Problem with MQTT_Simple
I am having a problem running MQTT_Simple on my nRF9160 DK.
The COM Port shows the following:
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x4002a514
***** Hardware exception *****
Current thread ID = 0x20000324
Faulting instruction address = 0x6704
Fatal fault in essential thread! Spinning...
I have recently updated SES, but the code still produces the bus fault.
Case ID: 226428 seems to be similar, but the discussion involves several "experiments" only some of which were productive.
So, could someone explicitly lists the steps needed to get this example working.  I wish to use it as the basis for a new product that sends data to the cloud.
Thank you,
-Craig Goldman
  • craig.goldman said:
    Thank you for the continuing support
     But of course, this is why we are here :)
    craig.goldman said:
    I will remove SES and re-install this afternoon
     Fingers crossed that the version of SES you have installed is the source of error!
  • I've uninstalled SES.
    I've downloaded  "EmbeddedStudio_ARM_Nordic_v416_win_x64.zip" as directed, but there is no obvious installation executable.  No ".bat" file; no "Read.me" file.  Could you direct me how to install?
  • This is correct. Extract Segger Embedded Studio to your preferred folder. In the bin folder, you will find the executable emStudio.exe. This is how you start SES.
  • Good News.  I've gotten quite a bit further along.  Again, thank you for your help.
    I've installed the new SES as directed.  It does look a bit different.  Funny that it has the same revision number.
    The project loaded as an nRF Connect SDK Project without error and built without error.
    After fumbling for a bit, I remembered that I had to manually load the "merged" hex file (and I did).
    Connecting the board opened three serial ports.  One is for the nRF52840, one does nothing and the third seems to be the MQTT application.
    (By the way, I could find no mention of baud rate, 115.2K was not my first choice.  You may want to mention this somewhere.)
    I got the following output...
    vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
    ***** Booting Zephyr OS v1.14.99-ncs1-587-g5c5ba77d0170 *****
    Flash region            Domain          Permissions
    00 0x00000 0x08000      Secure          rwxl
    01 0x08000 0x10000      Non-Secure      rwxl
    02 0x10000 0x18000      Non-Secure      rwxl
    03 0x18000 0x20000      Non-Secure      rwxl
    04 0x20000 0x28000      Non-Secure      rwxl
    05 0x28000 0x30000      Non-Secure      rwxl
    06 0x30000 0x38000      Non-Secure      rwxl
    07 0x38000 0x40000      Non-Secure      rwxl
    08 0x40000 0x48000      Non-Secure      rwxl
    09 0x48000 0x50000      Non-Secure      rwxl
    10 0x50000 0x58000      Non-Secure      rwxl
    11 0x58000 0x60000      Non-Secure      rwxl
    12 0x60000 0x68000      Non-Secure      rwxl
    13 0x68000 0x70000      Non-Secure      rwxl
    14 0x70000 0x78000      Non-Secure      rwxl
    15 0x78000 0x80000      Non-Secure      rwxl
    16 0x80000 0x88000      Non-Secure      rwxl
    17 0x88000 0x90000      Non-Secure      rwxl
    18 0x90000 0x98000      Non-Secure      rwxl
    19 0x98000 0xa0000      Non-Secure      rwxl
    20 0xa0000 0xa8000      Non-Secure      rwxl
    21 0xa8000 0xb0000      Non-Secure      rwxl
    22 0xb0000 0xb8000      Non-Secure      rwxl
    23 0xb8000 0xc0000      Non-Secure      rwxl
    24 0xc0000 0xc8000      Non-Secure      rwxl
    25 0xc8000 0xd0000      Non-Secure      rwxl
    26 0xd0000 0xd8000      Non-Secure      rwxl
    27 0xd8000 0xe0000      Non-Secure      rwxl
    28 0xe0000 0xe8000      Non-Secure      rwxl
