Occasionally large latency
I have run many tests using the light_switch demo. I have noticed that occasionally the latency is much larger. The latency jump is between sends, i.e. it will send 20 times with avg latency of 100ms then the 21st time it will be 1000ms, then resume to normal. Is this because the board is busy in these instances? I am doing group sending.
N.B. This happens with all configs e.g. different packet sizes, instaburst on/off
My timing code works as follows:
At sending:
static void button_event_handler(...){
    status = generic_onoff_client_set(&m_clients[1], &set_params, &transition_params);
    hal_led_pin_set(BSP_LED_1, set_params.on_off);
    tx_timestamp = NRF_RTC0->COUNTER; // tx_timestamp is a global
And receiving:
uint32_t time_calc(uint32_t initial, uint32_t final) {
    uint32_t delta = ((final - initial) * 1000) / 32768;
    return delta;
static void app_generic_onoff_client_status_cb(...) {
    uint32_t ts = tx_timestamp;
    uint32_t rtt = time_calc(ts, NRF_RTC0->COUNTER);
  • This happens as soon as the messages are segmented (>11 bytes at the app layer). Still the average is low, just the occasional high latency. Do know if this a Bluetooth mesh problem?
  • 4 servers latency (this takes the min for each one)
    14/05/2019 17:18:24	1	0x0105	0x0104	0x0106	0x0103
    14/05/2019 17:18:24	1	534	541	546	583
    14/05/2019 17:18:30	2	46	61	50	54
    14/05/2019 17:18:35	3	57	47	46	55
    14/05/2019 17:18:40	4	54	45	56	49
    14/05/2019 17:18:45	5	52	61	59	57
    14/05/2019 17:18:50	6	52	44	56	51
    14/05/2019 17:18:55	7	42	43	58	44
    14/05/2019 17:19:00	8	27	41	32	131
    14/05/2019 17:19:05	9	42	47	38	98
    14/05/2019 17:19:10	10	533	538	534	532
    14/05/2019 17:19:15	11	41	38	50	31
    14/05/2019 17:19:21	12	47	60	62	45
    14/05/2019 17:19:26	13	89	74	100	61
    14/05/2019 17:19:31	14	41	28	45	40
    14/05/2019 17:19:36	15	70	61	30	105
    14/05/2019 17:19:41	16	37	30	41	85
    14/05/2019 17:19:46	17	43	27	38	33
    14/05/2019 17:19:51	18	44	56	40	37
    14/05/2019 17:19:56	19	58	39	49	45
    14/05/2019 17:20:01	20	36	47	41	32
    14/05/2019 17:20:06	21	543	540	556	543
    14/05/2019 17:20:12	22	50	49	43	56
    14/05/2019 17:20:17	23	50	63	102	58
    14/05/2019 17:20:22	24	62	61	57	53
    14/05/2019 17:20:27	25	68	55	51	57
    14/05/2019 17:20:32	26	56	110	57	66
    14/05/2019 17:20:37	27	51	78	107	51
    14/05/2019 17:20:42	28	46	92	42	41
    14/05/2019 17:20:47	29	40	42	52	51
    14/05/2019 17:20:52	30	49	44	50	60
    14/05/2019 17:20:57	31	92	55	59	45
    14/05/2019 17:21:03	32	45	45	55	55
    14/05/2019 17:21:08	33	97	56	102	51
    14/05/2019 17:21:13	34	46	70	59	45
    14/05/2019 17:21:18	35	520	528	525	510
    14/05/2019 17:21:23	36	105	42	61	52
    14/05/2019 17:21:28	37	70	53	99	60
    14/05/2019 17:21:33	38	43	45	37	43
    14/05/2019 17:21:38	39	84	50	112	33
    14/05/2019 17:21:43	40	47	35	42	46
    14/05/2019 17:21:48	41	58	68	60	54
    14/05/2019 17:21:53	42	54	50	43	51
    14/05/2019 17:21:59	43	43	54	102	56
    14/05/2019 17:22:04	44	41	51	52	56
