Whisper Ware (nRf9160)
Without doubt there is a new variation of software emerging:
We are all familiar with Firmware and Software, however I really feel the need to coin the term "Whisper Ware" when it comes to the nRF9160 which I must add we are absolutely committed to making work.
I have personally spent the last 12 hours, uninstalling, changing branches, reinstalling, and trying my best to follow every "whisper" in this forum to make any of the sample applications work.
Even more frustrating is that for a brief time they did seem to function.
Now whatever I do, AT commands time out as follows:
Error: 'AT+CFUN? ' timed out
If someone would be kind enough to give detailed instruction on how I may be able to start "from scratch" and therefore remove any legacy that may exist, I would be very grateful.
I'm using Windows 10 and clearly very very frustrated.
On the ever positive side, I'm thrilled to bits that the implementation currently is such a mess, as most will or already have simply given up as they will not have the sincere patience that I have.
  • Hi John,
    I can confirm that the asset tracker in v0.4.0 runs fine on the nrf9160-dk.
    Let us first figure out if you can connect to the network.
    Please flash the AT client as described in the Getting started tutorial.
    Then I want you to open and use the LTE Link Monitor with the nrf9160DK connected to your computer and select your kit in the LTE Link Monitor and hit the reset button on the nRF91DK.
    One thing to note with the LTE Link Monitor status sidebar:
    Is that it does not update automatically, you have to actually send the "AT+CFUN?" command so the LTE Link Monitor application will go through all the necessary AT commands (a script) and send them to the modem and then it will update the responses to the "status sidebar".
    Here you can see I actually have a connection but the status bar has not been updated: (this is after ~3 minutes after It went through the automatic AT commands)
    If I send the "AT+CFUN?" command again you can see that it will update to the correct parameters:
    and you actually see that I have a connection with the network. ("Telenor Norge AS" in my case)
    Please confirm that this happens on your side as well before we move on to the next step.
    Now that we know that we have a network connection we can try the "asset_tracker" application which will connect to the nrf cloud.
    I am adding the precompiled .hex file of the "Asset_tracker" merged with the "Secure Partition Manager" (SPM):  (this is from the v0.4.0 release)
    asset_tracker.hex
    To flash this .hex file please use the following command in the command line:
    nrfjprog --program asset_tracker.hex -f nrf91 --sectorerase -r --verify
    Note: You can use the LTE Link Monitor as a standard serial output Terminal if you deselect the "Automatic requests" setting:
    This will prohibit that the LTE Link Monitor will run through the script sending AT commands when sending for example "AT+CFUN?". (it will only send it once)
    Please have the LTE Link Monitor open while testing the "asset_tracker" application to easier see what is actually going on.
    Here you can see the output after the "asset_tracker" got a connection with the nrf cloud server.
    - "LTE LC config ..." is showing while the kit is trying to get a network attachment, and the following output is from the application itself saying it found and got access to the nrf cloud server.
    If you get the same output, you can now go into www.nrfcloud.com and pair your nRF91DK with your account following the steps on the nrf cloud webpage. (you do not need to register the iBasis SIM card more than once)
    After you have followed the Pairing sequence given by nrfcloud you should see this verified in the output terminal as well.
    Now you should be connected to nrfcloud.
    Extra tip:
    For faster attachment with the network the next time you power on the board is to save the information about the network in the modem flash.
    To do this just send the AT command "AT+CFUN=0".
    This will Power off the modem as well as saving the network information in the modem flash.
    (note that you need to power cycle the board after this command to turn on the modem)
    Best Regards,
    Martin L.
  • Ok, so I'm connected.
    Loading asset Tracker now.
    It seems I'm unable to download the asset_tracker.hex you have given me. Says "forbidden"
    You do not have permission to view this directory or page.
    Anyway in an attempt t move forward Jan gave me this merged.hex from the master branch a few moments ago.
    I've tried loading it using Segger (4.16) Window 10
    All I get is LTE Lc Config....
