Buttonless DFU using BLE
I have application that is sending data over BLE every 5 minutes.
I want to implement DFU using BLE. I don't have any single button on my device.
What should i have to add in my application for DFU. I use native nRF boot-loader from example. What are the changes i have to do in native Bootloader for buttonless DFU.
How to tell my application to jump into DFU mode ?
Thanks.
  • Hello ,
    This thread is more than a year old and the customer has stopped replying.
    Please create a new ticket detailing the issue you are experiencing, if you require help.
    Karl
  • Hello, it's been a long time since you posted these questions but the answer is:
    STEP 1. be sure that in the code "secure_bootloader" the macro NRF_BL_DFU_ENTER_METHOD_GPREGRET located in sdk_config.h file been equal to 1.
    STEP 2. in your main application if you want to jump to DFU mode you have to execute the next code:
    sd_power_gpregret_clr(0, 0xFF)
    NRF_POWER->GPREGRET = BOOTLOADER_DFU_START;
    // Signal that DFU mode is to be enter to the power management module
    nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU);
    wherethe value of those macros is:
    #define BOOTLOADER_DFU_GPREGRET_MASK (0xB0)
    #define BOOTLOADER_DFU_START_BIT_MASK (0x01)
    #define BOOTLOADER_DFU_START (BOOTLOADER_DFU_GPREGRET_MASK | BOOTLOADER_DFU_START_BIT_MASK)
    /**@brief Power management shutdown types. */
    typedef enum
    NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF,
    //!< Go to System OFF.
    NRF_PWR_MGMT_SHUTDOWN_STAY_IN_SYSOFF,
    //!< Go to System OFF and stay there.
    * Useful when battery level is dangerously low, for example.
    NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU,
    //!< Go to DFU mode.
    NRF_PWR_MGMT_SHUTDOWN_RESET,
    //!< Reset chip.
    NRF_PWR_MGMT_SHUTDOWN_CONTINUE
    //!< Continue shutdown.
    * This should be used by modules that block the shutdown process, when they become ready for
    * shutdown.
    } nrf_pwr_mgmt_shutdown_t;
    Also you have to include the nexts files:
    #include "nrf_soc.h"
    #include "nrf_power.h"
    and that's all. When the application execute the line nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU); it will execute a system reset so the bootloader will read the NRF_POWER->GPREGRET register and will jump to DFU mode.
    NOTE: The NRF_POWER->GPREGRET register is cleared when a hardware reset occurs. therefore if you turn off you device then you turn on it will start in your main application becose the register will be equal to 0.
    Thank you for providing us with an update on this, Hector! :)
    I assume that brijeshgpt47 created a separate ticket for this, but its great to have your comment here for completeness / future reference.
    Karl
