How to use the below code to SDK 15.3.0
#include <string.h>
#include <inttypes.h>
#include "softdevice_handler.h"
#include "app_scheduler.h"
#include "app_timer_appsh.h"
#include "nrf_dfu_settings.h"
#include "ble_dis.h"
#include "istddef.h"
#include "iopincfg.h"
#include "iopinctrl.h"
#include "stddev.h"
#include "custom_board.h"
#include "lmx_blueio.h"
#include "blueio_blesrvc.h"
#include "ledmxio.h"
#include "ble_periph_app.h"
#define DEVICE_NAME                     "LmxBLue"                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "I-SYST inc."                       /**< Manufacturer. Will be passed to Device Information Service. */
#define MODEL_NUM                       "LMX_DISPLAY"                            /**< Model number. Will be passed to Device Information Service. */
#define MANUFACTURER_ID                 ISYST_BLUETOOTH_ID                               /**< Manufacturer ID, part of System ID. Will be passed to Device Information Service. */
#define ORG_UNIQUE_ID                   ISYST_BLUETOOTH_ID                               /**< Organizational Unique ID, part of System ID. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                MSEC_TO_UNITS(64, UNIT_0_625_MS)             /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
void LmxBlueSrvcWrCallback(BLUEIOSRVC *pBlueIOSvc, uint8_t *pData, int Offset, int Len);
static const IOPINCFG s_GpioPins[] = {
	{BLUEIO_CONNECT_LED_PORT, BLUEIO_CONNECT_LED_PIN, 0, IOPINDIR_OUTPUT, IOPINRES_NONE, IOPINTYPE_NORMAL},	// BLE connect
static const int s_NbGpioPins = sizeof(s_GpioPins) / sizeof(IOPINCFG);
static const ble_uuid_t  s_AdvUuids[] = {
	{LMXBLUE_UUID_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN}
static const char s_RdCharDescString[] = {
		"LmxBlue data characteristic",
static const char s_WdCharDescString[] = {
		"LmxBlue write characteristic",
uint8_t g_ManData[8];
BLUEIOSRVC_CHAR g_LmxChars[] = {
		LMXBLUE_UUID_MSGCHAR,
		256,
		BLUEIOSVC_CHAR_PROP_WRITEWORESP,
		s_WdCharDescString,
const BLUEIOSRVC_CFG s_LmxBlueSrvcCfg = {
	BLUEIOSRVC_SECTYPE_NONE,
	LMXBLUE_UUID_BASE,
	1,
	g_LmxChars
BLUEIOSRVC g_LmxBleSrvc;
const BLEAPP_CFG s_BleAppCfg = {
	BLEAPP_MODE_APPSCHED,
	"LMXBLUE",
	"IBB-LMXBLUE",
	"I-SYST inc.",
	"0.0",
	"0.0",
	ISYST_BLUETOOTH_ID,
	1,
	g_ManData,
	sizeof(g_ManData),
	BLEAPP_SECTYPE_NONE,
	BLEAPP_SECEXCHG_NONE,
	NULL,//s_AdvUuids,
	0,//sizeof(s_AdvUuids) / sizeof(ble_uuid_t),
	APP_ADV_INTERVAL,
	APP_ADV_TIMEOUT_IN_SECONDS,
	0,
	NULL
// I/O pins connection
LEDMXIOCFG g_IOCfg = {
	LMXBLUE_WR_PIN,  // WR pin
	LMXBLUE_RD_PIN,  // RD pin
	LMXBLUE_DATA_PIN,  // Data pin
	LMXBLUE_EN_PIN, // En pin
	{ LMXBLUE_AD0_PIN, LMXBLUE_AD1_PIN, LMXBLUE_AD2_PIN, LMXBLUE_AD3_PIN,}, // CS pins
	4,  // Number of CS pins
	LMXBLUE_CSTYPE
#define LMXBLUE_LINE_MAX			16
// Display board configuration
LEDMXCFG g_LmxCfg[LMXBLUE_LINE_MAX] = {
	    &g_IOCfg,
		4,  // Number of display board in daisy chain, only one in this case
		{0, 1, 2, 3,}, // display board ordering
	    &g_IOCfg,
		{4, 5, 6, 7,}, // display board ordering
	    &g_IOCfg,
		{8, 9, 10, 11,}, // display board ordering
	    &g_IOCfg,
		{12, 13, 14, 15,}, // display board ordering
LEDMXDEV g_LmxDev[LMXBLUE_LINE_MAX] = {{0,},};
	LMXMSG *msg = (LMXMSG*)pData;
	msg->Text[msg->Length] = 0;
	//LedMxPrintLeft(&g_LmxDev, msg->Text);
void BlePeriphAppSrvcEvtDispatch(ble_evt_t * p_ble_evt)
    BlueIOBleSvcEvtHandler(&g_LmxBleSrvc, p_ble_evt);
void BlePeriphAppInitServices()
    uint32_t       err_code;
    err_code = BlueIOBleSrvcInit(&g_LmxBleSrvc, &s_LmxBlueSrvcCfg);
void HardwareInit()
	// config Bluetooth connection state LED
    IOPinCfg(s_GpioPins, s_NbGpioPins);
	// Initialize IDM-LMX3208 series displays
	//LedMxInit(&g_LmxDev, &g_LmxCfg);
	//LedMxPrintLeft(&g_LmxDev, "IBB-LMXBLUE Blutooth LED matrix demo");
void BlePeriphAppInitUserData()
// Print a greeting message on standard output and exit.
// On embedded platforms this might require semi-hosting or similar.
// For example, for toolchains derived from GNU Tools for Embedded,
// to enable semi-hosting, the following was added to the linker:
// --specs=rdimon.specs -Wl,--start-group -lgcc -lc -lc -lm -lrdimon -Wl,--end-group
// Adjust it for other toolchains.
int main()
    HardwareInit();
    BlePeriphAppInit(&s_BleAppCfg, true);
    BlePeriphAppStart();
    while(1)
    	BlePeriphAppProcessEvt();
	return 0;
What are the changes required to change this code for SDK 15.3.0