    And led 3 flashing.
    I think this means that it's trying to resolve DNS and obviously can't.
    jan_merged.hex
    I've also tried as you suggested
    nrfjprog.exe --program jan_merged.hex -f nrf91 --sectorerase --verify
    Parsing hex file.
    Erasing page at address 0x0.
    Erasing page at address 0x1000.
    Erasing page at address 0x2000.
    Erasing page at address 0x3000.
    Erasing page at address 0x8000.
    Erasing page at address 0x9000.
    Erasing page at address 0xA000.
    Erasing page at address 0xB000.
    Erasing page at address 0xC000.
    Erasing page at address 0xD000.
    Erasing page at address 0xE000.
    Erasing page at address 0xF000.
    Erasing page at address 0x10000.
    Erasing page at address 0x11000.
    Erasing page at address 0x12000.
    Erasing page at address 0x13000.
    Erasing page at address 0x14000.
    Erasing page at address 0x15000.
    Erasing page at address 0x16000.
    Erasing page at address 0x17000.
    Erasing page at address 0x18000.
    Erasing page at address 0x19000.
    Erasing page at address 0x1A000.
    Erasing page at address 0x1B000.
    Erasing page at address 0x1C000.
    Erasing page at address 0x1D000.
    Erasing page at address 0x1E000.
    Erasing page at address 0x1F000.
    Erasing page at address 0x20000.
    Erasing page at address 0x21000.
    Erasing page at address 0x22000.
    Erasing page at address 0x23000.
    Erasing page at address 0x24000.
    Erasing page at address 0x25000.
    Erasing page at address 0x26000.
    Erasing page at address 0x27000.
    Erasing page at address 0x28000.
    Erasing page at address 0x29000.
    Erasing page at address 0x2A000.
    Erasing page at address 0x2B000.
    Erasing page at address 0x2C000.
    Erasing page at address 0x2D000.
    Erasing page at address 0x2E000.
    Erasing page at address 0x2F000.
    Erasing page at address 0x30000.
    Erasing page at address 0x31000.
    Erasing page at address 0x32000.
    Applying system reset.
    Checking that the area to write is not protected.
    Programming device.
    Verifying programming.
    Verified OK.
    Same result
    SPM: NS image at 0x8000
    SPM: NS MSP at 0x2002a898
    SPM: NS reset vector at 0xfda1
    SPM: prepare to jump to Non-Secure image.
    ***** Booting Zephyr OS v1.14.99-ncs1-1066-gf210011b9609 *****
    Application started
    LTE LC config ...
    Just a guess Martin is there a new version of uicr_tcxo.hex that should be loaded?
    I used the NRF Connect Programmer and erased all.
    I understand that this required uicr_tcxo.hex to be reloaded with the following command
    nrfjprog.exe --program uicr_tcxo.hex -f nrf91 --sectorerase --verify
    uicr_tcxo.hex
    Above is the file I loaded, then the modem from:
    https://www.nordicsemi.com/Products/Low-power-cellular-IoT/nRF9160/Download#infotabs
    Then compiled and loaded asset _tracker producing merged.hex and downloaded intel hex file.
    Quite a bunch of times now.
  • Hi John,
    Please follow the guide on how to build and flash the asset_tracker: https://devzone.nordicsemi.com/nordic/b/cellular-iot-guides/posts/getting-started-with-nrf9160-dk#h34sjqfiv5sq5kic2a102m2cw9mf4o9
    You should not need to flash uicr_tcxo since that is not needed anymore.
    Please try with the iBasis SIM card or another SIM card.
    Re-attaching the .hex file mentioned in the last post:
    asset_tracker (4).hex
    Also, it would be beneficial if you could share the full log from the LTE Link Monitor.
  • Hi Martin.
    I've used an ibasis sim
    Flashed your asset_tracker (4).hex
    Same result.
    With reference to your comment that uicr.hex isn't required.
