Mesh DFU Problem using NRF52840
I'm using 3 nRF52840 DK borads (provisioner,light_switch_client, DFU). I set DFU (DFU example used) as target board and connected it to PC as serial interface. I have provisioned light_switch_client with provisioner board. I did step 3 to 6 as mentioned in infocenter.nordicsemi.com/index.jsp for only DFU board, after that i used to transfer firmware from this board to light_switch_client board, i get error as failed to establish connection. The DFU board connected in COM15. Can you please help me?
My sdk version is : nrf5_SDK_for_Mesh_v2.1.1_src
steps:
1. D:\Nordic\sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1>nrfutilmesh keys --gen-key private_key.txt
Generated key at: private_key.txt
2. D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1>nrfutilmesh keys --show-vk hex private_key.txt
Verification key Qx: 5985dc051f803ec11990fe27139e65b18b935d7e2873a76f66a40f0b2108e45a
Verification key Qy: 088999730ce716d57b50503920da0ab3ee252cabd03dbb611cd0ae405b58a9d1
3. D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1>nrfutilmesh dfu genpkg --application bin/blinky/blinky_nrf52840_xxAA_s140_6.0.0.hex --company-id 0x00000059 --application-id 1 --application-version 2 --key-file private_key.txt --sd-req 0x00A9 --mesh dfu_test.zip
Key file was given, setting DFU version to 0.8
Zip created at dfu_test.zip
4. D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1\tools\dfu>python device_page_generator.py -d nrf52840_xxAA -sd "s140_6.0.0"
Wrote device page for nrf52840_xxAA with the s140_6.0.0 SoftDevice to bin/device_page_nrf52840_xxAA_s140_6.0.0.hex.
5. D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1>nrfjprog --eraseall
Erasing user available code and UICR flash areas.
Applying system reset.
6. D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1>nrfjprog --program bin/softdevice/s140_nrf52_6.0.0_softdevice.hex --chiperase
Parsing hex file.
Checking that the area to write is not protected.
Programming device.
7. D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1>nrfjprog --program bin/bootloader/armcc/mesh_bootloader_serial_armcc_nrf52840_xxAA.hex
Parsing hex file.
Reading flash area to program to guarantee it is erased.
Programming device.
8. D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1>nrfjprog --program examples\dfu\build\dfu_nrf52840_xxAA_s140_6.0.0_Debug\dfu_nrf52840_xxAA_s140_6.0.0.hex
Parsing hex file.
Programming device.
9. D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1>nrfjprog --program tools/dfu/bin/device_page_nrf52840_xxAA_s140_6.0.0.hex
Parsing hex file.
Programming device.
10. D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1>nrfutilmesh --verbose dfu serial -pkg dfu_test.zip -p COM15 -b 9600 -fc --mesh
Upgrading target on COM15 with DFU package D:\Nordic\Sdk\nrf5_SDK_for_Mesh_v2.1.1_src_1\dfu_test.zip. Flow control is enabled.
Flushing com-port...
Opened com-port
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 1656
Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
PC -> target: 0502aabbccdd
Failed to upgrade target. Error is: Failed to establish connection
I have changed flash_placement.xml memory segment as mentioned in devzone.nordicsemi.com/.../134485. But still it is not working for me
Please help me i'm new to do DFU in mesh
  • Now i'm getting this RTT Log in DFU:
    <t: 1>, main.c, 206, ----- Bluetooth Mesh DFU Example -----
    <t: 8769>, serial_handler_prov.c, 267, Generating encryption keypair...
    <t: 13630>, main.c, 224, Initialization complete!
    <t: 18379>, main.c, 245, Enabling serial interface...
    <t: 18382>, mesh_app_utils.c, 65, Device UUID (raw): 81A2E45B8A562749B3CF37CF4FFAA541
    <t: 18385>, mesh_app_utils.c, 70, Device UUID : 5BE4A281-568A-4927-B3CF-37CF4FFAA541
    <t: 18392>, nrf_mesh_dfu.c, 528, RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
    <t: 18397>, nrf_mesh_dfu.c, 561, SERIAL TX!
