How to update advertisement packet SDK 15.0.0 ?
Dear all,
I am trying to develop an application that reads data from a sensor (accelerometer) and I want to be able to update the advertisement packet with the measurement I obtain from it.
So far I am able to read the values from the sensor. Using this example as a basis I can transmit a single value, but I am unable to update the content of the package in order to be able to read the right value. Is there any idea, how I can do this update?
I am using SDK 15.0.0.0. From what I have seen in the forum there is no straight forward way to do this, but I wonder, if someone has the same issue and if it is possible to share some sample code with me.
Kind regards
  • Hi Jimmy. I took your code and I reduced to the minimum code necessary to simply update the advertisement package. I really want to thank you for your example and your code. I am posting the code bellow:
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_qwr.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_DURATION                0                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(1000, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
    #define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    static uint8_t m_hardcode_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX] =
            0x02, 0x01, 0x04, //flags
            0x08, 0x09, 'G', 'i', 'a', 'n', 'n', 'i', 's',
            0x12, 0xFF, 0x59,
            0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    #define INCREMENT_INTERVAL         APP_TIMER_TICKS(1000)                   /**< Increment interval (ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;              /**< Advertising handle used to identify an advertising set. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t m_conn_handle          = BLE_CONN_HANDLE_INVALID;                   /**< Handle of the current connection. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX] =
            0x11, 0xFF, 0x59,
            0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09,
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
            .adv_data =
                    .p_data = m_enc_advdata,
                    .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
            .scan_rsp_data =
                    .p_data = NULL,
                    .len    = 0
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
    /**@brief Function for handling errors from the Connection Parameters module.
            APP_ERROR_HANDLER(nrf_error);
            uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                    NRF_LOG_INFO("Connected");
                    NRF_LOG_INFO("Disconnected");
                    ble_gap_phys_t const phys =
                            .rx_phys = BLE_GAP_PHY_AUTO,
                            .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                    // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                    // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
    static void non_connectable_advertising_init(void)
            uint32_t err_code;
            m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
            m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
            m_adv_params.duration        = APP_ADV_DURATION;
            NRF_LOG_DEBUG("non_connectable_advertising_init");
            m_adv_data.adv_data.p_data = m_hardcode_enc_advdata;
            m_adv_data.adv_data.len    = 0x1F; // hardcode to 31 bytes
            err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    static void log_init(void)
    /**@brief Function for placing the application in low power state while waiting for events.
    #define FPU_EXCEPTION_MASK 0x0000009F
            __set_FPSCR(__get_FPSCR()  & ~(FPU_EXCEPTION_MASK));
            (void) __get_FPSCR();
            NVIC_ClearPendingIRQ(FPU_IRQn);
            while(NRF_LOG_PROCESS());
            //UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
            nrf_pwr_mgmt_run();
    static void non_connect_advertising_start(void)
            err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    /**@brief Function for initializing Radio Notification Software Interrupts.
    uint32_t radio_notification_init(uint32_t irq_priority, uint8_t notification_type, uint8_t notification_distance)
        uint32_t err_code;
        err_code = sd_nvic_ClearPendingIRQ(SWI1_IRQn);
        if (err_code != NRF_SUCCESS)
            return err_code;
        err_code = sd_nvic_SetPriority(SWI1_IRQn, irq_priority);
            return err_code;
        err_code = sd_nvic_EnableIRQ(SWI1_IRQn);
            return err_code;
        // Configure the event
        return sd_radio_notification_cfg_set(notification_type, notification_distance);
    /**@brief Software interrupt 1 IRQ Handler, handles radio notification interrupts.
    void SWI1_IRQHandler(bool radio_evt)
        if (radio_evt)
            nrf_gpio_pin_toggle(BSP_LED_2); //Toggle the status of the LED on each radio notification event
             m_hardcode_enc_advdata[30]++;
    /**@brief Application main function.
            bool erase_bonds;
            bool connect_mode_enter = false;
            uint32_t err_code = NRF_SUCCESS;
            log_init();
            timers_init();
            //buttons_init();
            power_management_init();
            ble_stack_init();
            err_code = radio_notification_init(3, NRF_RADIO_NOTIFICATION_TYPE_INT_ON_INACTIVE, NRF_RADIO_NOTIFICATION_DISTANCE_NONE);
            //application_timer_start();
            non_connectable_advertising_init();
            non_connect_advertising_start();
            NRF_LOG_INFO("Non-Connected Advertising!");
            // Enter main loop.
            for (;;)
                   idle_state_handle();
    I hope this will clear things out for people. Also this code doesn't do the update job in SDK 15.0.0, but 15.3.0.
    Again thank you very much Jimmy.
  • Hello Jimmy,
    Your example code really helped me to move on with my project.
    Currently I also need to be able to update the response packet. But if actually put a length to the scan_rsp_data that is not 0 the code brakes.
    Do you have any idea why this is happening?
  • Hi Giannis,
    I think it is same approach.  You only need to set the data pointer to the scan response payload.
  • Hi there Jimmy.
    I tried to replicate the same actions for the scan response package, but I keep getting an error.
    This is how I have changed the code:
            .adv_data =
            .scan_rsp_data =
    Created another array:
    static uint8_t m_hardcode_enc_rspdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX] =
            0x1B, 0xFF, 0x59,
            0x00, 0xAA, 0xBB, 0xCC,
    And passed the pointer to the pointer the same way you do:
    m_adv_data.scan_rsp_data.p_data   = m_hardcode_enc_rspdata;
    m_adv_data.scan_rsp_data.len = 0x1F;
    When I run the code in debug, I end up getting an error.
    Any ideas?
