Firmware update (DFU) from server or cloud.
Hello to all,
We are using nRF52840 with SDK v15.0 using SES, Our application is we have sensor devices with interface WiFi module. Sensor device will wake up as predefined time interval and send data to cloud using WiFi connectivity.
Now we want to update this sensor devices firmware from server. Currently we are able to update firmware using secure_ble via android app. But our requirements and few questions as below:
  1. How I can download program zip file from server using WiFi and store it in flash memory? (We know how to store data array into flash using FDS but not understand how to store and read this zip file in nordic internal flash)
  2. What is best way to do as per following flow:
get zip file from sever --> store in flash --> switch application to DFU / boot-loader mode using button less --> read this file from flash --->send this file for upgrade firmware and replace with existing firmware.
For implement as per above will you please provide me sample example code and some tutorial for how to do that?
Looking forward your response..!!!
Thanks in Advanced..!!
  • Hi Vidhar,
    Thanks for your response,
    Actually I downloaded your example that you have made for nRF52840 with name is "nRF_SDK_15.3.0_background_dfu_3.zip". This example is complied properly but when i tried to upload this into my nRF52840 board using SeS got EROOR like unknown function at 0xFFFFFFFE
    How i can fixed this error at our side?
    We want use to handle DFU in our running application How i can merge this background DFU libraries with our existing application.
    Is this any example for that How use background DFU ? As available lib description here
    Thanks for great support..!!
    It looks like you haven't programmed the Softdevice. Please make sure to follow the steps outlined in the readme.
    The IOT example can be used as a reference. You can also see what files I added to my example which was based on the ble_app_hrs example.
    After programmed SD on SES IDE got another error which is
    I am little bit confused in your readme fie under testing point 3) Start a debug session in SES to view the debug log?
    Is i need to programmed bootloader before softdevice program?
    I am able to compile our application code with your background dfu example files but got same error bootloader address is not set. If i comment it then got an issue with nrf_dfu_inti() function which is ERROR 8 NRF_ERROR_INVALID_STATE.
    I have refered  IoT example background dfu over TFTP but it looks like complex and different.
    I know how to communicate with server and get exacted zip in our application. But problem getting for implementing background DFU to handle their request in app.
    Thanks....
  • Hi Vidhar,
    I am facing lots of difficulties to implement background DFU and our WiFi based custom transport layer.
    I have read and understand IoT based background DFu over TFTP and COAP but it looks like different.
    Will you please guide me or provide sample example for WiFi based transport layer?
    I am stuck for implementing custom WiFi based transport layer for background DFU, If you provide me complete NRF logs of working project. I can try with that flow to implement next part with my best.
    Thanks.. looking forward your response..
    That's unfortunate, but I'm afraid I can't help you with exact instructions for creating a Wifi transport.
    I provided a working project with UART transport. Did you manage to get it working on your side?
