SPI communication problem with interfaced sensor getting ASSERTION FAILED?
Hello Everyone,
We are using nRF52840 DK with Segger Embedded Studio (SES) using SDK v15.0 We are sending few command to sensor via SPI for reading sensor value. But while reading sensor value getting asseration failed ERROR at line no: nRF5_SDK_15.0.0_a53641a/modules/nrfx/drivers/src/nrfx_uarte.c:269
When I go to this line saw NRFX_ASSERT(p_cb->state == NRFX_DRV_STATE_INITIALIZED); difficult to understand what exactly problem. Please help me for fixing this issue.
Looking forward your response....!!!
Thanks...
  • HI,
    Actually I saw this thread and not understand what exactly errata 87. When I changed the debug mode to release then it working.
    Why this happening for debug mode only.
    Thanks.
    In release mode some of the asserts are ignored, such that the application will run instead of asserting.
    In your case it seems you have used the FPU for a calculation, and the calculation output an operational error by invalid data.
    The fpscr register will tell you which of the three following operational errors it was:
    IOC - Invalid Operation cumulative exception bit.
    DZC - Division by Zero cumulative exception bit.
    OFC - Overflow cumulative exception bit.
    You may choose to remove/modify the assert check depending on your requirements. E.g., remove it entirely if you wish to ignore these exceptions like the errata workaround suggests. You may also read the fpscr to find exactly which bit is set if you want to try to figure out what FPU operation that went wrong preivously.
    Kenneth
  • Ok, Thanks for the great explanation..!!
    Now we received sensor that we have written this SPI code for that. But it not working I am little bit confused for How send SPI command to sensor and read sensor response.
    Here is my below simple for read and write SPI command:
    static uint8_t       reset_seq[] = { 0x15, 0x55, 0x40 };     /**< TX buffer. */
    static uint8_t       address_word1[] = { 0x1D, 0x50 };       /**< TX buffer. */
    static uint8_t       address_word2[] = { 0x1D, 0x60 };       /**< TX buffer. */
    static uint8_t       address_word3[] = { 0x1D, 0x90 };       /**< TX buffer. */
    static uint8_t       address_word4[] = { 0x1D, 0xA0 };       /**< TX buffer. */
    static uint8_t       address_pressure[] = { 0x0F, 0x40 };    /**< TX buffer. */
    static uint8_t       address_temp[] = { 0x0F, 0x20 };        /**< TX buffer. */
    static uint8_t       m_rx_buf[sizeof(((uint8_t)0x1D)) + sizeof(((uint8_t)0x1D)) + 1];    /**< RX buffer. */
    static const uint8_t m_length = sizeof(address_word1);
     * Initialized SPI driver and their pin configurations
    void spi_init() {
      nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
      spi_config.ss_pin = SPI_SS_PIN; /*  PCB Pin: 25*/
      spi_config.miso_pin = SPI_MISO_PIN; /*  PCB Pin: 27*/
      spi_config.mosi_pin = SPI_MOSI_PIN; /*  PCB Pin: 26*/
      spi_config.sck_pin = SPI_SCK_PIN; /*  PCB Pin: 28*/
      spi_config.mode    = NRF_DRV_SPI_MODE_0;
      spi_config.frequency    = NRF_SPI_FREQ_500K;
      APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
     * reset sensor module and send sequence.
    void reset_sensor() {
      NRF_LOG_INFO("Reset Sensor");
      APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, reset_seq, sizeof(reset_seq), NULL, 0));
      spi_xfer_done = false;
        while (!spi_xfer_done) {
         idle_state_handle();
        NRF_LOG_FLUSH();
     * brief function Read calibration data (factory calibrated) from PROM of MS5540C
     * by sending specific address.
    unsigned int read_cal_word(uint8_t *address) {
      unsigned int word = 0;
      memset(m_rx_buf, 0, m_length);
      reset_sensor(); /*Before read calibration word need to reset sensor module*/
      APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, address, sizeof(address), m_rx_buf, sizeof(m_rx_buf)));
      NRF_LOG_FLUSH();
      word = (m_rx_buf[0] << 8) | m_rx_buf[1]; /*Combine received 2 bytes from sensor*/
    //  NRF_LOG_DEBUG("Return Calibration word = %u", word);
      return word;
    I am getting wrong calibration word from sensor. Is this above code is correct. What's going wrong in my code.
    Is it necessary to send dummy byte to read data from sensor.
    Thanks..!!
    You should set spi_xfer_done = false; before nrf_drv_spi_transfer() to avoid potential race conditions. I can't see your spi_event_handler() but I assume it just set spi_xfer_done = true;
    Your m_rx_buf should be the length of address_word + data, then the actual data you are looking for is after the size of address_word.
    Also a logic analyzer (e.g. https://www.saleae.com/) can be very useful.
    Kenneth
