Is it possible to update firmware via BLE DFU from v14 to v15 of the nRF5 SDK?
I am trying to update firmware that uses v14 of the nRF5 SDK to firmware that uses v15.3, but I am getting the error "Init command larger than expected.".
I'm wondering if this is supposed to be possible, or if v15.3 is not backwards compatible (I didn't see anything in the documentation saying it's not compatible).
It looks like the size of the init command buffer was increased in this version.
#define INIT_COMMAND_MAX_SIZE      512 /**< Maximum size of the init command stored in dfu_settings. */
#define INIT_COMMAND_MAX_SIZE_v1   256 /**< Maximum size of the init command in settings version 1. */
Thank You,
Josh
  • So I changed two things that got me further along (at least with nRF Connect 4.22.3 on Android):
    1) Removed the `--sd-boot-validation` as you said.
    2) Changed
    --sd-req 0x98,0x99,0x9E,0x9D,0xB7
    to
    --sd-req 0x9D
    Without #2 the "SD req not met" pre-validate was failing. For some reason it was only seeing the last SD ID in the list, so removing all but the one matching the current firmware fixed it.
    I'm still getting the same original error using the iOS DFU library, but not Android, so that's likely a separate issue I need to open with them.
    Now I'm stuck here:
    [00175162] <debug> dfu_req_handling: Reset.
    [00000000] <info> app: Inside main
    [00000000] <debug> app: In nrf_bootloader_init
    [00000000] <debug> app: in weak nrf_dfu_init_user
    [00000000] <debug> app: In real nrf_dfu_init
    [00000000] <debug> nrf_dfu_settings: Running nrf_dfu_settings_init(sd_irq_initialized=false).
    [00000000] <debug> nrf_dfu_flash: Calling nrf_dfu_flash_init(sd_irq_initialized=false)...
    [00000000] <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    [00000000] <debug> app: Initializing the clock.
    [00000000] <debug> app: Enter nrf_dfu_continue
    [00000002] <debug> app: Valid SD + BL
    [00000003] <debug> app: Enter nrf_dfu_sd_bl_continue
    [00000006] <debug> app: Enter nrf_bootloader_dfu_sd_continue
    [00000009] <debug> app: Updating SD. Old SD ver: 50, New ver: 60
    [00000012] <debug> app: Copying [0x00023000-0x0002D000] to [0x00001000-0x0000B000]: Len: 0x0000A000
    [00000757] <debug> app: Finished copying [0x00023000-0x0002D000] to [0x00001000-0x0000B000]: Len: 0x0000A000
    [00000766] <debug> app: Validated 0x00023000-0x0002D000 to 0x00001000-0x0000B000: Size: 0x0000A000
    [00000770] <debug> app: Finished with the SD update.
    [00000773] <debug> nrf_dfu_settings: Writing settings...
    [00000775] <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
    [00000779] <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
    [00000785] <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
    [00000789] <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, len=0x1B8 bytes), queue usage: 1
    [00000802] <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
    [00000805] <debug> app: Copying [0x0002D000-0x00037000] to [0x0000B000-0x00015000]: Len: 0x0000A000
    [00001551] <debug> app: Finished copying [0x0002D000-0x00037000] to [0x0000B000-0x00015000]: Len: 0x0000A000
    [00001560] <debug> app: Validated 0x0002D000-0x00037000 to 0x0000B000-0x00015000: Size: 0x0000A000
    [00001564] <debug> app: Finished with the SD update.
    [00001567] <debug> nrf_dfu_settings: Writing settings...
    [00001569] <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
    [00001573] <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
    [00001579] <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
    [00001583] <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, len=0x1B8 bytes), queue usage: 1
    [00001596] <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
    [00001599] <debug> app: Copying [0x00037000-0x00041000] to [0x00015000-0x0001F000]: Len: 0x0000A000
    [00002345] <debug> app: Finished copying [0x00037000-0x00041000] to [0x00015000-0x0001F000]: Len: 0x0000A000
    [00002353] <debug> app: Validated 0x00037000-0x00041000 to 0x00015000-0x0001F000: Size: 0x0000A000
    [00002358] <debug> app: Finished with the SD update.
    [00002360] <debug> nrf_dfu_settings: Writing settings...
    [00002363] <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
    [00002366] <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
    [00002373] <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
    [00002377] <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, len=0x1B8 bytes), queue usage: 1
    [00002389] <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
    [00002393] <debug> app: Copying [0x00041000-0x00048000] to [0x0001F000-0x00026000]: Len: 0x00007000
    [00002916] <debug> app: Finished copying [0x00041000-0x00048000] to [0x0001F000-0x00026000]: Len: 0x00007000
    [00002924] <debug> app: Validated 0x00041000-0x00048000 to 0x0001F000-0x00026000: Size: 0x00007000
    [00002928] <debug> app: Finished with the SD update.
    [00002931] <debug> nrf_dfu_settings: Writing settings...
    [00002933] <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
    [00002937] <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
    [00002943] <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
    [00002947] <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, len=0x1B8 bytes), queue usage: 1
    [00002960] <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
    [00002963] <debug> app: Verifying BL: Addr: 0x00073000, Src: 0x00047150, Len: 0x00005A10
    [00002967] <debug> app: Bootloader not verified, copying: Src: 0x00047150, Len: 0x00005A10
    <hangs here, reset doesn't help either>
    Thank You,
    Josh
    Can you provide a memory dump of your device? One after each try, one with iOS and one with Android. Can you run the following command?
    nrfjprog --memrd 0x73000 --n 0xd000 > dump.txt
    Are you updating from SDK 14.0 or 14.2?
    jlubawy said:
    Now I'm stuck here:
    Is this with iOS or Android?
    Thanks!
    Øyvind
  • I will actually be out of the country for work until 7/9, is it ok if I get back to you then with the memory dump?
    We are trying to go from v14.2 to v15.3.
    Thank You,
    Josh
  • Yes, no worries. When you are back and have the time, just submit information to this ticket.
     Thank you! There were some issues with v14.0, but this is none of your concern.
    -Øyvind
