BLE_GAP_EVT_CONNECTED event is not triggered
Hi all,
I have checked in Nordic Devzone for this query but no luck in finding solution for my query.
I am using nrf52832 and configured as central and peripheral.
my device will scan and store peer address in flash and then connect to stored address later.
when i connect to peer address using sd_ble_gap_connect it returns NRF_SUUCESS but BLE_GAP_EVT_CONNECTED  is not triggered.
this issue occurs only for some peripherals and some peripheral i can able to connect and it triggers event as well.
tested with one of the example code: when i try to connect  peripheral  device programmed with ble_app_uart code this issue occurs where  BLE_GAP_EVT_CONNECTED  is not triggered.
but the same peripheral connects successfully through my Android phone.
i am unable understand what is the issue.
Please guide...
Thanks
Rekha
  • Hi
    thank you for the support.
    If you did expect the connection to succeed you need to look at the parameters you provided to sd_ble_gap_connect()
    i want my device to connect to peripheral if it is available in advertising state. but sd_ble_gap_connect will return NRF_SUCCESS even if the device bluetooth is turned off.
    if i try to connect the same device second time it returns INVALID_STATE error which is correct result which i expected during first time connection itself.
    How to get correct status of peripheral device ?
    please guide
    Thanks
    Yes, sd_ble_gap_connect() will return NRF_SUCCESS to indicate that the scanning (which is the initial part of connection establishment for a central role) was started. You have to wait for the BLE_GAP_EVT_CONNECTED or BLE_GAP_EVT_TIMEOUT event to know if the connection was established. Therefore you should set a sensible timeout value (not 0), and that should be it.
     You will typically get INVALID_STATE returned from the call to sd_ble_gap_connect() if there is an ongoing connection attempt. If you don't use timeout (set it to 0), you always have to either wait for the BLE_GAP_EVT_CONNECTED event or call sd_ble_gap_connect_cancel() to cancel the ongoing connection attempt before you can call sd_ble_gap_connect() again. Perhaps this is what is happening in this case?
    Can you elaborate the question?
  • Hi
    i want any kind of indication if my device is not getting connected after some time . can i specify particular amount of time as wait time for connection?
    i want to wait for some time and then jump connecting to next device as per my application.
    is time out error is the only indication if connection fails ?
    Thanks
    Yes, this is the timeout parameter that you have experimented with (first setting it to 0, then to 1). This specifies the timeout in 10 ms intervals. For example:
    • 0: no timeout
    • 1: 10 ms timeout
    • 20: 200 ms timeout
     Yes.
  • Hi
    i have not achieved my requirement yet.
    is it possible to connect more than one device at a time with scan paramter timeout set to 0.
    try to connect multiple device at the same time.
    how to achieve this ?
    because if i connect first device i unable to connect next since timeout is set to 0.
    how to achieve multiple connection simultaneously having an array of MAC address with me?
    Thanks