    14/05/2019 17:22:09	45	51	57	98	52
    14/05/2019 17:22:14	46	32	37	42	36
    14/05/2019 17:22:19	47	69	66	49	48
    14/05/2019 17:22:24	48	45	36	34	47
    14/05/2019 17:22:29	49	51	41	38	40
    14/05/2019 17:22:34	50	103	51	46	39
    14/05/2019 17:22:39	51	100	98	54	54
    14/05/2019 17:22:44	52	52	99	53	51
    14/05/2019 17:22:50	53	39	98	40	55
    14/05/2019 17:22:55	54	48	40	54	49
    14/05/2019 17:23:00	55	45	43	34	40
    14/05/2019 17:23:05	56	104	47	52	57
    14/05/2019 17:23:10	57	91	52	128	51
    14/05/2019 17:23:15	58	53	59	55	95
    14/05/2019 17:23:20	59	96	93	50	82
    14/05/2019 17:23:25	60	43	48	36	42
    14/05/2019 17:23:30	61	205	46	48	46
    14/05/2019 17:23:35	62	60	61	60	59
    14/05/2019 17:23:41	63	40	93	92	41
    14/05/2019 17:23:46	64	66	50	50	62
    14/05/2019 17:23:51	65	42	43	39	50
    14/05/2019 17:23:56	66	37	54	39	42
    14/05/2019 17:24:01	67	45	57	54	51
    14/05/2019 17:24:06	68	537	582	591	529
    14/05/2019 17:24:11	69	64	60	72	114
    14/05/2019 17:24:16	70	105	54	111	63
    14/05/2019 17:24:21	71	46	92	44	93
    14/05/2019 17:24:26	72	57	59	60	56
    14/05/2019 17:24:32	73	48	60	42	43
    14/05/2019 17:24:37	74	40	49	42	40
    14/05/2019 17:24:42	75	59	45	102	46
    14/05/2019 17:24:47	76	49	155	41	54
    14/05/2019 17:24:52	77	45	97	57	93
    14/05/2019 17:24:57	78	56	53	58	53
    14/05/2019 17:25:02	79	103	57	110	57
    14/05/2019 17:25:07	80	97	88	30	32
    14/05/2019 17:25:12	81	107	53	53	42
    14/05/2019 17:25:17	82	36	43	38	52
    14/05/2019 17:25:23	83	79	32	41	24
    14/05/2019 17:25:28	84	30	43	40	35
    14/05/2019 17:25:33	85	52	43	47	58
    14/05/2019 17:25:38	86	47	38	31	32
    14/05/2019 17:25:43	87	530	573	526	522
    14/05/2019 17:25:48	88	63	34	35	50
    14/05/2019 17:25:53	89	77	53	66	62
    14/05/2019 17:25:58	90	55	41	39	44
    14/05/2019 17:26:03	91	44	53	52	42
    14/05/2019 17:26:08	92	51	55	57	110
    14/05/2019 17:26:14	93	49	42	45	58
    14/05/2019 17:26:19	94	104	65	62	100
    14/05/2019 17:26:24	95	97	53	106	102
    14/05/2019 17:26:29	96	45	42	47	92
    14/05/2019 17:26:34	97	56	51	48	59
    14/05/2019 17:26:39	98	57	42	43	55
    14/05/2019 17:26:44	99	51	48	41	55
    14/05/2019 17:26:49	100	1014	1065	1017	1066
  • Hi Jon,
    Could you provide more info of the statistic? How many hops ? what was the payload size ?
  • 14 bytes incl. opcode. This is all single hop. I am almost certain this is a result of the segmentation process.
  • We are suspecting the responses from the servers has been collided. Are the response in one packet or they are also segmented message ?
    We would need to check which direction introduce the large latency. If possible could you toggle an GPIO pin on the client and on the servers when you send and receive respectively. So that we can measure the latency of the single direction from client to servers.
    You can use an oscilloscope or a digital analyzer to record the latency between the GPIOs toggle.
    Also please make sure the testing environment is not congested with other RF communication (wifi, other mesh , etc).