    <t: 18403>, main.c, 253, DFU example started!
    <t: 9579686>, nrf_mesh_dfu.c, 390, New firmware!
    <t: 9579690>, nrf_mesh_dfu.c, 528, RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
    <t: 9579693>, nrf_mesh_dfu.c, 534, Killing a TX slot prematurely (repeats done: 30).
    <t: 9579697>, nrf_mesh_dfu.c, 561, SERIAL TX!
    <t: 9645902>, nrf_mesh_dfu.c, 528, RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
    <t: 9645906>, nrf_mesh_dfu.c, 534, Killing a TX slot prematurely (repeats done: 0).
    <t: 9645910>, nrf_mesh_dfu.c, 561, SERIAL TX!
    <t: 9711942>, nrf_mesh_dfu.c, 430, DFU start
    <t: 9711945>, nrf_mesh_dfu.c, 528, RADIO TX! SLOT 1, count 6, interval: exponential, handle: FFFC
    <t: 9791823>, nrf_mesh_dfu.c, 329, Erase complete (0x43000)
    <t: 9791827>, nrf_mesh_dfu.c, 333, Flash idle.
  • Looks better. Please provide the screenshot of the nrfutil tool on PC.
    You may need to follow this link to fix some bug on the nrfutil if you see the same problem (if testing with the blinky image, it should work)
    https://devzone.nordicsemi.com/f/nordic-q-a/46950/problem-with-mesh-dfu
  • Sending firmware file
    [------------------------------------] 1% 00:11:58PC -> target: 1978fcff0100666022c600fd0320b1650200d9650200db650200
    target -> PC: 03847800
    PC -> target: 1978fcff0200666022c6dd650200df650200e165020000000000
    [------------------------------------] 2% 00:11:45PC -> target: 1978fcff0300666022c6000000000000000000000000e3650200
    PC -> target: 1978fcff0400666022c6e565020000000000e7650200e9650200
    [#-----------------------------------] 4% 00:07:19PC -> target: 1978fcff0500666022c6eb650200eb650200eb650200eb650200
    PC -> target: 1978fcff0600666022c6eb650200eb650200eb650200eb650200
    [##----------------------------------] 6% 00:05:36PC -> target: 1978fcff0700666022c6eb650200eb650200eb650200eb650200
    PC -> target: 1978fcff0800666022c6eb650200eb650200eb650200eb650200
    [##----------------------------------] 8% 00:04:39PC -> target: 1978fcff0900666022c6eb650200eb650200eb650200eb650200
    PC -> target: 1978fcff0a00666022c6eb650200eb650200eb650200eb650200
    [###---------------------------------] 9% 00:04:00PC -> target: 1978fcff0b00666022c6eb650200eb650200eb650200eb650200
    PC -> target: 1978fcff0c00666022c6eb650200eb6502000000000000000000
    [####--------------------------------] 11% 00:03:33PC -> target: 1978fcff0d00666022c6eb650200eb650200eb650200eb650200
    PC -> target: 1978fcff0e00666022c6eb650200eb650200eb650200eb650200
    [####--------------------------------] 13% 00:03:12PC -> target: 1978fcff0f00666022c6eb650200eb650200eb65020000000000
    PC -> target: 1978fcff1000666022c600000000eb65020000000000eb650200
    [#####-------------------------------] 15% 00:01:52PC -> target: 1978fcff1100666022c600000000000000000000000000000000
    PC -> target: 1978fcff1200666022c600000000000000000000000000000000
    [######------------------------------] 16% 00:01:38PC -> target: 1978fcff1300666022c600000000000000000000000000000000
    PC -> target: 1978fcff1400666022c600000000000000000000000000000000
    [######------------------------------] 18% 00:01:28PC -> target: 1978fcff1500666022c600000000000000000000000000000000
    PC -> target: 1978fcff1600666022c600000000000000000000000000000000
