NRF_ERROR_INVALID_PARAM on ble_advertising_init(), SDK 15.3.0
I'm migrating a project from SDK 14.2.0 to SDK 15.3.0. I use gcc. I have three advertising modes and the first of them is working fine. For the second one, the same
ble_advertising_init_t that I passed to ble_advertising_init() in SDK 14.2.0 successfully no longer works with SDK 15.3.0. The only change I've made in the course of migrating SDKs is that I noticed the timeouts are now specified in 10ms units, not seconds.
Here's the code up to ble_advertising_init(). BTS_UUID_SERVICE is our custom service.
void ble_advertise_on_motion(void)
  ret_code_t err_code = 0;
  ble_advertising_init_t init;
  // As above
  ble_uuid_t adv_uuids[] = {{BTS_UUID_SERVICE, m_bts.uuid_type}};
  // As above
  init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
  init.advdata.flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED; // non-discoverable
  init.advdata.uuids_complete.uuid_cnt = 1;
  init.advdata.uuids_complete.p_uuids = adv_uuids;
  // We do NOT want connections from unbonded centrals.
  init.config.ble_adv_whitelist_enabled = true;
  // Diasabled advertising modes.
  init.config.ble_adv_directed_high_duty_enabled = false;
  init.config.ble_adv_directed_enabled = false; // Would only last for 1.28s, so useless with a low power scan.
  init.config.ble_adv_fast_enabled = false;
  // Enabled advertising modes. Directed slow advertising at first looks appropriate here, but in testing, we never get a connection from our Android app. Just use slow (undirected) advertising, which gets us an immediate connection.
  init.config.ble_adv_slow_enabled = true;
  init.config.ble_adv_slow_interval = 32; // 32 * 0.625ms = 20 ms (minimum)
  init.config.ble_adv_slow_timeout = 15 * 100; // 15s, in units of 10ms
  // As above.
  // TODO (P1): Fix. Currently throwing:
  // "E error Code 0x7 (NRF_ERROR_INVALID_PARAM), ../ble_periph.c line 1206"
I was sure there used to be decent SDM migration guides from Nordic, but I don't see one in the SDK's documentation directory. Maybe it was only for SD releases.
  • No, as the comment in the ble_advertising_init states
    // Configure a initial advertising configuration. The advertising data and and advertising
    // parameters will be changed later when we call @ref ble_advertising_start, but must be set
    // to legal values here to define an advertising handle.
    When you start advertising using ble_advertising_start, then the intervals set in  ble_advertising_init_t init struct will be used, i.e. if you call
    ble_advertising_start(&m_advertising, BLE_ADV_MODE_SLOW);
    then the following parameters will be used.
    init.config.ble_adv_slow_interval = APP_ADV_INTERVAL;
    init.config.ble_adv_slow_timeout = APP_ADV_DURATION;
    Best regards
    Bjørn
