I want to write or change the code in to nRF52832
I have some code this code i should write for nRF52832
kindly give any suggestion
here is the my code
uint8_t HT1632_LedMatrix::putChar(int x, int y, char c) { // fonts defined for ascii 32 and beyond (index 0 in font array is ascii 32); // CGRAM characters are in range 0 to 15 with 8-15 being repeat of 0-7 // note we force y to be modulo 8 - we do not support writing character to partial y values. uint8_t charIndex; uint8_t colData; uint8_t numCols; uint8_t chipno; uint8_t addr; uint8_t colsLeft = 0; // cols that didn't fit if( c > 15 ) { // Regular characters // replace undisplayable characters with blank; if (c < 32 || c > 126) { charIndex = 0; } else { charIndex = c - 32; } // move character definition, pixel by pixel, onto the display; // fonts are defined as one byte per col; numCols=smallFont[charIndex][6]; // get the number of columns this character uses for (uint8_t col=0; col<numCols; col++) { colData = smallFont[charIndex][col]; chipno = chip_number(x,y); addr = chip_byte_address(x,y); // compute which memory byte this is in if (x <= xMax && y <= yMax) { shadowram[(addr>>1)+32*chipno] = colData; sendcol(chipno,addr,colData); x++; } else { colsLeft++; } } } else { // CGRAM Characters charIndex = c & 0x07; // Only low 3 bits count numCols=cgram[charIndex][0]; // get the number of columns this character uses // fonts are defined as one byte per col; for (uint8_t col=1; col<=numCols; col++) { colData = cgram[charIndex][col]; chipno = chip_number(x,y); addr = chip_byte_address(x,y); // compute which memory byte this is in if (x <= xMax && y <= yMax) { shadowram[(addr>>1)+32*chipno] = colData; sendcol(chipno,addr,colData); x++; } else { colsLeft++; } } } cursorX = x; cursorY = y; return colsLeft; }
