dfu removes bonds
I am using secure dfu with bonds (SDKv15.3, Segger, nrF52832), it works fine however after each dfu (application only) I lose the bond information.
I have search about it and found that there are several variables that can affect to it, I think I checked all of them but the problem still remains:
1-I use nRF Toolbox from Android phone and I enabled the "keep bonds" option on the settings. Can you btw tell me what is doing exactly this option and how is this setting is transfered to the secure dfu code to remove or not the bonds?
2-The sdk_config.h on the secure download has NRF_DFU_APP_DATA_AREA_SIZE set to 12288 (I think is correct to match FDS 3*4*1024)
3-FDS on the application side (based on heart rate example) has FDS_VIRTUAL_PAGES = 3, FDS_VIRTUAL_PAGE_SIZE = 1024, where I think stores the bonds.
According to comment on sdk_config.h it is same size as 12288:
// <i> The total amount of flash memory that is used by FDS amounts to @ref FDS_VIRTUAL_PAGES * @ref FDS_VIRTUAL_PAGE_SIZE * 4 bytes.
To me knowledge all seems to be fine, but .... why I after dfu the phone and board cannot connect?
To bypass the problem I remove bonds on the board and phone and connect them after each dfu, then everything seems to work fine... till the next dfu.
Carlos
  • I will try to get full sniffer, before dfu (bond and normal operation) -> dfu -> normal operation after dfu (mobile app reports 'cannot subscribe to event' and if I check with nRF connect I can connect but cannot see any service like bas, dis, dfu...).
    Would it help  this trace or do you already have an idea to check? Please tell me how to proceeed. I guess issue is related with service change... but learning and understanding the full SDK is hard without your support.
    Thks
    I uploaded full sniffer for all proces normal condition, dfu and post-dfu normal condition on private case: Case ID: 229977
    I hope you can have a look and help me to fix the issue.
    Here I paste the log from the board corresponding to the sniffer trace
    **********First launch of phone app and nRf board, fails to bond*****************
    <info> app: ble_evt_handler 0x10
    <info> app: Connected
    <info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Encryption, error: 4102
    <info> app: ble_evt_handler 0x14
    <info> app: ble_evt_handler 0x13
    <info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 132
    <info> app: ble_evt_handler 0x19
    <info> app: BLE_GAP_EVT_AUTH_STATUS: status=0x84 bond=0x0 lv4: 0 kdist_own:0x0 kdist_peer:0x0
    <info> app: ble_evt_handler 0x12
    <info> app: Fast advertising.
    <info> app: PLX on_disconnect
    <info> app: ble_evt_handler 0x11
    <info> app: Disconnected, reason 0x13.
    <info> app: Disconnected, reason BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION
    Switch off and on nRF board
    **********Second launch of phone app and nRf board, everything goes fine, all sucessive uses works fine always from this point*****************
    <info> app: ble_evt_handler 0x1A
    <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
    <info> app: BLE_GAP_EVT_AUTH_STATUS: status=0x0 bond=0x1 lv4: 0 kdist_own:0x3 kdist_peer:0x3
    <info> app: ble_evt_handler 0x35
    <info> app: ble_evt_handler 0x36
    <info> app: ble_evt_handler 0x50
    <info> app: ble_evt_handler 0x53
    **********Second launch of phone app and nRf board, everything goes fine*****************
    <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
    **********Made secure dfu bonded to the same application, everything goes fine*****************
    <info> app: Received indication state 1
    <info> app: Writing peer data to the bootloader...
    <info> app: ble_evt_handler 0x51
    <info> app: Device is preparing to enter bootloadã[info> app: Device is preparing to enter bootloader mode.
    <info> app: Disconnected 1 links.
    <info> app: Device will enter bootloader mode.
    <info> pwr_mgmt: Shutdown request 2
    <info> pwr_mgmt: Shutdown started. Type 2
    <info> app: Power management wants to reset to DFU mode.
    <info> app: Power management allowed to reset to DFU mode.
    <info> pwr_mgmt: SysOff handler 0x0002C405 => ready
    <info> pwr_mgmt: Shutdown complete.
    <info> pwr_mgmt: NVIC_SystemReset
    **********First start after DFU, connects to phone but no services are displayed. From this point all sucesive trials are same until we remove bonds on both phone and nRF and then we go to step1 and we got the system working fine forever (till next dfu)*****************
    <info> app: ble_evt_handler 0x54
    Thank you for your help!
  • Hi Carlos,
    Looking at the sniffer trace and the last connection I cannot see anything wrong with regards to the reencryption using the bonding data( i.e. stored encryption key). The link layer packets(i.e. LL_ENC_REQ/RSP, LL_START_ENC_REQ/RSP) are all send in the correct order and the parameters look good.
    So the bonding data must be preserved during the DFU otherwise you should have gotten a LL_REJECT_IND or LL_REJECT_EXT_IND packet in return.
    The sniffer trace does not show any LL activity nor ATT activity after the link is encrypted. If the nRF device was bonded with the Android device, then it should have cached the GATT table of the application. However, it could be that you simply have to update the GATT attribute
    Does the DFU update increase or modify the GATT table of the application compared to the application that was replaced? OItherwise,the GATT attribute table handles should be the same as before the DFU.
    Can you check if the NRF_SDH_BLE_SERVICE_CHANGED define in sdk_config.h is set in the bootloader project? Could you also check if this is set in the applicaiton as well?
    We do have a "refresh device cache" feature in nRF Connect. Connect to the device, then press the three vertical dots in the upper-right corner and then press "Refresh device cache". Does the Android device perform a new service discovery and display the services and characteristics after doing this?
    Best regards
    Bjørn
  • Thank you Bjorn,
    regarding you questions;
    >>Does the DFU update increase or modify the GATT table of the application compared to the application >>that was replaced? OItherwise,the GATT attribute table handles should be the same as before the >>DFU.
    No, application is exactly same before and after because dfu, after compile I generate hex and app_package. I write hex files in the board and then I update app to the same version, so no change in the application.
    >>Can you check if the NRF_SDH_BLE_SERVICE_CHANGED define in sdk_config.h is set in the >>bootloader project? Could you also check if this is set in the applicaiton as well?
    Yes, it is defined on both application and bootloader.
    >>We do have a "refresh device cache" feature in nRF Connect. Connect to the device, then press the >>three vertical dots in the upper-right corner and then press "Refresh device cache". Does the Android >>device perform a new service discovery and display the services and characteristics after doing this?
    And here comes the good news, by doing 'refresh services' when fRF is connected or 'refresh device cache' when it is disconnected and the connect it all services appear again and it work normally.
    The option name in nRF Connect changes when it is connected or disconnected but it seems to have same effect.
    Can you please tell me a bit more about this option and how would it be possible to make it work without the user need to do this refresh?
    Is this expected behavior or is it due to I miss something in my code?
    Thank you!!
  • Regarding my last question below:
    "Can you please tell me a bit more...
    Is this expected behavior or is it due to I miss something in my code?"
    Is is there any advice?
    thks
