I was able to use SPI communication to read data from ADS1220 (one channel of a 3-channel ADC) and transmit it via NUS ble service to my NRF Toolbox app and RTT logger on my PC (each data transfer is 3 bytes). Currently this is using 1 input pin of the ADC.
I would now like to switch between the 2 inputs of the ADC in turn and continuously receive data from both channels in real time. I wrote the following program which alternately initializes the ADC for a specific channel config and then calls data from it.
spi_init();
init_ain1();
nrf_delay_ms(100);
// Start execution.
advertising_start();
// Enter main loop.
for (;;)
idle_state_handle();
init_ain1(); //writes to ADC registers for channel change
data_call_for_ch1();
nrf_delay_ms(1000);
init_ain2();
data_call_ch2();
NRF_LOG_FLUSH();
///// This is my data call/transfer SPI function. Same for ch2
void data_call_for_ch1(void)
uint32_t err_code=0;
uint16_t ble_buff_len = m_rx_bufferSize;
memset(m_tx_buf, 0, (m_rx_bufferSize+3) );
m_tx_buf[0] = 0x08; // HEX command for transfer
memset(m_rx_buf, 0, m_rx_bufferSize);
spi_xfer_done = false;
nrf_gpio_pin_clear(SPI_CS_PIN);
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 1, m_rx_buf, m_rx_bufferSize));
while (!spi_xfer_done)
__WFE();
NRF_LOG_FLUSH();
if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
err_code = ble_nus_data_send(&m_nus, m_rx_buf, &ble_buff_len, m_conn_handle);
void init_ain1 (void) // Same config settings for Ch2
// Registers Config for pH AIN1
// Reg hex settings
m_tx_buf[0] = 0x40;
m_tx_buf[1] = 0x82;
m_tx_buf[2] = 0x10;
m_tx_buf[3] = 0x06;
m_tx_buf[4] = 0x20;
nrf_delay_ms(100);
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 5, m_rx_buf, m_rx_bufferSize));
__WFE();
According to the ADC ADS1220 datasheet, the ADS1220 register 0 has to be re-written for it to change input channel...
However, whenever I try to re-configure the registers before a data transfer call, I start receiving all "FFFFFF..." data. In my earlier experience with this ADC, it gives out "FFFFFF" when you try to call data faster than it is available. However, no matter how much delay I add, the problem persists and I cannot switch between channels in my program. I am not if the "FFFF"
data represents the same problem or something else...
SPI frequency = 4 MHz
SPI Mode 1
40 Samples/sec on Turbo Mode (512kHz Modulator clock)
Embedded Studio, nRF52382, TI- ADS1220, ble_nus, SDK 15.2
