BLE_GAP_EVT_CONNECTED event is not triggered
Hi all,
I have checked in Nordic Devzone for this query but no luck in finding solution for my query.
I am using nrf52832 and configured as central and peripheral.
my device will scan and store peer address in flash and then connect to stored address later.
when i connect to peer address using sd_ble_gap_connect it returns NRF_SUUCESS but BLE_GAP_EVT_CONNECTED  is not triggered.
this issue occurs only for some peripherals and some peripheral i can able to connect and it triggers event as well.
tested with one of the example code: when i try to connect  peripheral  device programmed with ble_app_uart code this issue occurs where  BLE_GAP_EVT_CONNECTED  is not triggered.
but the same peripheral connects successfully through my Android phone.
i am unable understand what is the issue.
Please guide...
Thanks
Rekha
  • Hi
    That is where the risk is - if i set timeout device is not getting connected within that short span. hence i disabled timeout. suppose peripheral device is not in the vicinity, even then my device will still wait for the connection therefore i am unable to connect to next devices.
    How much time does a central requires to connect peripheral?
    Thanks
     Yes. That is why a timeout is usually sensible.
    The time depends on the advertising interval of the peripheral, and the RF environment (noise/interference), which can lead to packet loss. This is because you have to receive an advertising packed in order to connect, and then send a successful connection request. If the time between advertisement packets (advertising interval) is long, or packets are lost, it will take longer time to connect. This are all inherent properties of BLE, and not directly related to the nRF devices.
  • So the best way is to set time out to 0x20 and loop sd_ble_gap_connect().
    after one successful connection with peripheral , when central tries to connect to next peripheral will i get successful connection?
    can two peripheral devices connects to the same central in this way?
    Thanks
  • Yes. The SoftDevice support up to 20 concurrent connections, and it does not matter if it is in central or peripheral role. You have to configure it to support this many connections, though. You should set NRF_SDH_BLE_TOTAL_LINK_COUNT and NRF_SDH_BLE_CENTRAL_LINK_COUNT to whatever number you need in your projects sdk_config.h. You also need to adapt your application to actually keep track of the connections.
  • Hi Thanks for the information.
    I have already set NRF_SDH_BLE_TOTAL_LINK_COUNT = 8 and NRF_SDH_BLE_CENTRAL_LINK_COUNT = 7 and NRF_SDH_BLE_PERIPHERAL_LINK_COUNT  = 1
    and
    how do i do this?
    can you please  explain it in detail?
    thanks
