Hello
I am using Android and BLE communication with nRF52832 (BLENano2) now.
I am using SDK 15.0.0 with keil uversion.
Central is Android and peripheral is nRF52832.
Use the SDK "ble_app_blinky".
I now want to send arbitrary data from peripheral to central.
So I added a characteristic based on "ble_app_blinky".
The following program was created for that characteristic.
uint32_t send_value(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t sensor_value)
if (p_lbs == NULL)
return NRF_ERROR_NULL;
uint32_t err_code = NRF_SUCCESS;
ble_gatts_value_t gatts_value;
// Initialize value struct.
memset(&gatts_value, 0, sizeof(gatts_value));
gatts_value.len = sizeof(uint8_t);
gatts_value.offset = 0;
gatts_value.p_value = &sensor_value;
// Update database.
err_code = sd_ble_gatts_value_set(BLE_CONN_HANDLE_ALL,////////////
p_lbs->sensor_char_handles.value_handle,
&gatts_value);
if (err_code != NRF_SUCCESS)
return err_code;
// Send value if connected and notifying.
if ((conn_handle != BLE_CONN_HANDLE_INVALID))
ble_gatts_hvx_params_t hvx_params;
memset(&hvx_params, 0, sizeof(hvx_params));
hvx_params.handle = p_lbs->sensor_char_handles.value_handle;
hvx_params.type = BLE_GATT_HVX_NOTIFICATION;
hvx_params.offset = gatts_value.offset;
hvx_params.p_len = &gatts_value.len;
hvx_params.p_data = gatts_value.p_value;
err_code = sd_ble_gatts_hvx(conn_handle, &hvx_params);
err_code = NRF_ERROR_INVALID_STATE;
return err_code;
By calling this "send_value" function
It turned out that a value is set by "sd_ble_gatts_value_set" and a value is notified by "sd_ble_gatts_hvx".
There is something I do not understand here, but I want to know when to call this function.
I found out that I have to be called when notification is enabled.
How should I program when notification is valid?
Please give me an answer
