RESETREAS DOG without WDT Handler Firing
SDK 15.2, nrf52840 SD 6.1
I'm having an issue where a reset with RESETREAS DOG 0x02 is not coming through the WDT handler before executing reset.
I can force this reset by jumping into a while(1) spin loop, but the WDT expired handler does not fire before the jump to 0 reset.
The code resets, and the reset reason is watchdog, however my breakpoint and routine in wdt_event_handler are not executed before the reset. (I make sure to clear the reason after each reboot)
I also made sure APP_ERROR_CHECK is not executed either.
What is the path of this execution? Is this a valid watchdog reset, or am I looking in the wrong place?
Does the soft device not being able to run in the while loop cause the reset? The breakpoint that happens at the reset instruction does not give any context.
Any help/insight would be appreciated,
Jeff
    I ran into the same problem, and after patch this code, problem still.
    test with:
    set nrf_drv_wdt_init with interrupt_priority 0 will trigger a ASSERT ERROR by INTERRUPT_PRIORITY_IS_VALID(pri)
    so, try to insert NVIC_SetPriority(WDT_IRQn, 0); between wdt_init and wdt_enable
    But, test result is can't catch wdt_timeout_hanlder in debug(just Reset)
    Is there a better answer or tutorial, currently updated
    Thand you advance
  • Interrupt priority 0 is reserved to the Softdevice, hence the assertion. But you can work around this by calling 'NVIC_SetPriority(WDT_IRQn, 0);' after enabling the Softdevice.
    As a test to confirm if the WD callback is indeed blocked by another interrupt, please try to add an infinite loop after 'wdt_enable' in main context, then check again if the WD callback doesn't come through.
    e.g.
    int main()
    wdt_enable();
    for(;;); // Wait here until the WD times out
