fstorage: writting and then reading 'wrong' data?
Env: nrf52, sdk15, ubuntu, SES
Hi
First steps on fstorage. As I just need to store and read an array of some bytes I have chosen fstorage
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
    .evt_handler = fstorage_evt_handler,
    .start_addr = 0x3e000,
    .end_addr   = 0x3ffff,
printf("fstorage example started.\n");
nrf_fstorage_api_t * p_fs_api;
printf("SoftDevice is present.\n");
printf("Initializing nrf_fstorage_sd implementation...\n");
p_fs_api = &nrf_fstorage_sd;
uint32_t rc = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
APP_ERROR_CHECK(rc);
print_flash_info(&fstorage);
(void) nrf5_flash_end_addr_get();
m_data          = 0xFFFFFFFF;
const uint32_t m_data_read  ;
printf("Writing \"%x\" to flash.\n", m_data);
rc = nrf_fstorage_write(&fstorage, 0x3e000, &m_data, sizeof(m_data), NULL);
wait_for_flash_ready(&fstorage);
printf("Done.");
rc = nrf_fstorage_read(&fstorage, 0x3e000, &m_data_read,sizeof(m_data_read));
printf("Reading \"%x\" from flash.\n", m_data_read);
and I got this as output:
Writing "ffffffff" to flash.
Done.Reading "746f6e20" from flash.
Template example started.
It was written ffffffff but read 746f6e20
Another doubt: How Do we know if the flash is being written for the first time or not? I want to write it if it was not written yet.
Thanks a lot
Alex
  • Well of course you're going to get the same output if you read twice the same address without writing in between. What did you expect?
  • Same output, I meant this:
    which means that even if I just read, the value read is not ffffffff (last written). That could be justified by: as I never did an erase, and tried to write lots of things i could never get the expected vaue (ffffffff) because of the reason pointed by Jorgen.
    Now If I erase and then if I write ffffffff and can read ffffffff! :-)
    Solved!
    I was missing that flash property about "A flash write operation can only change bits from 1 to 0, to change a 0 to a 1 requires a erase operation,"
    Thanks to all
    Alex
