Issues reading virtual registers via I2C
I have an AMS AS7261 light sensor that I'm using with my NRF51422 DK to take a light reading, pull it using nrf_drv_twi_tx/rx, and send it over BLE. However, when I try to read from the virtual registers of interest, nearly each of the registers return 0. Below is my function:
void read_sensor(uint16_t values[], const uint8_t registers[]) {
  uint8_t reg_addr = registers[0]; //first virtual register to read
  uint8_t end_reg = registers[1];
  uint8_t buf;
  ret_code_t status;
  uint16_t value;
  int counter = 0;
  while (reg_addr < end_reg) {
    value = 0;
    //Read higher byte
    buf = 0;
    while(true){
      status = nrf_drv_twi_tx(&m_twi, AS72XX_ADDR, &reg_addr, sizeof(reg_addr), true);
      if (status == NRF_SUCCESS)
    while(true) {
      status = nrf_drv_twi_rx(&m_twi, AS72XX_ADDR, &buf, sizeof(buf));
    printf("Value at register %#x: %#x\r\n", reg_addr, buf);
    value = (buf<<8); //record higher byte
    reg_addr++;
    //Read lower byte
    buf = 0;
    while(true){
    while(true) {
    value += buf; //record lower byte
    reg_addr++;
    values[counter] = value; //store raw value in array
    counter++;
I want to read each of the raw data registers, which according to the datasheet are registers 0x08 to 0x13:
The only registers that return a value other than 0 are the last 4, but the values I get are also wrong (in that they do not match up with the values shown in the provided GUI to read these values).
At this point I suspect this may be more of an issue with the sensor or how I'm reading it, but if it is an issue with my code any help is appreciated!
Thank you.
  • Hi Bennett
    Thanks for sharing the data sheet.
    Reading through the sample code for reading and writing the virtual registers this seems considerably more complicated than similar sensors I have worked with, and I am not sure the code you sent me is equivalent to the code they provided.
    For one thing their virtual register read example starts with a read loop, to wait for the read buffer to be ready, while your code starts with a write.
    Secondly, it is important to note that the nrf_drv_twi_rx function returns any error code returned by the TWI driver, it doesn't return the data read. The data read is stored in the buffer that you pass into the function.
    In other words you have to implement the while(1) loops in the virtual register write/read procedures a bit different from what they do in the data sheet in order to properly check the status data returned from the sensor.
    Best regards
    Torbjørn
  • Hi Torbjørn,
    Thank you again for your help. I have resolved this issue by adding some extra read/writes. It looks like the main fix was changing the p_data argument in nrf_drv_twi_tx from just the virtual register address to an array holding both the HW write register and the virtual address.
    However, I'm running into a new issue now. When I read all the values from these registers, the registers seem to be "offset" by 1. For example, the value I should get for R0 is instead returned for R1, the value I should get for R1 is returned for R2, etc. My code is below, do you know why this may be happening?
      uint8_t reg = 0;
      uint8_t read_addy = I2C_AS72XX_SLAVE_READ_REG;
      uint8_t stat_addy = I2C_AS72XX_SLAVE_STATUS_REG;
      uint8_t reg_addr[2] = {I2C_AS72XX_SLAVE_WRITE_REG, registers[0]}; //first virtual register to read
      uint8_t buf;
      ret_code_t status;
      int counter = 0;
      FILE *fp;
      fp = fopen("./test.txt", "w");
      while (reg_addr[1] <= end_reg) {
        buf = 0;
        //Check status
        while (true) {
          nrf_drv_twi_tx(&m_twi, AS72XX_ADDR, &stat_addy, sizeof(stat_addy), true);
          if ((buf & I2C_AS72XX_SLAVE_TX_VALID) == 0)
        buf = 0;
        //Write virtual address
        while(true) {
          status = nrf_drv_twi_tx(&m_twi, AS72XX_ADDR, reg_addr, sizeof(reg_addr), true);
        //Check status
        while(true) {
          if ((buf & I2C_AS72XX_SLAVE_RX_VALID) != 0)
        buf = 0;
        //Read virtual register
        while(true) {
          status = nrf_drv_twi_tx(&m_twi, AS72XX_ADDR, &read_addy, 1, true);
        while(true) {
        printf("Value at register %#x: %#x\r\n", reg_addr[1], buf);
        fprintf(fp, "Value at register %#x: %#x\r\n", reg_addr[1], buf);
        reg_addr[1]++;
      fclose(fp);
    int main() {
        uint16_t values[6];
        const uint8_t regs[2] = {0x00, 0x13};
        read_sensor(values, regs);
    Thank you again for your help,
    Bennett Sasaki
  • Hi Bennett
    I am having a hard time understanding why this happens by looking at the code alone.
    Are you able to provide another scope plot, similar to the one you provided before?
    Ideally one showing the entire communication sequence (assuming the code doesn't have to check the status register over and over).
    Best regards
    Torbjørn
  • Hi Torbjørn,
    So I'm not sure exactly why, but this issue seems to have solved itself when I tried it again yesterday morning. I don't know what change fixed it, I'm thinking it may have just been resetting the DK/rebuilding the project, though I did try that initially as well.
    Thank you for all your help,
    Bennett
  • Hi Bennett
    You welcome!
    I'm glad you were able to solve the issue Slight smile
    Best regards
    Torbjørn
