can someone post tutorial how to do Over Air Download? I mean new SDK 4.4
I get error from cmd: ImportError: No module named intelhex
Regards, Konstantin
Regards, Konstantin
Hi Konstantin, Could you mark the answer that enabled you to make it work as the accepted answer? if you by chance had to find the solution yourself, could you post that one and mark it as accepted answer? BR Pål
Oh, it was my mistake, I wrote wrong address =))
You have to keep this button pressed while the device is powering up, but when doing so, I don't have any problems with this. Does your regular application start even when holding button 7 when starting?
Yes, Ole, it is working, when the button is pushed while powering up. Is it possible to enter bootloader mode without shutting down the system? For instance when I write characteristic for entering bootloader, send data which means "enter bootloader", without pushing buttons.