    29 0xe8000 0xf0000      Non-Secure      rwxl
    30 0xf0000 0xf8000      Non-Secure      rwxl
    31 0xf8000 0x100000     Non-Secure      rwxl
    SRAM region             Domain          Permissions
    00 0x00000 0x02000      Secure          rwxl
    01 0x02000 0x04000      Secure          rwxl
    02 0x04000 0x06000      Secure          rwxl
    03 0x06000 0x08000      Secure          rwxl
    04 0x08000 0x0a000      Secure          rwxl
    05 0x0a000 0x0c000      Secure          rwxl
    06 0x0c000 0x0e000      Secure          rwxl
    07 0x0e000 0x10000      Secure          rwxl
    08 0x10000 0x12000      Non-Secure      rwxl
    09 0x12000 0x14000      Non-Secure      rwxl
    10 0x14000 0x16000      Non-Secure      rwxl
    11 0x16000 0x18000      Non-Secure      rwxl
    12 0x18000 0x1a000      Non-Secure      rwxl
    13 0x1a000 0x1c000      Non-Secure      rwxl
    14 0x1c000 0x1e000      Non-Secure      rwxl
    15 0x1e000 0x20000      Non-Secure      rwxl
    16 0x20000 0x22000      Non-Secure      rwxl
    17 0x22000 0x24000      Non-Secure      rwxl
    18 0x24000 0x26000      Non-Secure      rwxl
    19 0x26000 0x28000      Non-Secure      rwxl
    20 0x28000 0x2a000      Non-Secure      rwxl
    21 0x2a000 0x2c000      Non-Secure      rwxl
    22 0x2c000 0x2e000      Non-Secure      rwxl
    23 0x2e000 0x30000      Non-Secure      rwxl
    24 0x30000 0x32000      Non-Secure      rwxl
    25 0x32000 0x34000      Non-Secure      rwxl
    26 0x34000 0x36000      Non-Secure      rwxl
    27 0x36000 0x38000      Non-Secure      rwxl
    28 0x38000 0x3a000      Non-Secure      rwxl
    29 0x3a000 0x3c000      Non-Secure      rwxl
    30 0x3c000 0x3e000      Non-Secure      rwxl
    31 0x3e000 0x40000      Non-Secure      rwxl
    Peripheral              Domain          Status
    00 NRF_P0               Non-Secure      OK
    01 NRF_CLOCK            Non-Secure      OK
    02 NRF_RTC1             Non-Secure      OK
    03 NRF_NVMC             Non-Secure      OK
    04 NRF_UARTE1           Non-Secure      OK
    05 NRF_UARTE2           Secure          SKIP
    06 NRF_IPC              Non-Secure      OK
    07 NRF_VMC              Non-Secure      OK
    08 NRF_FPU              Non-Secure      OK
    09 NRF_EGU1             Non-Secure      OK
    10 NRF_EGU2             Non-Secure      OK
    11 NRF_TWIM2            Non-Secure      OK
    12 NRF_SPIM3            Non-Secure      OK
    13 NRF_TIMER0           Non-Secure      OK
    14 NRF_TIMER1           Non-Secure      OK
    15 NRF_TIMER2           Non-Secure      OK
    16 NRF_SAADC            Non-Secure      OK
    17 NRF_GPIOTE1          Non-Secure      OK
    SPM: NS image at 0x8000
    SPM: NS MSP at 0x200237b8
    SPM: NS reset vector at 0xa271
    SPM: prepare to jump to Non-Secure image.
    The MQTT simple sample stabsdlib recoverable error: 3
    rted
    LTE Link Connecting ...
    No further characters after "LTE Link Connecting..."
    I'm not in the best location for a Cellular Link.  I'll try it elsewhere, if I can, later tonight or tomorrow.
    Is the above message (including the "recoverable error") good news, bad news or maybe a bit of both?
    Is my only problem needing a better cell connection or is there something else?
    What kind of message will print on the serial port when it is working?
    -Craig
  • OK.  I'm in a much better cellular location.  This is what I get...
    vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
    The MQTT simple sample started
    LTE Link Connected!
    ERROR: getaddrinfo failed 22
    ERROR: mqtt_connect -47
    So even more progress.  I think I'm getting close.
    What should I do next?
    -Craig