    [#######-----------------------------] 20% 00:01:21PC -> target: 1978fcff1700666022c600000000000000000000000000000000
    PC -> target: 1978fcff1800666022c600000000000000000000000000000000
    [#######-----------------------------] 22% 00:01:15PC -> target: 1978fcff1900666022c600000000000000000000000000000000
    PC -> target: 1978fcff1a00666022c600000000000000000000000000000000
    [########----------------------------] 23% 00:01:10PC -> target: 1978fcff1b00666022c600000000000000000000000000000000
    PC -> target: 1978fcff1c00666022c600000000000000000000000000000000
    [#########---------------------------] 25% 00:01:06PC -> target: 1978fcff1d00666022c600000000000000000000000000000000
    PC -> target: 1978fcff1e00666022c600000000000000000000000000000000
    [#########---------------------------] 27% 00:01:03PC -> target: 1978fcff1f00666022c600000000000000000000000000000000
    PC -> target: 1978fcff2000666022c600000000000000000000000000000000
    [##########--------------------------] 29% 00:01:00PC -> target: 1978fcff2100666022c610b5054c237833b9044b13b10448aff3
    PC -> target: 1978fcff2200666022c600800123237010bd3433002000000000
    [###########-------------------------] 30% 00:00:57PC -> target: 1978fcff2300666022c69c66020008b5034b1bb103490348aff3
    PC -> target: 1978fcff2400666022c6008008bd00000000383300209c660200
    [###########-------------------------] 32% 00:00:54PC -> target: 1978fcff2500666022c6154b002b08bf134b9d46a3f5803a0021
    PC -> target: 1978fcff2600666022c68b460f461348144a121a00f0fff90f4b
    [############------------------------] 34% 00:00:52PC -> target: 1978fcff2700666022c6002b00d098470e4b002b00d098470020
    PC -> target: 1978fcff2800666022c6002104000d000d48002802d00c48aff3
    [############------------------------] 36% 00:00:50PC -> target: 1978fcff2900666022c6008000f0c7f92000290000f013f800f0
    PC -> target: 1978fcff2a00666022c6adf900bf0000080000fd032000000000
    [#############-----------------------] 37% 00:00:48PC -> target: 1978fcff2b00666022c600000000343300205033002000000000
    PC -> target: 1978fcff2c00666022c60000000010b500231f2b29d94ff0a043
    [##############----------------------] 39% 00:00:46PC -> target: 1978fcff2d00666022c64ff4f032c3f808250022c3f80c254ff0
    PC -> target: 1978fcff2e00666022c680434ff00f12c3f800240122c3f81c25
    [##############----------------------] 41% 00:00:44PC -> target: 1978fcff2f00666022c64ff0a042d2f80435d94301f48041c2f8
    PC -> target: 1978fcff3000666022c6081503f48043c2f80c354ff4fa744ff4
    [###############---------------------] 43% 00:00:42PC -> target: 1978fcff3100666022c67a400a4b43f001039847013cf7d1e7e7
    PC -> target: 1978fcff3200666022c601229a4012f4f03f06d003f5e0724ff0
    [################--------------------] 44% 00:00:40PC -> target: 1978fcff3300666022c6a041032041f822000133c5e790660200
    PC -> target: 1978fcff3400666022c60120704701207047064b1b68082b01d0
    [################--------------------] 46% 00:00:39PC -> target: 1978fcff3500666022c600207047044b1b680bb1002070470120
    PC -> target: 1978fcff3600666022c6704700bf3001001034010010064b1b68
    [#################-------------------] 48% 00:00:37PC -> target: 1978fcff3700666022c6082b01d000207047044b1b680bb10020
    PC -> target: 1978fcff3800666022c670470120704700bf3001001034010010
    [##################------------------] 50% 00:00:36PC -> target: 1978fcff3900666022c6064b1b68082b01d000207047044b1b68
