use in this function); did you mean '___callee_saved_t_v2_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:59:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___callee_saved_t_v4_OFFSET' undeclared (first use in this function); did you mean '___callee_saved_t_v3_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:60:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___callee_saved_t_v5_OFFSET' undeclared (first use in this function); did you mean '___callee_saved_t_v4_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:61:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___callee_saved_t_v6_OFFSET' undeclared (first use in this function); did you mean '___callee_saved_t_v5_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:62:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___callee_saved_t_v7_OFFSET' undeclared (first use in this function); did you mean '___callee_saved_t_v6_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:63:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___callee_saved_t_v8_OFFSET' undeclared (first use in this function); did you mean '___callee_saved_t_v7_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:64:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/kernel/include/gen_offset.h:80:19: error: '___callee_saved_t_psp_OFFSET' undeclared (first use in this function); did you mean '___callee_saved_t_v8_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:65:1: note: in expansion of macro 'GEN_OFFSET_SYM'
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:69:18: error: '___callee_saved_t_SIZEOF' undeclared (first use in this function); did you mean '___callee_saved_t_psp_OFFSET'?
1> C:/Dev/nrfconnectsdk/zephyr/arch/arm/core/offsets/offsets.c:80:18: error: '_K_THREAD_NO_FLOAT_SIZEOF' undeclared (first use in this function); did you mean 'K_THREAD_STACK_SIZEOF'?
Build failed
  • Me too I had the same problem.
    I was trying to build the asset_tracker example of sdk v0.4.0 with SES 4.16 (in windows) which does NOT compile ! Getting the GEN_ABSOLUTE_SYM compile error.
    It has nothing to do with the path length.
    My solution was indeed to use the command line way given in this link.. and not use SES.
    .\zephyr\zephyr-env.cmd
    set ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    set GNUARMEMB_TOOLCHAIN_PATH=c:\gnuarmemb
    cd nrf\applications\asset_tracker
    mkdir build
    cd build
    cmake -GNinja -DBOARD=nrf9160_pca10090ns ..
    ninja
    ninja flash
    This works without problems !
    And also v 0.3.0 does not yet work with west, so the "Getting Started Assistant" from nRF Connect SW can only be used after v0.4.0.
  • Hi Marten,
    Please look at this link. Do you have the correct path in SES?
    Øyvind
  • Yes I set the correct path for gcc and zepyr base.
  • And you are still not able to use SES?
    Just a shot in the dark, but what direction is your slash in the path?
    From previous link I posted, it shows:
    C:/ncs/zephyr but this should be C:\ncs\zephyr
    Ref. this link
  • in SES, nRF Connect environment Options I indeed already used back slashes (windows style): \
    Build output:
    3> Compiling ‘socket_offload.c’
    3> C:/gnuarmemb/bin/arm-none-eabi-gcc -DBUILD_VERSION=v1.14.99-ncs1 -DKERNEL -DNRF9160_XXAA -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__LINUX_ERRNO_EXTENSIONS__ -D__ZEPHYR__=1 -ID:/ncs/zephyr/kernel/include -ID:/ncs/zephyr/arch/arm/include -ID:/ncs/zephyr/include -ID:/ncs/zephyr/include/drivers -Izephyr/include/generated -ID:/ncs/zephyr/soc/arm/nordic_nrf/nrf91 -ID:/ncs/zephyr/soc/arm/nordic_nrf/include -ID:/ncs/zephyr/ext/hal/cmsis/Include -ID:/ncs/zephyr/ext/hal/nordic/nrfx -ID:/ncs/zephyr/ext/hal/nordic/nrfx/drivers/include -ID:/ncs/zephyr/ext/hal/nordic/nrfx/hal -ID:/ncs/zephyr/ext/hal/nordic/nrfx/mdk -ID:/ncs/zephyr/ext/hal/nordic/. -ID:/ncs/zephyr/subsys/net/lib/sockets/. -ID:/ncs/nrf/include -ID:/ncs/nrf/ext/cjson/. -ID:/ncs/nrf/lib/at_cmd_parser/include -ID:/ncs/nrf/subsys/net/lib/nrf_cloud/./include -ID:/ncs/nrfxlib/bsdlib/include -ID:/ncs/nrf/applications/asset_tracker/src -ID:/ncs/nrfxlib/crypto/nrf_oberon/include -isystem C:/gnuarmemb/arm-none-eabi/include -Os -g -Wall -Wformat -Wformat-security -Wno-format-zero-length -imacros D:/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090/zephyr/include/generated/autoconf.h -ffreestanding -Wno-main -fno-common -mthumb -mcpu=cortex-m33 -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -Wno-pointer-sign -Wno-unused-but-set-variable -fno-reorder-functions -fno-defer-pop -Werror=implicit-int -Wpointer-arith -ffunction-sections -fdata-sections -mabi=aapcs -march=armv8-m.main+dsp -std=c99 -MD -MF D:/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090/zephyr\CMakeFiles\zephyr.dir\subsys\net\lib\sockets\socket_offload.c.obj.d -fno-diagnostics-show-caret -o zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/socket_offload.c.obj -c D:/ncs/zephyr/subsys/net/lib/sockets/socket_offload.c
    11> In file included from D:/ncs/zephyr/include/toolchain.h:21:0,
    11>                  from zephyr/misc/generated/configs.c:7:
    11> D:/ncs/zephyr/include/toolchain/gcc.h:325:51: error: expected expression before ')' token
    11> zephyr/misc/generated/configs.c:22:1: note: in expansion of macro 'GEN_ABSOLUTE_SYM'
    11> zephyr/misc/generated/configs.c:29:1: note: in expansion of macro 'GEN_ABSOLUTE_SYM'
    Build failed