    It seems that after an erase all with NRF Connect Programmer that the modem software is unable to be installed, however if I flash uicr it can be.
    Not understanding fully the function that uicr performs, I'm curious if I'm using the correct version as it certainly seems to be doing "something".
    If you also say that I shouldn't be silly enough to erase all...then someone has to do it Slight smile
    C:\Users\jcris\Desktop\Modem>nrf9160_mdm_dfu --update
    Configure APP IPC as non-secure
    Configure IPC HW for DFU
    Configure APP RAM as non-secure
    Store DFU indication into shared memory
    Power up / reset modem
    Start polling IPC.MODEM_CTRL_EVENT to receive root key digest
    Modem responded with a5000001
    Modem root key digest received: 72b3d7c13e549acf08bbc48cb936b9b861e4cbae28a7537c9859a6d945ee9489
    Store IPC DFU executable into shared memory
    Send IPC.APP_CTRL_TASK
    Start polling IPC.MODEM_CTRL_EVENT To receive 'Started' indication from DFU executable
    ERROR: Time out, no event received after 10 sec.
    C:\Users\jcris\Desktop\Modem>cd ..
    C:\Users\jcris\Desktop>cd uicr
    C:\Users\jcris\Desktop\UICR>nrfjprog.exe --program uicr_tcxo.hex -f nrf91 --sectorerase --verify
    Parsing hex file.
    WARNING: A UICR write operation has been requested but UICR has not been
    WARNING: erased. Please verify that the result is correct.
    Programming device.
    Verified OK.
    C:\Users\jcris\Desktop\UICR>cd ..
    C:\Users\jcris\Desktop>cd modem
    IPC DFU 'Started' indication from DFU received
    Updating modem firmware
    Programming pages from address 0x59602000
    Programming pages from address 0x6000
    Programming pages from address 0x50000
    Programming pages from address 0x60000
    Programming pages from address 0x70000
    Programming pages from address 0x80000
    Programming pages from address 0x90000
    Programming pages from address 0xa0000
    Programming pages from address 0xb0000
    Programming pages from address 0xc0000
    Programming pages from address 0xd0000
    Programming pages from address 0xe0000
    Programming pages from address 0xf0000
    Programming pages from address 0x100000
    Programming pages from address 0x110000
    Programming pages from address 0x120000
    Programming pages from address 0x130000
    Programming pages from address 0x140000
    Programming pages from address 0x150000
    Programming pages from address 0x160000
    Programming pages from address 0x170000
    Programming pages from address 0x180000
    Programming pages from address 0x190000
    Programming pages from address 0x1a0000
    Programming pages from address 0x1b0000
    Programming pages from address 0x1c0000
    Programming pages from address 0x1d0000
    Programming pages from address 0x1e0000
    Programming pages from address 0x1f0000
    Programming pages from address 0x200000
    Programming pages from address 0x210000
    Programming pages from address 0x220000
    Programming pages from address 0x230000
    Programming pages from address 0x27c000
    Programing firmware time: 47.579352
    Firmware update time including overhead: 50.544982
    Firmware updated.
    Starting verification
    Digest reading started
    Firmware digest received from modem: bf002e90453a1ed0566e8ff81580d78ef8bbd44cdf3886abf51dc853f9443349
    Verification success
    Total time used: 55.257405
    2019-06-03T19_40_06.536Z-log.txt
    Here's the current log file from NRF Connect Link Monitor.
  • Hi John,
    This will be fixed in the next modem DFU release.
    The reason I am saying that you do not need the "UICR.hex" is that this is set by the application. That means that you can flash whatever application you like to the nrf91 and the UICR are will be programmed correctly.
    This can be confirmed by erasing all and then flashing an application and doing the modem dfu. So please disregard the uicr.hex from now on.
    With regards to the log from LTE Link Monitor, could you disable the "automatic requests" and only run the asset_tracker without sending AT commands since this can interfere with the connection process happening in the "LTE LC Config".
    Best Regards,
    Martin L.
