How to use MQTT+TLS in nRF9160?
I'm working on a project using nRF9160 DK.
How can you use MQTT+TLS in nRF9160?
Where should ca certificate file be stored?
I modified the code below in mqtt_simple project. What code should I modify additionaly?
<prj.conf>
CONFIG_MQTT_LIB_TLS=y
<main.c>
/**@brief Initialize the MQTT client structure
static void client_init(struct mqtt_client *client)
	mqtt_client_init(client);
	broker_init();
        /* Add from here */
        static struct mqtt_utf8 password;
	static struct mqtt_utf8 user_name;
	password.utf8 = (u8_t *)MQTT_PASSWORD;
	password.size = strlen(MQTT_PASSWORD);
	user_name.utf8 = (u8_t *)MQTT_USERNAME;
	user_name.size = strlen(MQTT_USERNAME);
        /* to here */
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = (u8_t *)CONFIG_MQTT_CLIENT_ID;
	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
	client->password = &password; // Add here
	client->user_name = &user_name; // Add here
	client->protocol_version = MQTT_VERSION_3_1_0; // originally MQTT_VERSION_3_1_1
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
    /* MODIFIED HERE */
    #if defined(CONFIG_MQTT_LIB_TLS)
       client->transport.type = MQTT_TRANSPORT_SECURE;
       client->transport.tls.config.peer_verify = 0;
       client->transport.tls.config.cipher_count = 0;
       client->transport.tls.config.cipher_list = NULL;
       client->transport.tls.config.sec_tag_count = 0;
       client->transport.tls.config.seg_tag_list = NULL;
       client->transport.tls.config.hostname = NULL;
    #else
       client->transport.type = MQTT_TRANSPORT_NON_SECURE;
  • Hello, KentaM!
    CONFIG_SEC_TAG may be wrong value so that the error may be caused. How do you decide the value? random value?
  • I used GitHub's prj.conf, which Hakon taught me, almost as it is.
    It looks like an error with CA_CERTIFICATE, but is the CA certificate correct?
    https://github.com/joakimtoe/fw-nrfconnect-nrf/blob/36532a8ca60bf7139a988b5cbb4e6cb47948a9fa/samples/nrf9160/mqtt_simple_tls/prj.conf
    By the way, I do not understand the meaning of CONFIG_SEC_TAG ... (tell me ...)
  • About certificates, I downloaded three files from AWS IoT
    - Amazon_Root_CA_1.pem(ca crt)
    - xxxxxx-certificate.pem.crt(client crt, not public key)
    - yyyyyy-private.pem.key(client private key)
    I overwrote certificates.h put in src folder according to them.
    The following message indicates that deleting the builtin certificate files was not successful. So I don't think AWS certificate files are related to this issue.
    nrf_inbuilt_key_delete(16842753, 1) => result=14
    Could you show me the content of the prj.conf again if possible? mqtt_simple prj.conf sets a value in CONFIG_SEC_TAG while mqtt_simple_tls project prj.conf sets a value in CONFIG_MQTT_TLS_SEC_TAG.
  • prj.conf
    # General config
    CONFIG_TEST_RANDOM_GENERATOR=y
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    # BSD library
    CONFIG_BSD_LIBRARY=y
    # AT Host
    CONFIG_AT_HOST_LIBRARY=y
    #CONFIG_SPM=n
    # MQTT
    CONFIG_MQTT_LIB=y
    # Appliaction
    #CONFIG_MQTT_PUB_TOPIC="/my/publish/topic"
    #CONFIG_MQTT_SUB_TOPIC="/my/subscribe/topic"
    #CONFIG_MQTT_CLIENT_ID="my-client-id"
    #CONFIG_MQTT_BROKER_HOSTNAME="iot.eclipse.org"
    #CONFIG_MQTT_BROKER_PORT=1883
    CONFIG_MQTT_PUB_TOPIC="myTopic/publish"
    CONFIG_MQTT_SUB_TOPIC="myTopic/subscribe"
    CONFIG_MQTT_CLIENT_ID="nRF9160-DK"
    CONFIG_MQTT_BROKER_HOSTNAME="a544w27l82h92-ats.iot.us-east-1.amazonaws.com"
    CONFIG_MQTT_BROKER_PORT=8883
    CONFIG_SEC_TAG=16842753
    CONFIG_PROVISION_CERTIFICATES=y
    CONFIG_CERTIFICATES_FILE="certificates.h"
    # Main thread
    CONFIG_MAIN_THREAD_PRIORITY=7
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=1024
    CONFIG_NO_OPTIMIZATIONS=y
    By the way, I will do a study session, will you come?
    Saturday.
    atnd.org/.../106150
    I can't solve the above issue yet.
    I tried a project, which KentaM uses successfully, with two different 0.8.2 DK boards, and they throw the same error. He gave me the whole project files including certificates.h through private message and I used it. The project should be the exactly same.
    During nrf_inbuilt_key_delete, the project throws an error(14), "Bad Address."
    SPM: NS image at 0x8000
    SPM: NS MSP at 0x200240d8
    SPM: NS reset vector at 0xb609
    SPM: prepare to jump to Non-Secure image.
    ***** Booting Zephyr OS v1.14.99-ncs1 *****
    The MQTT simple sample started
    Deleting certs sec_tag: 16842753
    nrf_inbuilt_key_delete(16842753, 0) => result=2
    ***** BUS FAULT *****
      Precise data bus error
      BFAR Address: 0x2800460d
    ***** Hardware exception *****
    Current thread ID = 0x200203fc
    Faulting instruction address = 0x1682c
    Fatal fault in thread 0x200203fc! Aborting.
    nrf_inbuilt_key_delete(16842753, 2) => result=14
    nrf_inbuilt_key_delete(16842753, 3) => result=14
    nrf_inbuilt_key_delete(16842753, 4) => result=14
    Write ca certs sec_tag: 16842753
    CA_CERTIFICATE err: 14
    LTE Link Connecting ...
    LTE Link Connected!
    ERROR: getaddrinfo failed 22
    ERROR: mqtt_connect -47
    I'm sure the firmware is the latest one, 0.7.0-29.alpha.
    ncs_tag is v0.4.0
    mqtt_simple project which doesn't include TLS works fine. However, when it includes TLS procedure, it throws the error.
    Any help?
