nRFConnect App on iOS cannot do take app into DFU mode with SDK15.2
nRFConnect is behaving differently for apps on different SDK versions. I am able to do a DFU via script something similar to the one here https://thegecko.github.io/web-bluetooth-dfu/examples/web.html. The app uses SDK 15.2. However, on testing DFU via nrfConnect on iOS it doesn't work. The device doesn't enter DFU mode. The same nrfConnect app can do DFU for an app using SDK 14.2.
Has anyone observed this before?
  • You can use our bootloader in two configurations; allow DFU from unbonded devices (use ble_dfu_unbonded.c) or only allow DFU from bonded devices(use ble_dfu_bonded.c with NRF_DFU_BLE_BUTTONLESS_SUPPORTS_BONDS in the Preprocessor Definitions) . If the latter configuration is chosen, then you need to use the Peer Manager, as the bootloader uses its API to retrieve peer data( encryption keys, identity resolving keys etc).
    The Peer Manager and its dependencies is about 15kB I think. GATT table caching should only be an issue if you have bonded with the iOS device.
  • NRF_DFU_BLE_BUTTONLESS_SUPPORTS_BONDS is set to 0 and we are using ble_dfu_unbonded.c. So does this mean that peer manager is still needed for sending the service change indication?
  • No, service changed indication should only be necessary if you are bonded with the iOS device. You can initiate a Service Changed Indication through the SD API, i.e. sd_ble_gatts_service_changed()
    If you are not bonded the the Bootloader will increment the device address by one so that it appears as a "new" device
    #if (!NRF_DFU_BLE_REQUIRES_BONDS)
    static uint32_t gap_address_change(void)
        uint32_t       err_code;
        ble_gap_addr_t addr;
        err_code = sd_ble_gap_addr_get(&addr);
        VERIFY_SUCCESS(err_code);
        /* Increase the BLE address by one when advertising openly. */
        addr.addr[0] += 1;
        err_code = sd_ble_gap_addr_set(&addr);
        return NRF_SUCCESS;
    So if you are not bonding to the iOS device and you do accept DFU from unbonded peers, then you should not need to use the peer manager.
  • OK, so even with NRF_DFU_BLE_REQUIRES_BONDS not defined, why cannot iOS do DFU/get notification unless peer manager is added to the application? What am I missing here?
  • If you are not bonded with the iOS device you do not need the PM and you do not have to send any Service Changed notification as the nRF device in bootloader mode will have another address than the device in application mode. The nRF Connect app should look for advertisment packets from both addresses.
    If I could see the sniffer trace I would be able to see if the bootloader is changing the address or not and if the iOS device is attempting to connect to the bootloader or not.
