Whisper Ware (nRf9160)
Without doubt there is a new variation of software emerging:
We are all familiar with Firmware and Software, however I really feel the need to coin the term "Whisper Ware" when it comes to the nRF9160 which I must add we are absolutely committed to making work.
I have personally spent the last 12 hours, uninstalling, changing branches, reinstalling, and trying my best to follow every "whisper" in this forum to make any of the sample applications work.
Even more frustrating is that for a brief time they did seem to function.
Now whatever I do, AT commands time out as follows:
Error: 'AT+CFUN? ' timed out
If someone would be kind enough to give detailed instruction on how I may be able to start "from scratch" and therefore remove any legacy that may exist, I would be very grateful.
I'm using Windows 10 and clearly very very frustrated.
On the ever positive side, I'm thrilled to bits that the implementation currently is such a mess, as most will or already have simply given up as they will not have the sincere patience that I have.
  • Hi John,
    I tested your application "0535.jan_merged.hex".
    SPM: NS reset vector at 0xfda1
    SPM: prepare to jump to Non-Secure image.
    ***** Booting Zephyr OS v1.14.99-ncs1-1066-gf210011b9609 *****
    Application started
    LTE LC config ...
    NRF_CLOUD_EVT_TRANSPORT_CONNECTED
    NRF_CLOUD_EVT_USER_ASSOCIATION_REQUEST
    Please enter the user association pattern using the buttons and switches
    Button 2
    Button 1
    Switch 2
    Switch 1
    Switch 2
    Switch 1
    NRF_CLOUD_EVT_USER_ASSOCIATED
    NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED
    NRF_CLOUD_EVT_READY
    NRF_CLOUD_EVT_SENSOR_ATTACHED
    GPS device found
    Notice the ***** Booting Zephyr OS v1.14.99-ncs1-1066-gf210011b9609 *****
    Is different than what you are getting as output.
    Please do the following;
    - Erase what's on the chip: nrfjprog -e
    - Confirm that you flash that file the following way:
    nrfjprog --program 0535.jan_merged.hex -f nrf91 --sectorerase -r  --verify
    Then you should get the same output.
    (it is possible that there was "garbage data" from before interfering the application)
    Best Regards,
    Martin L.
  • Hi Martin, I did what you said and yesterday I was getting a different result, whereby I was seeing a continuous reboot complaining about a 111 error. Which in thinking about it may be entirely reasonable because looking at your log you have paired with nrfcloud.
    I'm guessing that my connection and CWALLACH's connection is "being refused" because a particular IMEI "yours" already has paired with nrfcloud.
    However this morning after
    After nrfjprog -e
    I only receive
    SPM: NS image at 0x8000
    SPM: NS MSP at 0x2002a898
    Application started
    LTE LC config ...
    Are we missing a couple of steps here as discussed yesterday?
    Shouldn't I be loading SPM and downloading .elf first, because of the UICR and then reflashing the modem software then doing:?
    Anyway the above non repeatable behavior regardless of the SPM thing seems similar to my experience with the NZ distributor that I spent several hours with yesterday, who were as always extremely helpful.
    Between ourselves we had two different machines (Windows 10) using the MASTER branch of the software Segger 4.16 Both compiled the Asset Tracker.
    With no changes to the merged.hex produced we were able to make three nrf9160-DK function as expected (begin pairing process) and by erasing the chip and loading SPM .elf and modem and same merged.hex fail whereby the pairing process was never initiated.
    By doing as mentioned above I think we have eliminated (I hope) the tools and the application, as it would seem most unlikely that we were able to between ourselves make identical boards (version 0.8.5) vacillate between functioning as expected and failing reliably with the same merged.hex. We can only surmise and or conclude that it is something related to the UICR mechanism and or modem. which we have no control over.
    On a completely different note:
    I have noticed that sometimes (perhaps it's me) that my environment becomes unstable when I manipulate the versions using git checkout <tag> and west update to the point that I trash the directory and start again with the following:
    mkdir ncs
    cd ncs
    west init -m github.com/.../fw-nrfconnect-nrf
    west update
    Then everything returns to normal for a while.
    If I may make a suggestion, as it seems that most users will be using either
    the MASTER branch or a tagged release of their choice that to avoid/eliminate any
    possible corruption potentially caused by Git or West that it would be really
    simple to upload relevant zips (in the usual format) of the tagged releases on the
    Nordic website?
    The software is complex enough without having to absolutely rely upon the various
    scripts involved to hopefully deliver the correct version of the software, which
    currently from my own experience, without grumbling about Git or anyone else
    most certainly doesn't seem as reliable as it should/could be.
  • Hi John,
    • Please use the recommended v0.4.0 tag
    How to get the v0.4.0 tag of NCS:
    cd ncs/ncs
    git checkout master
    git pull
    git checkout v0.4.0
    west update
    Then you do not need to worry about any other versions since this is a stable release. (it is not recommended to use the master branch)
    • Program the Asset Tracker sample
    Programming Asset Tracker tutorial
    If you have provisioned other keys to the modem flash you have overwritten the already pre-provisioned nrf cloud credentials which can be the reason why you cannot connect to the nrf cloud. If you can run the standard mqtt_simple sample and see that you get the expected result : https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/nrf9160/mqtt_simple/README.html
    Then this is most likely the reason why you cannot access the nrf cloud.
    If that is the case we can send you the certificates over a Direct message if you want to connect to the nrf cloud with your nrf91DK.
    Please go through the nRF Connect SDK tutorial which will answer your other questions: https://devzone.nordicsemi.com/nordic/cellular-iot-guides/b/getting-started-cellular/posts/nrf-connect-sdk-tutorial
    Please disregard the UICR.hex since the same functionality has been implemented in the spm.
    Best Regards,
    Martin L.