    PC -> target: 1978fcff3a00666022c60bb1002070470120704700bf30010010
    [##################------------------] 51% 00:00:34PC -> target: 1978fcff3b00666022c634010010064b1b68082b01d000207047
    PC -> target: 1978fcff3c00666022c6044b1b680bb1002070470120704700bf
    [###################-----------------] 53% 00:00:33PC -> target: 1978fcff3d00666022c6300100103401001001207047014b024a
    PC -> target: 1978fcff3e00666022c61a607047c83200200090d00308b5fff7
    [###################-----------------] 55% 00:00:31PC -> target: 1978fcff3f00666022c6a7ff40b14ff080430022c3f80c21c3f8
    PC -> target: 1978fcff4000666022c61021c3f83825fff79dff002846d04ff0
    [####################----------------] 57% 00:00:30PC -> target: 1978fcff4100666022c68052d2f80414604bc3f82015d2f80814
    PC -> target: 1978fcff4200666022c6c3f82415d2f80c14c3f82815d2f81014
    [#####################---------------] 58% 00:00:28PC -> target: 1978fcff4300666022c6c3f82c15d2f81414c3f83015d2f81814
    PC -> target: 1978fcff4400666022c6c3f83415d2f81c14c3f84015d2f82014
    [#####################---------------] 60% 00:00:27PC -> target: 1978fcff4500666022c6c3f84415d2f82414c3f84815d2f82814
    PC -> target: 1978fcff4600666022c6c3f84c15d2f82c14c3f85015d2f83014
    [######################--------------] 62% 00:00:26PC -> target: 1978fcff4700666022c6c3f85415d2f83414c3f86015d2f83814
    PC -> target: 1978fcff4800666022c6c3f86415d2f83c14c3f86815d2f84014
    [#######################-------------] 64% 00:00:24PC -> target: 1978fcff4900666022c6c3f86c15d2f84424c3f87025fff754ff
    PC -> target: 1978fcff4a00666022c610b13e4b3e4a1a60fff760ff18b13d4b
    [#######################-------------] 65% 00:00:23PC -> target: 1978fcff4b00666022c6fb22c3f81825fff76bff48b13a490b68
    PC -> target: 1978fcff4c00666022c623f00f03394a126802f00f0213430b60
    [########################------------] 67% 00:00:22PC -> target: 1978fcff4d00666022c6fff770ff18b1364b4ff400721a60fff7
    PC -> target: 1978fcff4e00666022c67bff60b14ff08043d3f8003413f0010f
    [########################------------] 69% 00:00:20PC -> target: 1978fcff4f00666022c605d04ff080436ff00102c3f800242d4a
    PC -> target: 1978fcff5000666022c6d2f8883043f47003c2f88830bff34f8f
    [#########################-----------] 71% 00:00:19PC -> target: 1978fcff5100666022c6bff36f8f4ff01023d3f80032002b08db
    PC -> target: 1978fcff5200666022c64ff01023d3f80432002b02dbfff756ff
    [##########################----------] 72% 00:00:18PC -> target: 1978fcff5300666022c608bd214b0122c3f804251f4bd3f80034
    PC -> target: 1978fcff5400666022c6002bfad04ff010231222c3f800221a4b
    [##########################----------] 74% 00:00:17PC -> target: 1978fcff5500666022c6d3f80034002bfad04ff010231222c3f8
    PC -> target: 1978fcff5600666022c60422154bd3f80034002bfad0124b0022
    [###########################---------] 76% 00:00:15PC -> target: 1978fcff5700666022c6c3f80425104bd3f80034002bfad0bff3
    PC -> target: 1978fcff5800666022c64f8f0c49ca6802f4e0620c4b1343cb60
    [############################--------] 78% 00:00:14PC -> target: 1978fcff5900666022c6bff34f8f00bffde700c000408c560040
    PC -> target: 1978fcff5a00666022c64881030000f00040e40e004058020010
    [############################--------] 79% 00:00:13PC -> target: 1978fcff5b00666022c64096024000ed00e000e001400400fa05
