BLE UART connection status
Hello Nordic Pro's,
We are developing a product based on the BLE UART peripheral.  We communicate heavily via NUS.  There are extended processes that continually send status messages over BLE via a central based device.  These processes need to continue if the system disconnects, but the messages need to resume once reconnected.  So, we need to be able to detect the connection status and not send any messages when not connected, then resume the message once connected.  I have read through most if not all of the related cases, but cannot decipher a straightforward answer.  How can I determine from within a peripheral app whether it is connected to a central device? Has anyone successfully done this?
Thanks again,
Robin@TL
  • Another note that might help, is that our board does not have a hardware uart peripheral.  All i/o is via the ble uart interface.
  • Hello again Simon,
    Well I believe I have tracked this down to the fact that the advertising module puts the processor to sleep after a 3 minute timeout, presumably APP_ADV_TIMEOUT_IN_SECONDS   (180).  I can't see through the advertising module documentation well enough to understand how to properly and selectively, based on the state of our application, ignore the BLE_ADV_EVT_IDLE flag.  I have commented out the line that puts the cpu to sleep, and the code keeps running, but I cannot reconnect after the timeout.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
     //           sleep_mode_enter();
    Any help is greatly appreciated,
    Robin@TL
  • the advertising module puts the processor to sleep after a 3 minute timeout,
    It's not actually the Advertising Module itself which does it;  it's "your" app - when it receives the Timeout event from the Advertising Module.
    Two options:
    1. Set the advertising to never time out - use BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED;
    2. Just re-start advertising on each timeout
      There'l be an "advertising start" function called somewhere early on - just call that again.
    Indeed - with no advertising, your device cannot be seen and, therefore, you can't connect to it.
  • Mr. Neil,
    Should I presume that BLE_ADV_EVT_IDLE is the flag for the timeout?  Where is this stuff documented?
  • Where is this stuff documented
    Here:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/lib_ble_advertising.html
    You can also use your IDE's 'Go To Definition' feature to find the definition of BLE_ADV_EVT_IDLE - where there should be a descriptive comment:
    /**@brief   Advertising events.
     * @details These events are propagated to the main application if a handler was provided during
     *          initialization of the Advertising Module. Events for modes that are not used can be
     *          ignored. Similarly, BLE_ADV_EVT_WHITELIST_REQUEST and BLE_ADV_EVT_PEER_ADDR_REQUEST
     *          can be ignored if whitelist and direct advertising is not used.
    typedef enum
        BLE_ADV_EVT_IDLE,                /**< Idle; no connectable advertising is ongoing.*/
        BLE_ADV_EVT_DIRECTED_HIGH_DUTY,  /**< Direct advertising mode has started. */
        BLE_ADV_EVT_DIRECTED,            /**< Directed advertising (low duty cycle) has started. */
        BLE_ADV_EVT_FAST,                /**< Fast advertising mode has started. */
        BLE_ADV_EVT_SLOW,                /**< Slow advertising mode has started. */
        BLE_ADV_EVT_FAST_WHITELIST,      /**< Fast advertising mode using the whitelist has started. */
        BLE_ADV_EVT_SLOW_WHITELIST,      /**< Slow advertising mode using the whitelist has started. */
        BLE_ADV_EVT_WHITELIST_REQUEST,   /**< Request a whitelist from the main application. For whitelist advertising to work, the whitelist must be set when this event occurs. */
        BLE_ADV_EVT_PEER_ADDR_REQUEST    /**< Request a peer address from the main application. For directed advertising to work, the peer address must be set when this event occurs. */
    } ble_adv_evt_t;
    Sometimes (too often?), Nordic's idea of "descriptive" does seem rather lacking
    Disappointed
    Also, where to find the documentation is not always obvious: it'll be in the InfoCenter somewhere - but finding it is not always so easy ...
