AT24C512 + BMI160 + NRF52
I am using nRF52832 soc to develop my project. with nRF5_SDK_15.3 . SES file
I need to connect both BMI160 accelerometer sensor and AT24C512 EEPROM ic in TWI.
how to use TWI with this. guide me to use both at a time.
BMI160 separately i can read the data.
but i can't read while connect to AT24C512
    can i use
    #define TWI0_ENABLED 1
    #define TWI1_ENABLED 1
    i.e
    two TWI Instance. one for EEPROM and another for SENSOR.
    it means is it TWIM or TWIS ?
    is it advisable to go with two twi instance at a time
  • Hi, Can you please tell me what is the difference of  TWI0 and TWI1
    #ifndef TWI0_ENABLED
    // <q> TWI0_USE_EASY_DMA  - Use EasyDMA (if present)
    #ifndef TWI0_USE_EASY_DMA
    #define TWI0_USE_EASY_DMA 1
    // </e>
    // <e> TWI1_ENABLED - Enable TWI1 instance
    #ifndef TWI1_ENABLED
    #define TWI1_ENABLED 0
    // <q> TWI1_USE_EASY_DMA  - Use EasyDMA (if present)
    #ifndef TWI1_USE_EASY_DMA
    #define TWI1_USE_EASY_DMA 0
    shall i enable both twi instance.
    what is
    TWI0_USE_EASY_DMA 1  - use case?
    #define TWI1_USE_EASY_DMA 0 - use case?
    if i enable both twi instance
    means
    the EASY_DMA of TWI1 also be '1' or '0'
  • Can you please tell me what is the difference of  TWI0 and TWI1
    Again, look at the Product Specification!
    The Block Diagram clearly shows you that there are two TWIM modules - called "TWIM0" and "TWIM1":
    Yes, you could use both modules - with one slave on each.
    But the whole point of I2C as a bus is that each one can support multiple peripherals - as showed:
  • hi,
    please verify the code:
    #include <stdio.h>
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "bmi160.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define G_TO_LSB (16384.0f)
    #define DPS_TO_LSB (131.072f)
    #define I2C_24C128_SLAVE_ADDR        (0x57)
    #define BMI160_I2C_ADDR1                      UINT8_C(0x68)
    #define ARDUINO1_I2C_SCL_PIN 30
    #define ARDUINO1_I2C_SDA_PIN 31
    /* TWI instance ID. */
    #define TWI0_INSTANCE_ID     0
    #define TWI1_INSTANCE_ID     1
    struct bmi160_dev sensor;
    struct bmi160_sensor_data accel;
    struct bmi160_sensor_data gyro;
    struct bmi160_int_settg int_config;
    int8_t rslt = BMI160_OK;
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi_mma_EEP = NRF_DRV_TWI_INSTANCE(TWI0_INSTANCE_ID);
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI1_INSTANCE_ID);
    void eep_WriteByte(uint16_t eep_address, unsigned char val);
    unsigned char eep_readByte(uint16_t eep_address);
    ret_code_t err_codecpy;
    float accelX;
    void twi_init (void)
        ret_code_t err_code;
        const nrf_drv_twi_config_t twi_mma_EEP_config  = {
           .scl                = ARDUINO1_I2C_SCL_PIN,
           .sda                = ARDUINO1_I2C_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
          // .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi_mma_EEP, &twi_mma_EEP_config, NULL, NULL); //twi_handler
        if (NRF_SUCCESS == err_code)
    		nrf_drv_twi_enable(&m_twi_mma_EEP);
    		NRF_LOG_INFO("TWI0 init success...");
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    		nrf_drv_twi_enable(&m_twi);
    		NRF_LOG_INFO("TWI init success...");
       err_codecpy=err_code;
    		nrf_delay_ms(5);