    PC -> target: 1978fcff5c00666022c60649074a074b9b1a03dd043bc858d050
    [#############################-------] 81% 00:00:12PC -> target: 1978fcff5d00666022c6fbdcfff70bfffff73bfe0000a8660200
    PC -> target: 1978fcff5e00666022c6c832002034330020fee7fee7fee7fee7
    [##############################------] 83% 00:00:10PC -> target: 1978fcff5f00666022c6fee7fee7fee7fee7fee7fee708b5074b
    PC -> target: 1978fcff6000666022c6044613b10021aff30080054b1868836a
    [##############################------] 85% 00:00:09PC -> target: 1978fcff6100666022c603b19847204600f031f800bf00000000
    PC -> target: 1978fcff6200666022c69866020070b50d4e0d4ca41ba4100025
    [###############################-----] 86% 00:00:08PC -> target: 1978fcff6300666022c6a54209d10b4e0c4c00f022f8a41ba410
    PC -> target: 1978fcff6400666022c60025a54205d170bd56f8253098470135
    [###############################-----] 88% 00:00:07PC -> target: 1978fcff6500666022c6eee756f8253098470135f2e72c330020
    PC -> target: 1978fcff6600666022c62c3300202c3300203033002002440346
    [################################----] 90% 00:00:06PC -> target: 1978fcff6700666022c6934200d1704703f8011bf9e7fee700bf
    PC -> target: 1978fcff6800666022c6f8b500bff8bc08bc9e467047f8b500bf
    [#################################---] 92% 00:00:05PC -> target: 1978fcff6900666022c6f8bc08bc9e4670470000000000000000
    PC -> target: 1978fcff6a00666022c60338fdd870470000cc32002000000000
    [#################################---] 93% 00:00:03PC -> target: 1978fcff6b00666022c6a0fbff7f010000000090d00300000000
    PC -> target: 1978fcff6c00666022c600000000000000000000000000000000
    [##################################--] 95% 00:00:02PC -> target: 1978fcff6d00666022c600000000000000000000000000000000
    PC -> target: 1978fcff6e00666022c600000000000000000000000000000000
    [###################################-] 97% 00:00:01PC -> target: 1978fcff6f00666022c600000000000000000000000000000000
    PC -> target: 1978fcff7000666022c600000000000000000000000000000000
    [###################################-] 99% 00:00:00PC -> target: 1978fcff7100666022c600000000000000000000000025620200
    PC -> target: 0d78fcff7200666022c601620200
    [####################################] 100% DFU upgrade took 64.5310001373s
    Closing serial port...
    Device programmed.
    D:\Nordic\Sdk\nrf5SDKforMeshv310src\tools\dfu>python bootloader_verify.py xxxxxxxxx COM4
    Reading UICR.. OK.
    Reading Device page.. OK.
    Resetting device.. OK.
    Checking serial connection.. OK.
    Bootloader verification OK.
    It was updated successfully, do i need to flash anything after LED2 starts blinking on the board.
  • This result i have taken from the DFU board but if update in target board(light_switch_client) i getting error as
    Failed to upgrade target. Error is: Crashed on start packet
  • OK, So it worked with the blinky example.
    If you want to update with light switch client, you would need to implement DFU feature on it. Please refer to the DFU example to find what you need to add. Basically you need nrf_mesh_dfu.c, nrf_mesh_dfu.h, adding mesh_evt_handler(), etc. Make sure you enable SERIAL DFU.
    After you test to update the blinky firmware with the modified light switch you can think of updating light switch image, if you see error you may need to look into the fixes in this case:
