Erroneous results during service discovery of custom UUIDs
Hi there,
Background:
I have set-up a gap peripheral device (nRF52832 / SDK 15.0.0) with 1 service with 2 characteristics, each having its own custom 128 bit UUID. i can connect to the peripheral with nRF Connect App and exchange characteristic data  without any problem. All ok so far.
Now i have another central device (also nRF52832 / SDK 15.0.0), which tries to discover these services via the SDK API's  (sd_ble_gattc_primary_services_discover() / sd_ble_gattc_characteristics_discover() etc. ), however i see the first signs of the trouble, when in the discovery response of the first characteristic (on_evtgattc_char_discovery_resp()), i get the following  response logged below (contents of "ble_gattc_evt_t", please see the lines highlighted in red (char-decl-handle: , service-uuid: etc..).
discovering primary services..
GATT ATT MTU on conn-id 0x0 changed to 247
discovered primary service. uuid: 0x2001, type: 2, start-handle: 0x000E, end-handle: 0xFFFF
--> found a service-uuid: 0x2001
discovering char's (0x000E)..
rcvd char discovery resp, char count: 2
char-decl-handle: 0x000F, service-uuid: 0x2001, uuid-type: 3, value-handle: 0x0010
char-decl-handle: 0x0000, service-uuid: 0x9680, uuid-type: 0, value-handle: 0x001E
read resp for char-decl-handle: 0x000F
char-properties: 0x0C
--> found a char-uuid: 0x0001
discovering char-desc's (0x0011)..
rcvd desc discovery resp, desc count: 1
desc-handle: 0x0011, uuid: 0x2803, type: 1
discovering char's (0x0011)..
rcvd char discovery resp, char count: 1
char-decl-handle: 0x0011, service-uuid: 0x2001, uuid-type: 4, value-handle: 0x0012
read resp for char-decl-handle: 0x0011
char-properties: 0x10
--> found a char-uuid: 0x0002
discovering char-desc's (0x0013)..
desc-handle: 0x0013, uuid: 0x2902, type: 1
found CCCD
on_evtgattc_write_resp()
discovering char-desc's (0x0014)..
error: on_evtgattc_desc_discovery_resp(): 0x10A
discovering char's (0x0014)..
error: on_evtgattc_char_discovery_resp(): 0x10A
The Problems:
1. first of all, why there is characteristic count of 2 in first characteristic discovery.
2.  the 1st characteristic index is relatively OK (i.e., service-uuid is correct, although uuid-type = 3? (0=ble, 1=vendor, 2=unknown), but the 2nd line is completely junk.
3. (for later perhaps), the 2nd characteristic had cccd / notifications enabled, the notification payload is partly corrupted, and appears to have the same junk bytes as contained in the junk characteristic discovery index mentioned in point 2.
how could these results be explained? is there something i need to look into, to avoid this?
much thanks in advance!