    unsigned char eep_readByte(uint16_t eep_address){
        unsigned char eep_by_address[2];
    unsigned char reg=0;
        eep_by_address[1]   = eep_address;
        eep_by_address[0] = (unsigned char)(eep_address << 8);
        // setting the start address
        nrf_drv_twi_tx(&m_twi_mma_EEP, I2C_24C128_SLAVE_ADDR, eep_by_address, 2, true);
        // read a byte
        nrf_delay_ms(5);
        nrf_drv_twi_rx(&m_twi_mma_EEP, I2C_24C128_SLAVE_ADDR, &reg,1);
        nrf_delay_ms(5);
    	return reg;
    void eep_WriteByte(uint16_t eep_address, unsigned char val){
        unsigned char eep_by_address[3];
        eep_by_address[2] = val;
        err_codecpy = nrf_drv_twi_tx(&m_twi_mma_EEP, I2C_24C128_SLAVE_ADDR, eep_by_address, 3, false);
        nrf_delay_ms(5);
        if(err_codecpy == 0)
          NRF_LOG_INFO("\r\nWritten Sucess");
        NRF_LOG_FLUSH();
    int8_t Acc_i2c_Write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
        //  NRF_LOG_INFO("WRITE: dev_id: %x reg_addr: %x reg_data: %x len: %i\n", dev_id, reg_addr, *reg_data, len);
    	int8_t rslt = 0;
    	uint8_t data[len + 1];
    	data[0] = reg_addr;
    	for (uint16_t i = 0; i < len; i++) {
    		data[i + 1] = reg_data[i];
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, data, len + 1, false);
    	APP_ERROR_CHECK(rslt);
            return rslt;
    int8_t Acc_i2c_Read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    	int8_t rslt = 0;
       //     NRF_LOG_INFO("READ: dev_id: %x reg_addr: %x len: %i\n", dev_id, reg_addr, len);
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, &reg_addr, 1, false);
    	if (rslt == 0)
    		rslt = nrf_drv_twi_rx(&m_twi, dev_id, reg_data, len);
        //    NRF_LOG_INFO("READ: %x",*reg_data);
    	return rslt;
    void Acc_delay_ms(uint32_t period)
    /*if (period==NULL){
    period = 1;
    }// delay time*/
      nrf_delay_ms( period ) ;
    void BMI_init (void)
        sensor.id = BMI160_I2C_ADDR;         //0x69
        sensor.interface = BMI160_I2C_INTF;  //0x00
        sensor.read = &Acc_i2c_Read;
        sensor.write = &Acc_i2c_Write;
        sensor.delay_ms = &Acc_delay_ms;
        rslt = bmi160_init(&sensor);
        if(rslt == BMI160_OK){
        NRF_LOG_INFO("BMI160 Initialized...");
        } else {
        NRF_LOG_INFO("BMI160 not Initialized...");
        }NRF_LOG_FLUSH();
        sensor.accel_cfg.odr = BMI160_ACCEL_ODR_1600HZ;
        sensor.accel_cfg.range = BMI160_ACCEL_RANGE_2G;
        sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
        sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
        sensor.gyro_cfg.odr = BMI160_GYRO_ODR_3200HZ;
        sensor.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS;
        sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
        sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
        rslt = bmi160_set_sens_conf(&sensor);
        NRF_LOG_INFO("sensor Configured...");
        } else {
        NRF_LOG_INFO("sensor not Configured...");
        }NRF_LOG_FLUSH();
    static void read_sensor_data()
          bmi160_get_sensor_data((BMI160_ACCEL_SEL | BMI160_GYRO_SEL | BMI160_TIME_SEL), &accel, &gyro, &sensor);
          /*NRF_LOG_INFO("DataX:%d", accel.x);
          NRF_LOG_INFO("DataY:%d", accel.y);
          NRF_LOG_INFO("DataZ:%d", accel.z);
          NRF_LOG_INFO("GyroX:%d", gyro.x);
