Problem about fatfs and QSPI on nRF52840
static bool fatfs_init(void)
	FRESULT ff_result;
	bool    init_result = true;
	DSTATUS disk_state = STA_NOINIT;
	bool flag = false;
	memset(&m_filesystem, 0, sizeof(FATFS));
	// Initialize FATFS disk I/O interface by providing the block device.
	static diskio_blkdev_t drives[] =
#if USE_SD_CARD
		DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)
#else
			DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_qspi, block_dev), NULL)
	diskio_blockdev_register(drives, ARRAY_SIZE(drives));
	NRF_LOG_INFO("Initializing disk 0 (QSPI)...");
	disk_state = disk_initialize(0);
	if (disk_state)
		NRF_LOG_ERROR("Disk initialization failed.");
		return false;
	NRF_LOG_INFO("Mounting volume...");
	ff_result = f_mount(&m_filesystem, "", 1);
	if (ff_result != FR_OK)
		if (ff_result == FR_NO_FILESYSTEM)
			NRF_LOG_ERROR("Mount failed. Filesystem not found. Please format device.");
			NRF_LOG_ERROR("Mount failed: %u", ff_result);
		ff_result = fatfs_mkfs();
			init_result = false;
#ifdef RECORD_ERR
			m_log_buf_len =   sprintf((char *)m_log_buf, "f_mount failed,then fatfs_mkfs sucessfully, fatfs_mkfs result %d\r\n", ff_result);
			record_stat_data(0);
			flag = true;
		flag = true;
#ifdef RECORD_ERR
		m_log_buf_len =   sprintf((char *)m_log_buf, "Initializing disk 0 (QSPI) completed,ff_result %d\r\n",ff_result);
		record_stat_data(1);
	return init_result;
Hi, I was using nRF52840 , flash is mx25L25645GM2, I used fatfs with QSPI ,but I found fatfs was unstable,After some time, the stored file would dispear.Sometime there were scrambling symbols in my files
