Hi
I tried to implement Eddystone example in nRF52810. it worked successfully. Then i tried to implement same in nRF52832 using pca10040. But it not working. I only changed the led pin. why this not working?.
I am using SDK 15.3.0
Hi
Hi
I am using honor 9 lite
Segger embedded studio is using to build
i tried to flash ble_app_blinky example. then same problem happened.
Please update the suggestions....
Hi
It might be a caching problem.
Could you try to change the BLE address of the device and see if the problem disappears?
To do this please add the following code snippet to the gap_params_init() function in your example:
uint8_t address_raw[] = {0x01, 0x02, 0x03, 0x04, 0x05, 0xC6};
ble_gap_addr_t address;
address.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC;
memcpy(address.addr, address_raw, 6);
sd_ble_gap_addr_set(&address);
Best regards
Torbjørn
Hi
i added this to the gap_params_init() function. then it didnt detect in any phones
Hi
There was a bug in my initial reply, and I fixed it some minutes later.
Which address did you try?
It should be this one:
Not the one I originally posted.
Best regards
Torbjørn