          NRF_LOG_INFO("GyroY:%d", gyro.y);
          NRF_LOG_INFO("GyroZ:%d", gyro.z);*/
          /* need the calculation to study  */
          accelX = ((((float)accel.x) / G_TO_LSB) * 9.80655); // in m/s^2
          float gyrX = ((((float)gyro.x) / DPS_TO_LSB) * 0.0174532925); // in rad/sec
          NRF_LOG_INFO("DataX in m/s^2   : " NRF_LOG_FLOAT_MARKER,
          NRF_LOG_FLOAT( accelX));
          NRF_LOG_INFO("DataY in rad/sec : " NRF_LOG_FLOAT_MARKER,
          NRF_LOG_FLOAT(gyrX));
          NRF_LOG_FLUSH();
        NRF_LOG_INFO("\r\nTWI sensor example started.");
        NRF_LOG_FLUSH();
        twi_init();
        NRF_LOG_FLUSH();
    	unsigned char  reg1 = 0;
            Acc_delay_ms(50);
        BMI_init();
        Acc_delay_ms(100);
        uint8_t reg_addr = BMI160_CHIP_ID_ADDR;
        uint8_t data;
        uint16_t len = 1;
        Acc_delay_ms(1000);
        rslt = bmi160_get_regs(reg_addr, &data, len, &sensor);
        NRF_LOG_INFO("Data:%x", data);
        eep_WriteByte(0x0000,data);
        while(true)
            nrf_delay_ms(1000);
    		//	    eep_WriteByte(0x0000,'w');
    	 nrf_delay_ms(5);
    	//eep_WriteByte(0x0001,'B');
    	 nrf_delay_ms(5);
    	   reg1=eep_readByte(0x0000);
    	if(reg1!=0){
    		NRF_LOG_INFO("\r\n Read value 00 : %x",reg1);
                    NRF_LOG_FLUSH();
                    nrf_delay_ms(5);
    	else if(reg1==0){
    	 nrf_delay_ms(5);
            reg1=eep_readByte(0x00051);
    	if(reg1!=0){
    		NRF_LOG_INFO("\r\n Read value 51 : %c",reg1);
                    NRF_LOG_FLUSH();
                    nrf_delay_ms(5);
    	else if(reg1==0){
    	 nrf_delay_ms(5);
            read_sensor_data();
            eep_WriteByte(0x00051,accelX);
    	if(reg1!=0){
    		NRF_LOG_INFO("\r\n Read value 51 : %d",reg1);
                    NRF_LOG_FLUSH();
                    nrf_delay_ms(5);
    	else if(reg1==0){
    	 nrf_delay_ms(5);
    output:
    it works in two different TWI wire pins
    that is
    eeprom  scl in 27
    eeprom sda in 26
    bmi scl in 30
    bmi sda in 31
    if i give same sda and scl pin to eeprom and bmi. it gives fatal error ;
    can you give how to manage this in single TWI wire.
    i have seen TWI mangr
    in that
    i have difficult to interface the eeprom with bmi
    can you give a solution
  • My mouse pointer is all over the place today, did mean to suggest this as the answer for this case.
    awneil said:
    I find it unclear whether it is a separate module, or if TWIM and/or TWIS are just "operating modes" of the TWI module?
    @awneil, I agree. This is very confusing, even for me. But the easy explanation is:
    • TWI is legacy driver for nRF51
    • TWIM and TWIS are new for nRF52 which also uses EasyDMA
    There is no connection between TWI and TWIM/TWIS.
    awneil said:
    and are there two TWIS modules plus two TWIM modules - or is it just a total of two modules, each of which can be either TWIM or TWIS ?
     Have a look at the memory Instantiation, as long as they do not collide. I.e. Address 0x40003000 is shared between SPIM, SPIS, SPI, TWIM, TWIS and TWI. Only one can be instance can be used at one memory location. Address 0x40003000 has the same. So you can have an instance of TWIM in each, but then you have filled max instances.
    I hope this helps to clarify Slight smile
